Mazdaspeed Forums
-   Mazdaspeed3/6 General Discussion (http://www.mazdaspeedforum.org/forum/forum/f505/)
-   -   Refurbish trans mount? (http://www.mazdaspeedforum.org/forum/forum/f505/refurbish-trans-mount-223243/)
Gary1001 12-19-2019 07:47 PM
Anyone know if it possible to recast or replace the rubber in the gen1 transmission motor mount? Look to diy instead of buying new.
Cyberdutch 12-20-2019 12:56 AM
So, you are willing to spend more money on diy repair, then buying a new OEM mount? Interesting...
Verstuurd vanaf mijn SM-G970F met Tapatalk
Gary1001 12-20-2019 05:47 AM
It's $35 for 1 litre of liquid urethane. Doesn't repair sound like something worth considering?
Example
Cyberdutch 12-20-2019 06:08 AM
It will be difficult to find an rubber insert with the right sturdiness. And the glue must be very durable and weather resistant. I think the oem is vulcanised rubber. Not easy to replicate.
Db09ms3 12-20-2019 09:08 AM
Get used or buy new. I went GenPu Tranny Mount with the CS insert. Better design, better feel.
Don't be a cheap skate scrub:spankme:
Jeff23spl 12-20-2019 12:08 PM
i did fill an oem mount with urethane for my gs-sky 155hp but for a speed it isn't enought.
I used it previously on older winter beater as a cheap fix. you mask one side with tape and fill by the other and let it dry.....it isn't bad and last a lot but it won't make a very rigid support like the one sold for the speed.
Page generated in 0.16948 seconds with 11 queries
