 Old 06-21-2011, 01:59 PM   #1
ukmps3's Avatar
Posts: 31   (View Stats)
ukmps3 has a brilliant futureukmps3 has a brilliant futureukmps3 has a brilliant futureukmps3 has a brilliant futureukmps3 has a brilliant futureukmps3 has a brilliant futureukmps3 has a brilliant futureukmps3 has a brilliant futureukmps3 has a brilliant futureukmps3 has a brilliant futureukmps3 has a brilliant future
Default Replacement VVT Parts Kit
Can anyone tell me if anyone does VVT Actuator, tensioner, chain etc as a kit to buy??
thanks
Mazda 3 mps : Hypertech tune only so far...
ukmps3 is offline   Reply With Quote
 Old 06-21-2011, 02:36 PM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Tech/Sales@EM
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 06-25-2011, 05:05 PM   #3
Burdoror's Avatar
Posts: 52   (View Stats)
Burdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud of
thanks
Onlinemazdaparts.com
I have prepared for my self:
I think I did not miss anything, right?
Mazda 3 MPS 2007
Street Shadow Garage (SSG) custom: FMIC (Precision), 3" High flow cat DP, 3" CBE.
Autotech HPFP internals, Forge BPV Gen2, K&N Typhoon,CPE TIP, Sachs clutch, Fidanza flywheel, STRI oil temp and egt temp, Innovation AFR, Bilstein B14, TRZ Dog Bone RMM, James Barone Racing RSB, HEL Brakelines, Tenzo-r DC5, Bridgestone S001 235/40
Powered by DisiTune
295WHP
Burdoror is offline   Reply With Quote
 Old 06-25-2011, 05:35 PM   #4
Tokay444's Avatar
Groans: 793
You missed all the bolts and washers.
And timing tools.
Demodded.
The Seals
Last edited by Tokay444; 06-25-2011 at 05:35 PM. Reason: MSF Database - Automerged Doublepost
Alpha (06-25-2011)
 Old 06-25-2011, 05:41 PM   #5
Burdoror's Avatar
Hmm, I could not find bolts and washers. Can you help me with proper links?
I don't need tools - Job will be done by Mazda service. I will import part from US because they are 50% cheaper than here
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 06-25-2011, 05:57 PM   #6
kmac's Avatar
Posts: 1,792   (View Stats)
Why not get the upgraded vvt?
The Following 3 Users Say Thank You to kmac For This Useful Post:
06Speed6 (06-25-2011), Alpha (06-25-2011), nighthawk358 (06-26-2011)
 Old 06-25-2011, 08:37 PM   #7
Alpha's Avatar
Posts: 3,711   (View Stats)
lol u mean the one that doesent work? its either JJ or alpha whos having all those problems and hes on like this 3rd one.
No, my DCR VVT works great! Just don't buy the Corksport LW Crank Pulley haha!
The welds cracked on the timing ring in two days and caused a ton of timing issues. Stock crank pulley FTW until someone designs a good LW version!
kmac (06-26-2011)
 Old 06-27-2011, 07:32 PM   #8
Alpha, Is Kelly here at Corksport working with you on the pulley?
Derrick
CorkSport is online now   Reply With Quote
 Old 06-27-2011, 07:38 PM   #9
Alpha's Avatar
Derrick
Yes she is, thanks. Been super cool thus far so hopefully we can get everything straightened out.
These really need to be redesigned to hold up under our driving conditions. I have some great ideas if you guye are interested?
 Old 06-27-2011, 08:04 PM   #10
These really nees to be redesigned to hold up under driving conditions. I have some great ideas if you guye are interested.
Send your ideas on over via email.
Thanks
Derrick
 Old 06-25-2011, 06:09 PM   #11
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
You dont need the valve cover gasket either unles you tore it or something. The tensioner and guides most likely do not absolutely need to be replaced unless you have alot of miles/km.
The cam sprocket bolts are :
LF1712428 x2
The cam friction washers are:
L3K912429 x2
Timing chain tensioner is:
L3K912500A x1
Timing chain guide is:
L3K912671 x1
L3K912614 x1
2006 Mazdaspeed 6
The Following 6 Users Say Thank You to 06Speed6 For This Useful Post:
Alpha (06-25-2011), BobtailedSnail (03-11-2013), kmac (06-26-2011), RichieRichness (06-27-2011), superskaterxes (06-25-2011), the_caruch (06-27-2011)
 Old 06-26-2011, 01:41 AM   #12
Burdoror's Avatar
LF1712428 x2
L3K912429 x2
L3K912500A x1
L3K912671 x1
L3K912614 x1
I have almost 100k miles on it. Rattling and ticking started to be quite annoying.
