Notices
 Old 09-17-2012, 03:42 PM   #1
Will fuck up ur day
Chimmike's Avatar
Posts: 6,007   (View Stats)
Groans: 434
Default Rock Auto - What doesn't fit??
Let this be the beginning.
I have 2 so far that I need to add. Potentially a third.
07 MS3
The original Genpoo Hater
TiGraySpeed6 (09-17-2012)
 Old 09-17-2012, 03:57 PM   #2
cnyms6's Avatar
Posts: 55   (View Stats)
cnyms6 has a brilliant futurecnyms6 has a brilliant futurecnyms6 has a brilliant futurecnyms6 has a brilliant futurecnyms6 has a brilliant futurecnyms6 has a brilliant futurecnyms6 has a brilliant futurecnyms6 has a brilliant futurecnyms6 has a brilliant futurecnyms6 has a brilliant futurecnyms6 has a brilliant future
AC compressor didn't fit
cnyms6 is offline   Reply With Quote
 Old 09-17-2012, 04:03 PM   #3
dale_gribble's Avatar
Posts: 3,262   (View Stats)
I have found a few times where parts listed for my Speed6 is wrong on Rock Auto because for some dumb reason, a lot of parts were listed to work with 2.3L motor and Mazdaspeed MZR even though this isn't right. I mean, the parts sort of fit, but they are different enough to be a PITA; In other words, the part will fit and not leave you stranded, but its just different enough to cause the OCD in you to flare up. A lot of part manufacturers must have assumed the 2.3L and MZR are basically one in the same and didn't do a lot of research.
Specifically for me, the thermostat and radiator. The thermostat on the 2.3L has a longer neck, by about 1.5" then my MS6. The MS6 neck is shorter to clear the power steering hose. The longer neck does fit and will work, but the power steering hose has to be scooted over a bit. The supposed MS6 drop in radiator from them has different lower mounts and the auto trans cooler hookups. I massaged it to work because I was in a pinch, but I will eventually get my stock radiator repaired and reinstalled.
 Old 09-17-2012, 04:24 PM   #4
LilGator's Avatar
Posts: 136   (View Stats)
LilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond repute
Groaned at 6 Times in 3 Posts
Blower motor for MS6 doesn't fit. They list it under "2.3L L4 Turbocharged", but it's definitely not a match.
2007 Speed6 GT - LPM
RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP
SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV
MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports
E85 Stratified
LilGator is offline   Reply With Quote
 Old 09-17-2012, 09:24 PM   #5
Lowspeed
TiGraySpeed6's Avatar
Posts: 3,473   (View Stats)
I'll see if I can look up some of the bad part numbers tomorrow, but last I looked, only one passenger side front cv axle, out of 6 different axles, both pass & drivers side, actually fits the speed6.
I also have the specs, dimensions & such that I'll add to feed the search engines and help folks be able to identify speed6 axles from 2.3 na axles which are much smaller
Mazdaspeed6 GT #3476 TiGray slicktop
HTP 3.5"; BNRs3v1; MAC EBCS; CXR fmic; 3 BAR; GFB Respons; VTCS Delete; JBR TIG;
XSPower ExMani; M2 DP; Custom Magnaflow exhaust; Luk Clutch & Fidanza FW;
KMD; CPE SafeSeals; MD OCC; K2 Primary & JBR Secondary EGR Delete; other shit...
Bilstein & Mazdaspeed springs; SPC's; WL RSB; Steeda F&R Adj End Links;
CPe xFlex RMM; Corksport TMM Inserts; Dread & Jugg diff mounts; EBC Yellow's &
Carbotech XP8's; Racing Brake SS brake & clutch lines; ATE SuperBlue; other shit
 Old 09-17-2012, 09:33 PM   #6
jack_hammer's Avatar
Posts: 5,754   (View Stats)
Groans: 520
Groaned at 116 Times in 71 Posts
i bought two rear ABS sensors. they both fit. in fact, they say "fomoco" on them. however, i think one is broken. i'm still working on determining that, though...
it's fun to do bad things
 Old 09-17-2012, 09:35 PM   #7
Groaned at 320 Times in 235 Posts
Lol someone in SoCal Nator was just pointing to me about this $63 axle they wanted to buy from them.. I hope they see this thread.
