 Old 04-12-2012, 05:48 PM   #1
falcon's Avatar
Posts: 106   (View Stats)
falcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud of
Default Running Rich at Idle - P2188
Hey guys, car threw this code about a week ago, and I assumed it was running rich. Unplugged the battery reconnected it about a half hour later, and it cleared it for about a week, until today, when I stopped at a red light for about 20 seconds. I had access to a code reader this time, and got the code (P2188). Wondering what anybody has done to fix it, or is just a trip to the dealership? I read the other thread on this from like a year ago, but nobody ever gave a solid solution. I have no mods, and have done nothing in the past 6 months of owning the car to cause the light.
falcon is offline   Reply With Quote
 Old 04-12-2012, 05:57 PM   #2
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
What year is your car? How long have you had it? How many miles does it have on it? Sounds stupid but have you checked your air filter and spark plugs? That's where I would start.
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
 Old 04-12-2012, 06:00 PM   #3
atvfreek's Avatar
Posts: 7,787   (View Stats)
The canister purge valve has been a common problem for that code as well as the p2187 lean at idle code. It's a cheap part too.
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
Black Metal (04-13-2012), MS3inDC (04-13-2012), SofaKingAwesome (04-13-2012)
 Old 04-12-2012, 06:17 PM   #4
falcon's Avatar
Car is a '07 with about 106,450km. I have owned it since september of last year. I have not checked the plugs or filter, although i had the filter out about a month ago and it was looking pretty clean. The plugs are a maintenance action according to the dealership at 102k km's so I was planning on replacing those in the next week or two.
Tappin
Is the purge valve something that can be checked easily?
Last edited by falcon; 04-12-2012 at 06:17 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-12-2012, 08:27 PM   #5
deigo_ba's Avatar
Posts: 17   (View Stats)
deigo_ba is a splendid one to beholddeigo_ba is a splendid one to beholddeigo_ba is a splendid one to beholddeigo_ba is a splendid one to beholddeigo_ba is a splendid one to beholddeigo_ba is a splendid one to beholddeigo_ba is a splendid one to behold
The ECU modulates the purge solenoid to allow a specific amount of vacuum through during the Evaporative Emissions self-test. If the valve is stuck open it will allow unmetered air to be drawn into the intake manifold and cause a lean condition. If it is stuck closed it would most likely cause an Evap specific CEL (most likely P0455), so it's possible but I doubt your P2188 is caused by the purge solenoid. But to be sure you can remove it and wire the terminal that corresponds to the black/orange wire to any 12 volt source. Then have a wire coming off the other terminal. Try blowing through the solenoid with the free wire connected to nothing, then again when it is grounded. You shouldn't be able to blow any air through unless the wire is grounded.
Again, I'm sure a P2188 has been caused by a purge solenoid failure, but seems unlikely. That being said, it comes out easy and is tested easy, so it's a good place to start. After I would check out the MAF sensor. Check terminal tension and condition, wires for pinch/stretch condition, and sensor element for contamination. I've also heard of a faulty thermostat causing this code.
Good luck
08 Sunlight Silver Speed3--
Cobb stage2+93 'self tune', Cobb SRI, Cobb TIH, Cobb FMIC, Cobb downpipe, Cobb cat-back, KMD v2.1 pump internals, Forge BPV, Custom FMIC Sprayer
Ralco SS, Eibach Pro-kit with koni yellows, Ebay strut tower brace, Prosport boost gauge, Corksport RMM insert, Ebay OCC, Matte Graphite Sparco Assetto Gara 18X8 +45 wheels, 235/40/18 Continental Extreme Contact DWS
AWmustang- 287/347. 1/4- 13.633@106.3 (track), 0-60- 4.906 (w/AP)
deigo_ba is offline   Reply With Quote
 Old 04-12-2012, 08:28 PM   #6
atvfreek's Avatar
It's a check valve thats normally closed, so if you take it off you shouldn't be able to blow through it in both directions.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 04-12-2012, 08:40 PM   #7
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
Groans: 38
I got 2188 from the purge valve( and quite a few others), also I could just tap mine with a wrench and it would close back up. rockauto.com I believe i paid under $16 for it.
