Like Tree9Likes
 Old 01-04-2014, 04:46 PM   #41
God I hope its not the ecu, but I can't connect the obd so that scares me a bit. I cant imagine that's cheap.
Why would it just stop working? I can't take the intake off and see if anything under there is rubbing. I know when I re-did my battery tray a month ago or so I moved the wires around down there.
Sent from my XT907 using Tapatalk
You can find used ECUs for cheap for your year and sometimes COBB can recover it if it happened during a flash. They are good at helping out. Dealer price on an ECU is a pretty penny but there are options.
I added to my post - it may not be the ECU - there are a few components at play there. If you suspect wiring it is well worth checking out.
If you can't unlock the car via the key you won't be able to connect to OBD using the usual scanners or AP.
Funkster777 (01-04-2014)
 Old 01-04-2014, 05:04 PM   #42
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Well it didnt happen during a flash, so Im not sure if thats good or bad.
I will check out the wiring and see. Everything at the ECU connection point looks good. With how the car is flashing a code though I think its receiving something from the ECU, but I really know very little about this stuff. And the whole "cant connect" with the obd2 stuff still has me wondering.
I will try tonight to see if I can find some wires causing issues. It sucks more now, because my heater is only half working in the garage and its supposed to go down to single digits I believe tonight. yay.
 Old 01-04-2014, 07:08 PM   #43
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Plug in ur ap to your computer and see if an recovery mode is on there.
 Old 01-04-2014, 07:16 PM   #44
maisonvi's Avatar
Groans: 75
Where would that be? Everything looks normal in the AP manager.
 Old 01-04-2014, 11:51 PM   #45
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Check the wire that runs from the main harness to the starter. I have been having problems with that wire since i installed my 3 bar map. Sometimes the car wont start and i have to giggle the wire to get the car to start. I though i had fixed it by disconnecting the wire of the starter and cleaning it. But the problem is back 4 months later.
Checked battery cells as a last resort before buying new battery and they were bone dry. Put distilled water in all 6 and ran it for lil bit on the freeway. Seemed to start up a bit faster and with no struggle. The last 7 starts were good too, this after dying twice in the same day. Hope this lasts.
Sent from my KFAPWI using Tapatalk HD
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 01-06-2014, 02:08 AM   #46
Micha's Avatar
Posts: 3,436   (View Stats)
ken, my wiring harness did this after my last motor swap. The problem with mine is the part of the harness that goes to the ecu was all beat up for some reason. so I took everything apart, cleaned it up and re taped it up good with electrical tape. I wish I had my car on me so I could show you what I meant. maybe @Little John; can take pics and send them to you because he was there.
There is an exposed ground wire in the middle part of that section of harness.
I am slow again.
I modded it a little.
The Following 2 Users Say Thank You to Micha For This Useful Post:
Funkster777 (01-06-2014), maisonvi (01-06-2014)
 Old 01-09-2014, 08:25 AM   #47
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Has this been rectified yet? We must get our only BT Speed3 running!
Silver 2007 Speed3 GT
The Following 2 Users Say Thank You to HawkeyeGeoff For This Useful Post:
Funkster777 (01-09-2014), mzr0818 (01-09-2014)
 Old 01-09-2014, 08:30 AM   #48
maisonvi's Avatar
Groans: 75
Gonna call the dealer here again shortly. Talked to Cobb yesterday, they have no idea either. Hoping to have it towed in to the dealer tomorrow morning and have them take a look.
HawkeyeGeoff likes this.
The Following 2 Users Say Thank You to maisonvi For This Useful Post:
 Old 01-09-2014, 08:36 AM   #49
I'll get my baseball bat in case they decide to fuck with any of your mods.
 Old 01-09-2014, 02:57 PM   #50
maisonvi's Avatar
Groans: 75
Well she is set to go on the flat bed at 7:30 in the morning tomorrow. Hopefully the dealer can give me some good news before I leave for the terMInator ski trip at noon.