Haltech is online now   Reply With Quote
 Old 09-17-2012, 09:43 PM   #8
theschrum's Avatar
Posts: 1,004   (View Stats)
Groans: 30
Rock auto is an awesome site for parts, but I always reference the part number to a regular 2.3l before I purchase from them though. I wouldn't be suprised if 20% of the parts listed for our cars didn't fit.
08 Speed 3|SOLD
 Old 09-18-2012, 01:57 PM   #9
Lowspeed
Rock Auto- MS6 axle listing has been improved, but still not perfect. At least it's better than it was. Only a single CV appears to be incorrect.
I can guarantee that Cardone # 608190 is correct, that one was in my car for a couple of months till the rebuild failed- just lucky there. They're usually not bad. It's reasonably safe to "assume" the rear axles would be right, the application shows '06 & '07 only, and hey, they're rear axles....
The first one in the list is certainly incorrect (MZ8338A), and is used as an example of what to watch out for in the pics below.
The entire list- much shorter than it used to be:
See anything amiss with this application list?
Here's a good application list:
Mazdaspeed6 Front CV Axle specs compared to the N/A 2.3 CV axles:
Dimensions:
The Speed6 axles have a much larger nut, 35mm -vs- 32mm, on the splines/hub side. This is the one I've been using a 36mm socket on, by mistake apparently.
This nut size can also be referred to as M24-1.5 on the Speed6, and as M22-1.5 for the smaller NA axle.
Spline section diameter on the speed6 is 32.5mm, and is only 29mm on the NA axle.
Passenger side is also longer for the Normal 6 2.3, since there is no PTO to deal with
- top is the Speed6, bottom is normal 6 passenger side
 Old 09-18-2012, 02:10 PM   #10
SleeperHatch's Avatar
Posts: 3,105   (View Stats)
Yes I see this thread lol. I ended up just buying a OEM axel
GTX3071 // 3.5" Intake // CP-E Exhaust Manifold // EMUSA 38mm Wastegate // CX Racing FMIC // Treadstone TR8 Core // KMD Internals // Corksport OCC // Corksport Shift Plate // Sonic Tuning Coilovers // CNT Catted Downpipe // Corksport Catback // PTP Injector Seals // SPC Camber Arms // 70d Transmission Mount // CP-E Stage 2 RMM // Devils Own Stage 2 (D07) Nozzle // 30% E85 Mix
 Old 12-28-2012, 12:31 AM   #11
DashingDomin8r's Avatar
Posts: 21   (View Stats)
DashingDomin8r is just really niceDashingDomin8r is just really niceDashingDomin8r is just really niceDashingDomin8r is just really niceDashingDomin8r is just really nice
Exedy Clutch kit doesnt fit.
DashingDomin8r is offline   Reply With Quote
 Old 03-29-2013, 02:17 PM   #12
lopezsr20's Avatar
Posts: 71   (View Stats)
lopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud of
Does anyone know if the ball joint moog MDBJ4869 they offer for the speed fits?
Or the DEEZA Part # MDH201—
2007 Mazdaspeed GT
Autotech Internals :Mazdaspeed cold air intake v2 : Corksport TIP : Cobb Accessport : Turbo XS Hybrid BOV cuz pssshhhhhhhhhhhh : Corksport RMM :Corksport Testpipe: JBR Shifter Bushings: Homedepot special OCC : Koni Yellows : Cobb rear sway bar : Resonator delete : Rallyarmor Mudflaps cuz rally car
lopezsr20 is offline   Reply With Quote
 Old 04-06-2013, 07:53 PM   #13
MazdaSpeedster's Avatar
Posts: 84   (View Stats)
MazdaSpeedster is a jewel in the roughMazdaSpeedster is a jewel in the roughMazdaSpeedster is a jewel in the roughMazdaSpeedster is a jewel in the rough
I ordered a cabin air filter last week for my speed 6. I received it today and it did not fit.
MazdaSpeedster is offline   Reply With Quote
 Old 04-06-2013, 08:47 PM   #14
Lowspeed
What's the part number for the filter which doesn't fit?
