![]() Join Date: Mar 2012 Location: the 101 and the 118
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score I've tried searching the forums for an answer, but I haven't seen one to all these problems. My poor MS3 has been degrading these last 10k miles, I've got about 150k on her and i think her time could be done. About 15k miles ago I got a checkup done and the shop said everything looked great and that she was doing good on compression but the spark plugs needed changing. Ever since then things have just been going down hill.. Currently experiencing: 1) rough idle. When idling the car feels like its about to stall, then it pumps fuel back in, then it almost stalls, then pumps fuel back in. It's quite annoying. (replaced MAF but that didn't help 2) Doesn't like starting after fuel up. This is by far the weirdest. After you fill the car all the way up it has to crank for a few seconds and then you have to feather the gas pedal to get it to turn on. After you get her running, it doesn't have a problem starting again. She also has a hard time starting in really cold weather (freezing) 3) Running rich: car blows more than normal amounts of black smoke out when idling. I noticed this when i started to fill her up while the car was running. 4) Vacuum leak: I'm getting a generic vacuum leak code, can't find where it is Any ideas? |
![]() Join Date: Jan 2011 Location: Vancouver BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
| Not Ranked : 0 score Did you ever replace the plugs/coil packs? Most of what you describe is AFR related and that includes the spark. What kind of shop did you go to? As for your vacuum leak, I found my fuel trims were off because both the TIP side and hot side IC hose at the turbo were loose. That was after the dealership was checking for a dye to see if my oil loss was at the turbo. I'd take a guess your leak is around the cold side intake manifold tubes or rear/hot side inter cooler hose.
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters Last edited by Marcus; 12-14-2017 at 08:11 PM. |
| Not Ranked : 0 score And was there a good reason to fill up the car while it was running?
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters |
| Not Ranked : 0 score Also dont cheap out on regular pump gas. Your turbo needs better.
![]() Join Date: Feb 2017 Location: Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
| Not Ranked : 0 score Some things that may help: 1) When replacing the MAF sensor on these cars ONLY replace with a genuine OEM sensor. For some reason these cars never seem to run right without the OEM part. 2) It seems to me like your problem is a combination of a vacuum leak and some kind of EVAP system issue. Most likely your purge valve is clogged or stuck.
__________________ 2007 Sunlight Silver Mazdaspeed3 Engine: \\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\ Tuning: \\Cobb AP V3\\ Freektune Custom Tune \\ Suspension/Brakes: \\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\ |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score purge valve
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() Join Date: Oct 2016 Location: Spokane, WA
Rep Power: 0 ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score I'm having a similar problem with my MS6 but the idle dips between 500rpm-1500rpm.. Having a possibility of stalling while at a red light so i have to hold the gas up to 1200rpm in order for the guy not to stall out... On top of that, i quickly noticed a dramatic drop in power that the engine is supposed to give. No, i dont think it is a boost leak because i have checked all hoses and clamps for signs of looseness.. And i dont currently have an Accessport yet either. i have done some more of my own research about this kind of problem and i have either gotten the idea that it is possibly an EGR Valve or an Idle Control Valve as far as the idling is concerned but still havent got to finding out why most of my power is lost as well... Any Ideas? i'm desperate as much as the next guy so any advice would be very helpful.. Would you guys still say this is a purge valve Problem? if so, is there a way of cleaning it or should i buy a new one...? Last edited by IvansMZR; 12-26-2017 at 02:50 AM. Reason: corrections |
![]() Join Date: May 2016 Location: Sarastoa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score I'm surprised no one has asked yet, but OP, do you have an Access Point so you can give us data logs at idle or while driving? May help shed some light.
__________________ 2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub Other Mods: FIAMM 72112 Low Note Horn alongside stock Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Find and fix the vacuum leak first. What is this "generic" code number?
How does it actually run? If you're idles that spread out, I'd check everything including the little vacuum tube from the IM to the the intake but its not the big recirc tube that goes into your turbo inlet pipe. I cant describe it right. Since you say lack of power, I'll just say its your high pressure fuel pump. Probably and hopefully way off but you'll need to replace that eventually. Whats your mileage at and mods, if any?
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters | |
| The Following User Says Thank You to Marcus For This Useful Post: | IvansMZR (12-27-2017) |
| Not Ranked : 0 score The only mod on it is a MazdaSpeed Cold Air Intake, and mileage wise, it's at 99,500... And what do you mean by IM Tube? I have just today bought a new Purge Valve for my MS6 and a buddy that works at a local Autoparts store has told me, his car idled the exact same way until he switched out his purge valve. He also owns an MZR but in an MS3. |
| Not Ranked : 0 score I also noticed... When i start my MS6 on a cold start (If it doesnt die), it idles normally but stays on 900-1,000 Rpms up until i actually start driving it, the guy starts dipping on stop signs and Street lights. |
Based on your description, I'd guess unmetered air is getting in, so I'd check for any leaks in your intake or TIP. Or your MAF is dirty.
__________________ 2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub Other Mods: FIAMM 72112 Low Note Horn alongside stock Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks | |
| The Following User Says Thank You to Carskick For This Useful Post: | IvansMZR (12-28-2017) |
| Not Ranked : 0 score Find that leak. If it is post-maf, you are sucking in unmetered air. That is also unfiltered air. Unfiltered air contains dust and particles that are abrasive and will quickly damage your engine.
| The Following User Says Thank You to MSMS3 For This Useful Post: | IvansMZR (12-28-2017) |
![]() Join Date: Jul 2012 Location: Akron, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 758
| Not Ranked : 0 score Having a hard time starting the car after filling gas is purge valve failure. Easy and cheap fix.
__________________ 2007 ms3 GT, sunlight silver Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM. FD wheels E48 mix Tuned by Realgib3 Purchased 8/3/12 - 25,314 miles on chassis and motor 6/21/18- 234,700 miles on chassis, 73,200 on built motor |
| Rough idle/Vacuum issues | ThomasSpeed3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 28 | 06-05-2017 05:48 PM |
| Rough Idle, Insanely Rich | Mazduhspeed6 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 23 | 12-03-2016 03:03 PM |
| P2177 and p300 rough idle and possible vacuum leak | vanya | Mazdaspeed3/6 General Discussion | 4 | 09-12-2016 08:55 AM |
| Rough/Rich idle after Internals install | Bingo | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 24 | 06-05-2016 05:16 PM |
| Rich AFR, Hesitation, Rough Idle, Sputtering Exhaust | BrandonRKD | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 20 | 09-29-2014 12:28 PM |
