 Old 12-28-2017, 07:39 AM   #1
sho
sho's Avatar
Posts: 537   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
Having a hard time starting the car after filling gas is purge valve failure. Easy and cheap fix.
2007 ms3 GT, sunlight silver
Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM.
FD wheels
E48 mix
Tuned by Realgib3
Purchased 8/3/12 - 25,314 miles on chassis and motor
6/21/18- 234,700 miles on chassis, 73,200 on built motor
sho is offline   Reply With Quote
Rough idle/Vacuum issues ThomasSpeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 06-05-2017 05:48 PM
Rough Idle, Insanely Rich Mazduhspeed6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 12-03-2016 03:03 PM
P2177 and p300 rough idle and possible vacuum leak vanya Mazdaspeed3/6 General Discussion 4 09-12-2016 08:55 AM
Rough/Rich idle after Internals install Bingo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 06-05-2016 05:16 PM
Rich AFR, Hesitation, Rough Idle, Sputtering Exhaust BrandonRKD MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 09-29-2014 12:28 PM
Page generated in 0.23715 seconds with 21 queries