 Old 05-22-2013, 01:18 PM   #15
rabble rabble
802MS3's Avatar
Posts: 4,958   (View Stats)
Groans: 198
Groaned at 102 Times in 55 Posts
Strut mount kit for the 3 -
Mevotech MS76201 does not come with the strut boot and bump stop, even though it shows both of those in the pictures.
More Information for MEVOTECH MS76201
Details
'08 CWP MS3 w/ ported ATP 3071r
 Old 07-31-2013, 08:15 AM   #16
spd6demon's Avatar
Posts: 163   (View Stats)
spd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the world
The shaft pivot seal doesn't fit, too big in diameter. I just re-used the old seal but took the spring ring (or whatever its called) out of the new seal and put it in the old one. Been about two weeks and no leaks
06 MS6 GT // PTE 6266 GEN2 // Kozmic 6th Port Inj. 1200cc // Weisco Pistons (0.020 over) // Manley H+ Rods // JDM Sport EM // Tial 38mm EWG // SP63 Keyed & Polished Crank & Sprockets // 4" WPI // P&P IM // Cobb AP // Custom DP
CP-E Safe Seals // CP-E Rear Diff Mount // Bosch 3.5 BAR // Sure ShortCut // TWM Shift Knob // AutoTech HPFP internals // H&R Springs // DRAG DR-34 +35mm // CS2 Front Lip // CX Racing Air to Water IC // Custom Matt Damond Dual OCC
HTP Small Batt Tray // SP63 EBCS // HKS BOV // Kozmic Oil Feed Line // JBR EGR block off // JBR BSD // JBR Counter-weight // NGK // DW 65c ITFP // JBR PMM // JBR SSB // SU RMM // Corksport TMM Insert // FREEK Tune in progress
305/364 (K04) // 367/387 (2871r)
454/417 (PTE6262 R.I.P)
spd6demon is offline   Reply With Quote
 Old 07-31-2013, 08:29 AM   #17
Lowspeed
Can you post the part number you ordered from RA, or any other details?
Knowing RA, they have some that do fit & some that don't so any details you can provide on what didn't work would be great!
 Old 07-31-2013, 08:50 AM   #18
spd6demon's Avatar
Part # 221620
There was only one shift shaft seal that came up for the 06' ms6. The seal didnt fit no matter how hard I tried. Seal is slightly too big for housing. Also the new seal wasnt as thick as OEM
The Following User Says Thank You to spd6demon For This Useful Post:
TiGraySpeed6 (07-31-2013)
 Old 08-01-2013, 01:18 PM   #19
Mandinca's Avatar
Posts: 1,557   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
Groaned at 7 Times in 5 Posts
Originally Posted by spd6demon View Post
Part # 221620
For what the OEM costs why didn't you go to Mazda ?
The radiator doesn't fit. The brackets for the fans are all wrong and one of the hose fittings on top is different. It would be nice if it did fit since RA's is $119 and the only other place I could find one was OEM at $350
I also bought a PCV valve from them and the jury is still out on its functionality.
Last edited by Mandinca; 08-01-2013 at 01:18 PM. Reason: MSF Database - Automerged Doublepost
Mandinca is offline   Reply With Quote
 Old 08-01-2013, 01:23 PM   #20
soul.survivor's Avatar
Posts: 332   (View Stats)
soul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the world
Fel-pro donut exhaust gasket fits but isn't thick enough to make a seal.
2008 CBM MS3
CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune
soul.survivor is offline   Reply With Quote
 Old 08-01-2013, 06:30 PM   #21
spd6demon's Avatar
My friend actually ordered it for me. Didn't think rock auto's would be different. Guessed wrong lol.
 Old 01-23-2014, 06:53 AM   #22
Rcimp's Avatar
Posts: 107   (View Stats)
Rcimp has a brilliant futureRcimp has a brilliant futureRcimp has a brilliant futureRcimp has a brilliant futureRcimp has a brilliant futureRcimp has a brilliant futureRcimp has a brilliant futureRcimp has a brilliant futureRcimp has a brilliant futureRcimp has a brilliant futureRcimp has a brilliant future
I ordered the LUK clutch kit and it fit fine, I also ordered two axles that fit fine to. I ordered two front bearings with hubs and they did not fit.
Bearing with Hub: PRECISION AUTOMOTIVE 513211 - Did not fit.