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 06-25-2011, 06:19 PM   #13
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
im gona edit the title for better future reference, great thread thanks 06
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (06-26-2011), acidbbg (06-26-2011), kmac (06-26-2011), RichieRichness (06-27-2011), the_caruch (06-27-2011)
 Old 06-26-2011, 08:34 AM   #14
Speeeeeed
06Speed6's Avatar
If you have that many miles, I would replace all of the parts I listed. I also recommend the DCR VVT, it is alot cheaper than having someone replace it twice.
2006 Mazdaspeed 6
Alpha (06-26-2011)
 Old 06-30-2011, 01:30 AM   #15
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
Is DCR more reliable than the OEM VVT actuator? I had my VVT mechanism completely changed 12k miles ago, but recently it started ticking again. Wtf ??
Are there any clues of changing the timing mechanism except for assembling everything just the way it was working? Or are there any installation tricks with tensioners etc?
Thanks in advance.
paveltol is offline   Reply With Quote
The Following User Says Thank You to paveltol For This Useful Post:
Burdoror (06-30-2011)
 Old 06-26-2011, 10:07 AM   #16
Burdoror's Avatar
What is the reason of buying aftermarket vvt actuator?
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 06-26-2011, 10:48 AM   #17
Tokay444's Avatar
Groans: 793
Better materials.
Demodded.
The Seals
 Old 06-26-2011, 11:20 AM   #18
kmac's Avatar
So it doesn't break again.
 Old 06-27-2011, 08:31 AM   #19
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Thanks for the info.
 Old 08-02-2011, 10:55 AM   #20
JAGspeed6's Avatar
Posts: 138   (View Stats)
JAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud of
Groaned at 20 Times in 6 Posts
Okay so I have had my speed 6 for three weeks and its ticking kinda bad. i took it to the dealership and they told me that it was the vvt and all the other stuff. they also told me that it would be $1100 to fix it and i do not want to pay that. Is this a job I could probably do myself?
JAGspeed6 is offline   Reply With Quote
 Old 08-02-2011, 03:00 PM   #21
Burdoror's Avatar
If you are asking if VVT replacing is job to do by your self... it means you have no idea how tough job it is. 1100$ for parts+job (around 6 hours) is not so bad price.
You can always buy parts on mazdaparts (whole VVT around 330$) and ask Mazda dealer to replace it. I think this will be definitely cheaper option.
If you have somebody who knows how to change VVT in our DISI engine - buy required tools: Cam Alignment Tool and Top Dead Center Peg (~200$).
Remember to correct align the Camshaft position sensor.
It looks that mine is wrong. Well - It is setup according to Mazda Service Manual (check this page)and Ignition Timing (on idle) is setup to 10', however I fell I lost some power/torque now.
I compared it with my buddy And he has 13' at idle. I heard that this is kind of "bug" in the manual. I have to fix some other things and then I will be sure if VVT is a right part to complain.
After changing my VVT I realized also that fuel consumption grows by 2l/100km
BTW guys, what do you think about my situation and Camshaft position sensor alignment? Should I change it anyway?
Look on it (comparing my new vvt installation and my buddy's old one):
ME
RPM Ignition Timing
680 11
1000 28
1500 37
2000 41.5
Buddy's
RPM Ignition Timing
680 12-13
1000 36.5
1500 45.5
2000 46.5-47.5
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 08-03-2011, 02:04 PM   #22
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
i build my entire motor up 3 times and i still DO NOT want to touch my damn VVT retiming motor is a huge responsibility and to pin it on the dealer by paying is a very good idea especially if your asking the questions it means your not ready!
 Old 08-02-2011, 06:35 PM   #23
Our cx7 is getting it done at the dealer right now. Read enough here on it to know it's worth $600 for someone, especially the dealer, to handle. Way out of my league, and I've worked on cars for 25 years.
 Old 08-03-2011, 12:17 PM   #24
JAGspeed6's Avatar
Alright thanks for your help Burdoror. I may just take it to the dealership
 Old 08-03-2011, 01:06 PM   #25
Speeeeeed
06Speed6's Avatar
@Burdoror Ignition timing is based off of the crank position sensor, not the camshaft phase sensor. Also compairing spark timing between cars at various rpms is near impossible, in the ECU spark timing is based off of rpm and load, but that table is then modified by the ign open/closed loop tables, the ign retard knock tables, ign high/low BAT tables, ign overload tables, and some others.
2006 Mazdaspeed 6
 Old 08-03-2011, 01:24 PM   #26
Burdoror's Avatar
Sorry, I know how to call it in polish - I was guessing English meaning Thanks for clarifying
These values were made on neutral gear - so no there were no loads at all.
Lets look into idle table only. The crank position sensor is configuring during VVT installation. As Mazda service owner says - Approx. BTDC 10 degree. And what I heard - this is wrong and default is setup to 13 degrees. Can you just check yours ignition time on idle? I'm just curious if I am right
Here is the Service manual tutorial for incpection of:
IGNITION TIMING INSPECTION
A6E390802000W01
Note
• Ignition timing is not adjustable.
