Like Tree6Likes
  • 1 Post By MSMS3
  • 1 Post By Db09ms3
  • 1 Post By monkey.bones.007
  • 2 Post By Tomas
 Old 01-25-2019, 03:38 PM   #1
b4n30n3's Avatar
Posts: 108   (View Stats)
b4n30n3 is infamous around these partsb4n30n3 is infamous around these partsb4n30n3 is infamous around these partsb4n30n3 is infamous around these partsb4n30n3 is infamous around these partsb4n30n3 is infamous around these partsb4n30n3 is infamous around these parts
Groaned at 312 Times in 89 Posts
Default running a dp without fuel pump internals?
Remember when the fuel pump internals were not released yet but people had downpipes installed? How bad for the motor would it be to run a dp without the fuel pump internals? No other modifications either just the downpipe.
ZOOM-ZOOM
b4n30n3 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to b4n30n3 For This Un-useful Post:
djern (01-26-2019), MSMS3 (01-25-2019), Vansquish (01-26-2019)
 Old 01-25-2019, 05:30 PM   #2
MSMS3's Avatar
Posts: 2,825   (View Stats)
Just no. Repeat, just no. You will get really nasty boost spikes well above the 22.5 psi capability of your MAP sensor. I tried it, and fortunately was monitoring. I caught it right away before any damage. You will also see fuel rail pressure under load drop below 1600, down as low as in the 1400 psi range, with you injectors pulse width increasing the spray to try to maintain safe AFR.
And, even with pump internals upgraded you will have those nasty spikes if you try to run a downpipe on stock tune. You need a compatible tune. The downpipe will raise boost under load to about 18 psi on a stock tune intended for 15 psi. The tune does not support boost that high.
It is a recipe for disaster. I was lucky.
It's also not a good choice for a first power mod. You need to ditch the stock highly restrictive airbox in favor of a good CAI or SRI intake, or the downpipe does little good. An engine is an air pump. Unless you in increase air flow on the intake side, a better flowing exhaust really doesn't do much. You can't push more out than you have coming in.
Do as you please, but . . . you have been warned. Actually warned twice. I told you the same thing in another thread on January 3, 2012 - seven years ago. Yes, seven years ago. Are you trolling, or just an idiot? I'm being kind. I'm primarily replying to warn others not to try this.
joemd likes this.
 Old 01-25-2019, 07:57 PM   #3
b4n30n3's Avatar
I was thinking about when people had downpipes before the fuel pump internals were on the market. I wonder if they blew up their engines.
ZOOM-ZOOM
The Following User Says NO Thank You to b4n30n3 For This Un-useful Post:
MSMS3 (01-26-2019)
 Old 01-25-2019, 10:16 PM   #4
b4n30n3's Avatar
Does the cobb stage2 ots map get rid of the boost spike?
ZOOM-ZOOM
 Old 01-26-2019, 12:03 AM   #5
thatguy0o0's Avatar
Posts: 148   (View Stats)
thatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond repute
I’m pretty sure that the Cobb ots2 map specifically says that you need an up graded HPFP. Actually I think the term they use is “cam driven fuel pump” same same though...just get the HPFP internals and be done with it. You are already spending money on the DP why not start with the HPFP if you know that it is a must?
2013 Speed3 w/ tech
Autotech HPFP
Cobb APV3
ETS TMIC
JBR 3.5in SRI
UR catless DP
Corksport TP
Corksport Hoodscoop
JBR RMM
Stratified e30 tune
Other Stuff:
1992 Jeep Cherokee 202,000 miles (salt/snow work horse)
2009 Toyota Rav 4 (wife has to drive something practical)
2012 Yamaha R1 Full Two Brothers exhaust & ECU flash
thatguy0o0 is offline   Reply With Quote
 Old 01-26-2019, 07:39 AM   #6
Db09ms3's Avatar
Posts: 536   (View Stats)
I dare you. In for part out afterwards.
thatguy0o0 likes this.
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
monkey.bones.007 (01-27-2019)
 Old 01-26-2019, 07:52 AM   #7
MSMS3's Avatar
Do you not know how to read? I almost blew up mine and would have were I not data logging. I've reported that in detail to you twice in two different threads seven years apart.
Look, we keep telling you not to do this. So, go ahead, go 3" catless dp on stock pump and tune. Then see what happens. It won't take long. You don't deserve to own your car, because you will not listen to reason or experience.
Cobb's stage 2 OTS tune will only be half of the fix. YOU MUST ALSO UPGRADE THE PUMP INTERNALS to run a 3" catless dp.
thatguy0o0 (01-26-2019)
 Old 01-26-2019, 03:40 PM   #8
b4n30n3's Avatar
I will get the fuel pump done then. But now another question can you start up the car and run it after upgrading the fuel pump internals on the stock tune? Like just to drive it out of the garage to the parking lot? Because if I take it to a mechanic to get the pump and exhaust done it won't have the ecu flashed.