Clutch Kit: LUK 10064 - Fit
Axle: EMPI 803952 - Fit
Axle: EMPI 803957 - Fit
Clutch Slave Cyl: WAGNER SC143568 - Fit
07 Cosmic Blue Speed 3,
Cobb AP
BEGI SRI
CNT Catted Downpipe
Forge BOV
CorkSport Turbo Inlet Pipe / Silicone BPH / Boost Tubes / Dry Flow Air Filter
Fidanza Aluminum Flywheel
CPE Xflex Stage 2 Driver Side MM
CPE Xflex Stafge 2 Rear MM
AWR Passenger Mount 88 Duro
Power Slot Rotors
Last edited by Rcimp; 01-23-2014 at 06:53 AM. Reason: MSF Database - Automerged Doublepost
Rcimp is offline   Reply With Quote
The Following 2 Users Say Thank You to Rcimp For This Useful Post:
madspd6 (03-02-2014), stockms3 (08-13-2014)
 Old 03-02-2014, 01:47 AM   #23
season_of_ages's Avatar
Posts: 160   (View Stats)
season_of_ages has a brilliant futureseason_of_ages has a brilliant futureseason_of_ages has a brilliant futureseason_of_ages has a brilliant futureseason_of_ages has a brilliant futureseason_of_ages has a brilliant futureseason_of_ages has a brilliant futureseason_of_ages has a brilliant futureseason_of_ages has a brilliant futureseason_of_ages has a brilliant futureseason_of_ages has a brilliant future
Radiator was mentioned. Of course, this will include the drain plug. Thread is too small to fit oem radiator
Sent from my SM-N900T using Tapatalk
season_of_ages is offline   Reply With Quote
 Old 03-02-2014, 02:41 AM   #24
madspd6's Avatar
Posts: 966   (View Stats)
madspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the world
The one EMPI Drivers side front axle #803967 for the speed 6 fits fine too as i have it.
I also called EMPI and about 5 months ago they were working on tooling for the passanger side, guy said new tooling takes between 5-6 months to perfect.
Velocity Red Mica 06 Speed6 (ricer) #834
madspd6 is offline   Reply With Quote
 Old 09-24-2014, 06:25 PM   #25
arias valentia's Avatar
Posts: 13   (View Stats)
arias valentia is an unknown quantity at this point
I got the engine gasket set, 4 exhaust valves and a pcv valve from them and I havnt had any issues except a minor seaping around the valve cover that I attribute more to the some rusty (+1 missing/snapped) cover bolts.
So far I guess i was lucky
Anyone know about the rack and pinion boots?
arias valentia is offline   Reply With Quote
 Old 09-29-2014, 08:32 AM   #26
maddocx240's Avatar
Posts: 610   (View Stats)
Has anyone ever tried the oxygen sensors for the speed 6? I might need one and wanted to know if they are the right part.
 Old 10-29-2014, 07:22 PM   #27
twiztdspeed's Avatar
Posts: 11   (View Stats)
twiztdspeed will become famous soon enough
Ngk 02 sensors should be ok but the dorman intake manifold runner control or ebcs has the wrong male pluge
twiztdspeed is offline   Reply With Quote
 Old 10-29-2014, 07:34 PM   #28
Turbo_Steve's Avatar
Posts: 444   (View Stats)
The ngk/ntk o2 sensor part number 24357 worked perfectly for my 08 speed 3.
They list part number 24354 for the speed 6. I am not sure if the connectors are different between the 2 cars but this is probably why it has a different part number. If it is pictured with the heat shield it should be the one you want.
The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, e4p SS + jbr ssp, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve.
Soon to come.
Manley H beam Rods, Cp-e Magnum DI Stage 2 Pistons, Td06sl2 20g Bolt on turbo, EWG, ACT Streetlite fw/6 puck sprung combo.
The Following User Says Thank You to Turbo_Steve For This Useful Post:
cshunter (10-29-2014)
Rock vs Fog light SWAY Gen2 MS3 General Discussion 41 09-10-2011 03:11 PM
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
©Copyright 2008 ; 2014 Cymru Internet Services LLC | FYHN™ Autosports HQ
Page generated in 0.43419 seconds with 42 queries