• Ignition timing verification requires WDS or equivalent.
1. Turn off the electrical loads.
2. Warm up the engine as follows.
(1) Start the engine.
(2) Maintain the engine speed at approx. 3,000 rpm until the cooling fans start to operate.
(3) Release the accelerator pedal.
(4) Wait until the cooling fans stop.
3. Verify that the ignition timing (WDS: SPARKADV PID) is within the specification using WDS or equivalent.
Ignition timing
4. Verify that ingestion timing advances when the engine speed increases gradually.
IDLE SPEED INSPECTION
A6E390802000W02
Note
3. Verify that the idle speed (WDS: RPM PID) is within the specification using WDS or equivalent.
Idle speed (L8 engine model)
Idle speed (LF engine MTX model)
ENGINE TUNE-UP
Condition Engine speed (rpm)*1
No load 650—750
Electrical loads*2 ON 650—750
P/S ON 700—800
A/C ON and refrigerant
pressure switch (middle) OFF 700—800
pressure switch (middle) ON 700—800
Second thing is my fuel consuption whci grows just after VVT replacement by 1-2l/100km.
I'm curious what was the impact of VVT installation
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 08-03-2011, 02:08 PM   #27
I just picked mine up, and there was $400 in parts, $800 in labor. According to the tech, it is his least favorite thing to do on our cars, as it is cramped, and so much can possibly go wrong if not done right.
Yeah, I might walk funny for a while, but my motor is running.
 Old 08-03-2011, 02:18 PM   #28
Burdoror's Avatar
can you grab some logs on idle, 1000 and 1500 rpm (all on neutral gear). I'm wondering how looks your ignition timing.
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 08-03-2011, 02:33 PM   #29
mail me a dashhawk and I will. (CX-7).
Worried about your VVT going out? Do what the dealer would do to check.
TSB: 0101011 - 02/23/2011 - VVT Noise At Engine Start Up | Technical Service Bulletins
Tokay444 (08-03-2011)
 Old 08-03-2011, 10:55 PM   #30
Burdoror's Avatar
Raider - I'm sorry but it is impossible. Postage fee are not worth of it . From CZ to US cost will be around 50$ in one way
BTW, was there any Bulletin regarding bugs in the service manual?
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 08-04-2011, 03:12 AM   #31
Ha. But I can ship it for $10 back.
Bugs in the service manual? Like insects? Not sure what you mean.
 Old 08-04-2011, 03:13 AM   #32
Burdoror's Avatar
NO Bugs is a common name for mistakes, errors, etc...
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 08-04-2011, 03:22 AM   #33
That is what I thought. I think finishlineperformance.com has them posted
 Old 08-04-2011, 03:30 AM   #34
Burdoror's Avatar
WOW. Thanks a lot!
Here is the direct link Mazda3 Bulletins
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 08-05-2011, 01:37 AM   #35
Burdoror's Avatar
Guys,
Can anybody do the logs form me? It will take 5 minutes of your time You even don need to go anywhere - test has to be done on neutral gear
Thanks a lot!
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 08-05-2011, 06:18 PM   #36
Burdoror's Avatar
Damn. I had just done tests on WOT. I can't go higher than 0.94 BAR... Before VVT replacement I had 1.22 BAR on WOT (at ~4500rpm and slipping clutch - new clutch just arrived to... custom office : vmad : )
Question - does the clutch have any influence on turbo charge?
BTW - Clutch was slipping before my VVT was changed - I notified my power loss after this replacement.
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 12-05-2012, 07:40 PM   #37
chuckms6's Avatar
Posts: 1,618   (View Stats)
@Raider; @superskaterxes; @Tokay444; maybe this should be a sticky/ knowledge base item? lots of good info here that i had to search for a couple times to find
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 12-06-2012, 06:34 AM   #38
It's an old thread, and I would prefer to see one with everything listed in post #1 with part #'s. I want to say there is a tube of gasket material too. Make a new thread with everything listed, and I will stick that.
 Old 12-06-2012, 07:39 AM   #39
chuckms6's Avatar
Will do later. I have everything in a cart, just have to screen shot it when I get back to my computer.
Tapatalking
Federal-Mogul recalls replacement parts in some Chryslers Haltech Automotive News 0 12-28-2010 10:10 PM
How To Find Car Replacement Parts Haltech Automotive News 0 07-29-2010 10:50 AM
Ford: Aftermarket replacement parts can be inferior, possible safety hazards Haltech Automotive News 0 07-23-2010 08:40 AM
Parts Imitating Life: Sculptor uses car parts to make cars... and animals Haltech Automotive News 0 11-13-2009 11:40 AM
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 02:30 PM
Page generated in 0.59721 seconds with 33 queries