RockAuto Parts Catalog
just search 911702
25%E85FREEKPERMED
 Old 04-12-2012, 08:56 PM   #8
falcon's Avatar
Awesome guys, I will give this a try in the next couple days and report back!
Thanks
 Old 04-13-2012, 10:02 AM   #9
falcon's Avatar
Just had the purge valve out, and I can NOT blow through it in either direction. But as a rule of thumb whenever I work under the hood i always disconnect the battery, so in doing so it got rid of the check engine light. So not sure if I rattled the valve loose in the process of pulling it out, but it would make since if its only intermittently sticking, cause I can drive for a couple days now before the light will come back on. I did let the car idle for a couple minutes after and no light! Am going out now to check the MAF sensor.
 Old 04-13-2012, 10:10 AM   #10
MS3inDC's Avatar
Posts: 3,070   (View Stats)
MS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the world
Groaned at 56 Times in 37 Posts
Pay attention to when the cel comes on in relation too when you fuel up as well...
cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp
jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob
ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com
311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM]
12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14]
I would wear a pink unicorn shirt, and still call someone a faggot. Since when did MSFers begin to give fucks?...
MS3inDC is offline   Reply With Quote
 Old 04-13-2012, 10:57 AM   #11
falcon's Avatar
The first time it ever came on I had just filled up, and drove 1.4km stopped in my driveway and it came on as I stopped. Second time was about 4 days later on a new tank of has that was half gone and I just stopped at a red light! Will post back when it comes on again
- CS SRI - Sure RMM - JBR OCC - JBR RSB - VG Shark Fin - Auto Goody Interior LED Kit - Sure Shortcut - Sure CounterShift - HKS SSQV4 -
 Old 04-13-2012, 01:59 PM   #12
deigo_ba's Avatar
Not being able to blow through it in both directions is good, but does not verify that it is opening when commanded on. It could be stuck closed. To check it you would have to activate it and see if it allows air through. You could wire it like I mentioned before or find a scan tool that can command it on and off.
 Old 04-14-2012, 02:14 PM   #13
falcon's Avatar
Purge valve is good. Just had it on a 12v source and it works fine. MAF sensor wiring looks secure no kinks, and sensor itself looks clean! Plugs will be replaced Sunday!
 Old 04-16-2012, 06:22 AM   #14
falcon's Avatar
Last night it threw another code - P300 - misfire cylinder 2. I'm assuming this is a result of it running so rich
 Old 04-16-2012, 01:26 PM   #15
falcon's Avatar
Okay guys, replaced the plugs today and the car is running much smoother, and I believe we have solved the misfire problem. Still working on the rich at idle. Have some freeze frame data im going to attach below, if anybody sees anything really unusual please let me know. I have a feeling its the MAF sensor because the freeze frame date is saying the vacuum pressure is 8-9 inHg and workshop manual says 18+ and i put a suction gauge on it, and it read 21inHg.
Freeze Frame Date from P2188
Fuel system 1 status -------------------Closed Loop
Calculated Load Value ------------------23.14%
Engine Coolant Temp. ------------------190.4 F
Short Term Fuel Trim - Bank 1---------( -7.81%
Long Term Fuel Trim - Bank 1---------( -17.19%
Intake manifold Absolute Pressure-----9.18 inHg
Engine RPM------------------------------700.25 RPM
Vehicle Speed Sensor -------------------0.0
Ignition Timing advance----------------9.50 degrees
Intake air temp--------------------------57.20 F
air flow rate mass air flow sensor-----0.36 lb/min
Absolute throttle position---------------11.37%
Time since engine start-----------------355 sec
Looking for any other suggestions or input!