ZOOM-ZOOM
The Following User Says Thank You to b4n30n3 For This Useful Post:
MSMS3 (01-26-2019)
 Old 01-26-2019, 04:56 PM   #9
MSMS3's Avatar
Yes, do it now. First. Do you ever read anything or do any research? The pump internals provide extra volume capacity when needed. On stock tune your ecu commands certain pressure and certain injector duration. The injectors only get what they need, what is commanded.
So, the upgraded pump works less hard on stock tune, but works fine. You can drive as long as you want. The extra capacity will be there to support your mods when added later. Do the pump first, even if you never upgrade the exhaust. You need it for the stage 2 tune, too.
There are probably hundreds of threads here already suggesting that the pump internal upgrade be done first before any other power mods. Heck, the stock pump is marginal to begin with. Your stock pump may already be worn enough after all these years that it may not be maintaining the minimum safe pressure for stock tune.
 Old 01-26-2019, 06:49 PM   #10
b4n30n3's Avatar
I was running 100% stock and the rear motor mount wore out and the engine was flapping around and it broke the exhaust. So currently I am driving around with loud exhaust. I fixed the motor mount myself with a cp-e stage1 65 durometer mount. It barely vibrates more than stock and the wheel hop is reduced significantly.
I didn't know if tuning was required for the fuel pump internals. I was assuming it was for no particular reason. That's good news that I can stick with the stock tune on the upgraded internals. That will make my life much easier.
So I was looking at the installation videos on the internet and it looks pretty easy so I might try to install the internals myself. But the first thing that happened was I can't figure out how to get the pcv fitting off. The pcv has some kind of lock fitting on it I can't get off of there.
ZOOM-ZOOM
 Old 01-27-2019, 06:33 PM   #11
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
The only place I've seen this level of awesome questions is the Special Olympics. Gold medal for you.
Sent from my SM-N960U using Tapatalk
danb likes this.
Db09ms3 (01-28-2019)
 Old 01-28-2019, 07:49 AM   #12
Police - Grammarhead
Vansquish's Avatar
Um...The PCV valve is underneath the intake manifold, and the PCV line is all of 6"-8" long. I'm not sure where you think your fuel pump is, but you're looking in the wrong place.
 Old 01-28-2019, 12:45 PM   #13
b4n30n3's Avatar
I guess it's called the breather tube not the pcv. It vents gas from the valve cover to the intake. On the valve cover side the fitting is green and on the intake side of the line the fitting is blue.
ZOOM-ZOOM
 Old 01-28-2019, 02:53 PM   #14
MoMS3's Avatar
Posts: 235   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
Go to corksport's website, look up their HPFP and go to the bottom of the page to their install instructions. It gives pointers on how to undo the breather among many other things.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
 Old 01-28-2019, 03:16 PM   #15
MSMS3's Avatar
https://www.dailymotion.com/video/x2y40pj
Go to 5:28 with the sound on. You have to spread those clips out and away. Try screwdriver in one hand, use your fingers with the other. It's not rocket science. I really think that you should be getting some help, and that you are total fail on trying to help yourself because you don't even try to search. You have to spread the blue clip and have to pull the yellow one away to the side. Just watch the video.
My prediction is that you will get to the next step and get stuck again. You might also want to go to the beginning of this video and look at the tools needed.
I'm now done. If anyone else wants to help, y'all have at it.
monkey.bones.007 (01-28-2019)
 Old 01-28-2019, 07:19 PM   #16
You sir are better than I. Of course I'm a dick and most of my Nator would agree.
Db09ms3 likes this.
MSMS3 (01-29-2019)
 Old 01-29-2019, 06:13 AM   #17
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
You are not a dick. Just very penis like. Some find that to be an attribute.
#metoo
Db09ms3 and GohanX like this.
monkey.bones.007 (01-29-2019), MSMS3 (01-29-2019)
 Old 02-15-2019, 02:04 PM   #18
_Mazdarati's Avatar
Posts: 90   (View Stats)
_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of
I am going through and reading this guy's threads... Holy fuck.
Do you need a helmet when you walk outside? My god I have never seen such fucking stupidity in my entire time owning my 3.
Please sell your car ASAP and stop fucking modding it. Jesus Christ .
2011 MS3 Tech Package
BNR S4v2
HTP 4" intake
CS injector seals
Grimmspeed 3-port EBCS
Full Race FMIC
CPe Triton catback exhaust
ATP long catless DP
E85
HYPNOTIC TUNED
_Mazdarati is offline   Reply With Quote
The Following 4 Users Say Thank You to _Mazdarati For This Useful Post:
Db09ms3 (02-15-2019), monkey.bones.007 (02-15-2019), MSMS3 (02-15-2019), Vansquish (02-16-2019)
In tank fuel pump not running Thestaplegunkid MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 07-26-2015 10:39 AM
Fuel pump running while parked? jaredpgh MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 02-15-2013 09:16 PM
Severity of not running a fuel pump upgrade poisonouschimp 2010 MS3 - Fuel, Nitrous & Water Injection 28 01-17-2013 12:37 PM
Page generated in 0.40893 seconds with 28 queries
