 Old 10-29-2015, 03:44 PM   #1
Zer0x90's Avatar
Posts: 9   (View Stats)
Zer0x90 will become famous soon enoughZer0x90 will become famous soon enough
Default Rod Knock Example
Just thought I would throw these up here for knowledge and training purposes.
This is what a rod knock in a MZR DISI long block sounds like.
Engine Right Side
Engine Left Side
Intake with some Throttle
Its not quite ZZB, but it could turn into a "walking home" situation very quickly.
FWIW, this is the result of redline RPMS, plus low oil, plus a hard left hand turn. It just ran dry and developed the knock.
Zer0x90 is offline   Reply With Quote
The Following User Says Thank You to Zer0x90 For This Useful Post:
kolosok17 (10-29-2015)
 Old 10-29-2015, 03:55 PM   #2
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Originally Posted by Zer0x90 View Post
plus low oil.
Found your main problem. In fact, this was really your only problem.
Blue Pu.
macdiesel (10-29-2015)
 Old 10-29-2015, 03:59 PM   #3
Zer0x90's Avatar
Probably. It wasnt low, but low enough to loose pickup obviously. The biggest contributing factor was probably neglect.
It was elk hunting season, so I just wasnt driving the car as much as I should, I was driving my old 4x4 pickup instead.
 Old 10-29-2015, 04:14 PM   #4
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
Groaned at 8 Times in 3 Posts
Even better, you can unplug a coil at a time to narrow it down to which cylinder it is.
Balance test.
Plug and play knock sensor listening harness. Is it really knock? Turbo_Steve MazdaSpeed 3/6 - ECU Computer Tuning 37 10-07-2019 03:50 PM
Knock Knock Knockin sallyspeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 08-02-2014 04:54 PM
Knock Knock Knock..Whose There? (<===total noob) thomas_cory2000 MazdaSpeed 3/6 - ECU Computer Tuning 158 06-12-2014 11:57 PM
Engine knock low speeds/low gear - false knock? Jra2011speed3 2010 MS3 - ECU Computer Tuning 5 12-13-2013 05:17 PM
Page generated in 0.26890 seconds with 22 queries