 Old 04-16-2012, 11:25 PM   #16
Groans: 78
Your vac pressure is low as you mentioned. Double check for boost/ vac leak. Your LTFT's are way off. I have no idea what would cause this on a stock car. Sorry I can't offer more advice.
- 6MT - Stock -
 Old 04-24-2012, 08:16 PM   #17
falcon's Avatar
Just got my car back from the dealership tonight, they replaced all four injectors! Waiting to see if the code comes back.
 Old 04-24-2012, 08:25 PM   #18
emag remrofni's Avatar
Posts: 1,594   (View Stats)
emag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the world
Groans: 209
Groaned at 92 Times in 38 Posts
If that doesn't fix it clean your MAF and try to find someone local that you could borrow one from to see if it's fucked up.
// 09 CWP // Cobb SRI // SURE Race RMM // eBay double penetration DP // SU BPV // ITV22's // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 //
4 Gallon E85 by Stratified
My Photography - DarkSidePhotoshoot.com
it was a mexican
whoever said they are lazy is a stupid dumb fucking idiot
and they can do ANYTHING...they prolly got the wheels off with a branch and some hedge clippers
The dick bone is not connected to the asshole... Mind over matter, learn to control them both.
emag remrofni is offline   Reply With Quote
 Old 05-29-2012, 10:28 AM   #19
CW42's Avatar
Posts: 216   (View Stats)
CW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant future
I have this problem on my stock 2007 MS3. Just that one code. Rough idle and too much fuel at idle if the engine is at operating temp. Every part has been changed and/or tested so I'm kind of stuck. They tell me the problem can't be fixed.
CW42 is offline   Reply With Quote
 Old 05-29-2012, 04:17 PM   #20
falcon's Avatar
Our cars naturally run rich, but when mine threw the code it also starting randomly miss firing. They replaced my injectors and I haven't seen the code since. About a $2200 fix though!
 Old 08-16-2012, 09:38 AM   #21
WhoIsJeremy's Avatar
Posts: 2,196   (View Stats)
WhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the world
just curious if you ever got to the bottom of it? I'm having the same issue on my 6, but don't wanna deal with 100 things haha
2007 MS3 GT -- > World's first flying Mazdaspeed3.
2006 MS6 GT -- > World's first n2o Mazdaspeed6.
1990 LS1 RX7-- > Probably broke somewhere
#DIX, for all the single ladies
WhoIsJeremy is offline   Reply With Quote
 Old 08-17-2012, 06:54 AM   #22
falcon's Avatar
It was a leaking injector for me, but since they had it apart and it was under warranty they replaced all 4. Haven't had any issues since! It was over a $2k job, only cost me my 200$ deductible
 Old 08-17-2012, 08:34 AM   #23
i went from my half finished e-tune to ots and it went away. thinking something in my tune was off or I havent put enough miles on it for it to pop back up
 Old 08-17-2012, 09:21 AM   #24
CW42's Avatar
My problem started after they put new injectors in. I basically paid 2000 dollars to have my car screwed up.
 Old 09-20-2012, 04:07 AM   #25
bulldog619's Avatar
Posts: 1   (View Stats)
bulldog619 is an unknown quantity at this point
i am having the same issue
I have a 2006 speed 6 and I have a Mazdaspeed CAI, Turbosmart dual port BOV, and a Magnaflow single exit CBE. And I have been having an issue with my CEL intermittently going on. When the CEL is on the code is p2188. It seems as though it usually comes on after accelerating pretty hard, and will stay on for a couple of days. Then after babying the car for a couple days to a week then the light will go out on its own. I also have noticed a hesitation at times when accelerating and backfiring when letting of the throttle to shift gears. I have tried removing the BOV and using the stock one, and the hesitation will go away and the backfiring will stop but the CEL issue continues. It is time for a smog and there is no way the car will pass with the CEL on. getting frustrated...
bulldog619 is offline   Reply With Quote
 Old 10-12-2012, 05:20 PM   #26
rolanblack's Avatar
Posts: 2,110   (View Stats)
Pulled the same code.
- i retighten all clamps and looked over the hoses.
- removed the MAF and sprayed it with MAF CLEANER
Problem fixed.
Didnt have any lose of power or hesitation. Would recommend it to anyone who experienced this.
 Old 10-12-2012, 06:07 PM   #27
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
I started getting this code when I flashed my car with an off-the-shelf map from cobb. I think this is because the computer isn't used to getting that much more fuel. It would come on and off all the time with no identifiable pattern but Iv'e ran the map for 3 months and I don't get it anymore and I didnt do anything, I just let the computer learn it and it learned that everything is running fine.
Performance:
Stratified Tune in progress
 Old 06-22-2017, 06:41 AM   #28
BloodBanez's Avatar
Posts: 9   (View Stats)
BloodBanez is on a distinguished road
I have an 08 speed 3 with a sri and an accessport and I got the codes PCM, p2188, IC, and u2064. I got it right after I filled my tank and I am trying out the economy tune to see what kind of mpg I can get. I filled up the day after I loaded the tune and then the code came on. Plus when I loaded the tune it gave me a message saying "this map either lacks or has dated support for this feature. Re save this map in the latest version of accesstuner to add AP adjustment support or contact customer support." Now the code still loaded so I just thought it was an outdated tune that still worked but now idk if it may have caused the codes or not. So what does the message mean and what do my codes mean?
BloodBanez is offline   Reply With Quote
 Old 06-22-2017, 10:07 AM   #29
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Load previous map and clear codes then see if they come back. I can almost guarantee they wont. I would not run the economy map. If you want good gas mileage sell the speed 3 and get a fiesta.
 Old 07-04-2017, 06:25 PM   #30
Dawson_MS6's Avatar
Posts: 29   (View Stats)
Dawson_MS6 is on a distinguished road
Ive had this too rich at idle situation for a couple weeks now, and I've tried everything my LTFT is at -16 and STFT is at -15 at idle, I checked purge valve, tune, MAF, leaks in bypass hose and changed hpfp pumps/ internals, still got the code. Some days it runs more rich than other days, but it's always running extremely rich, at this point I am thinking it's an O2 sensor, maybe the downpipe turbo gasket, idk spark plugs or an open injector? I'm just stuck and do not know what to do at this point or know how to find my problem, my car does not run any differently seems to idle normally, AFR is good, hpfp levels at idle and wot are good. Anything helps
Dawson_MS6 is offline   Reply With Quote
 Old 07-04-2017, 07:23 PM   #31
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Injector seals?
crapatalk it sucks for free
 Old 07-05-2017, 04:15 PM   #32
Groans: 211
Pull the dipstick and inhale lightly. Faint smell of gas or really strong?
 Old 09-06-2017, 08:52 AM   #33
brettmurphy's Avatar
Posts: 5   (View Stats)
brettmurphy is an unknown quantity at this point
Re: the smell of gas - what would it be? Rings?
brettmurphy is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/running-rich-idle-p2188-110637/
Problème speed3 injecteur?? Help - Mazda 3 Quebec This thread Refback 05-20-2013 09:17 AM
If only I was as rich as my car is running... MaverickX3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 03-04-2013 01:28 PM
Car running rich SilkySpeed3 Gen2 MS3 General Discussion 8 03-29-2012 02:28 AM
Rich @ Idle - P2188 TriO MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 11-02-2011 02:29 PM
p2188 - too rich at idle yearzero MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 05-15-2010 09:53 PM
Running rich ass hell i think NJSPEED3 MazdaSpeed 3/6 - ECU Computer Tuning 15 03-01-2009 07:39 PM
Page generated in 0.49672 seconds with 36 queries