The Following 3 Users Say Thank You to maisonvi For This Useful Post:
Funkster777 (01-10-2014), HawkeyeGeoff (01-09-2014), mzr0818 (01-09-2014)
 Old 01-10-2014, 11:52 AM   #51
maisonvi's Avatar
Groans: 75
Well as of this morning she is at the dealer. We will see what they say.
Feeling not great about my hopes of a cheap repair.
Funkster777 (01-10-2014), Micha (01-17-2014)
 Old 01-10-2014, 12:05 PM   #52
Funkster777's Avatar
Posts: 1,254   (View Stats)
Funkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the world
Hoping for good new.
Funkster777
2010 Black Cherry Metallic Mazda 6 DD (well as needed)
2006 Black Mica Mazdaspeed6 Sport
Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.
Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS
Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails
Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod
Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port?
Funkster777 is offline   Reply With Quote
The Following User Says Thank You to Funkster777 For This Useful Post:
maisonvi (01-10-2014)
 Old 01-10-2014, 12:20 PM   #53
mzr0818's Avatar
Groans: 221
Man, it sucks to see. Let us know the outcome.
EMWNM 2013
2008 mazdaspeed 3 true red
Tuned by Nishan
The Following 2 Users Say Thank You to mzr0818 For This Useful Post:
Funkster777 (01-10-2014), maisonvi (01-10-2014)
 Old 01-10-2014, 01:42 PM   #54
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Sad
Sent from fastest Ko4 Pu.
Nator is what it does.
 Old 01-10-2014, 02:55 PM   #55
maisonvi's Avatar
Groans: 75
Well the dealer spent a bunch of time on it today. Looks like the PCM is shot.
The dealer said they would be willing to install a used one (not something they normally are OK with but I know the parts counter guy). So now I'm on the hunt for a used ECU that will work. Anyone got one?
 Old 01-10-2014, 03:02 PM   #56
theurgy's Avatar
Posts: 2,580   (View Stats)
Damn...
From what I know, used form a wrecker they go for about $150 on average.
The Following User Says Thank You to theurgy For This Useful Post:
 Old 01-10-2014, 03:03 PM   #57
maisonvi's Avatar
Groans: 75
Originally Posted by theurgy View Post
Damn...
That's better than the $1200 dealer cost.
Funkster777 (01-10-2014), mzr0818 (01-10-2014)
 Old 01-10-2014, 03:17 PM   #58
theurgy's Avatar
Exactly, just look up on Car-Part.com--Used Auto Parts Market for the part: Engine Computer.
There's apparently the following variations for these:
Elec Cont Unit (ECU), (mtd by battery), 2.3L, MT, turbo (Speed3), ID L34B-18881-D thru G
Elec Cont Unit (ECU), (mtd by battery), 2.3L, MT, turbo (Speed3), ID L34C-18881-D thru G
Elec Cont Unit (ECU), (mtd by battery), 2.3L, MT, turbo (Speed3), ID L39R-18881
Elec Cont Unit (ECU), (mtd by battery), 2.3L, MT, turbo (Speed3), ID L39R-18881-A
Elec Cont Unit (ECU), (mtd by battery), 2.3L, MT, turbo (Speed3), ID L39S-18881
Elec Cont Unit (ECU), (mtd by battery), 2.3L, MT, turbo (Speed3), ID L39S-18881-A
I guess lookup which one is yours and locate a close enough wrecker willing to ship.
The Following 3 Users Say Thank You to theurgy For This Useful Post:
Funkster777 (01-10-2014), maisonvi (01-10-2014), mzr0818 (01-10-2014)
 Old 01-10-2014, 03:22 PM   #59
maisonvi's Avatar
Groans: 75
I'm looking for a L39S-18-881E according to the dealer. I made a WTB to see if anyone else has one.
I'm on my phone on the way to the Nator MI ski trip. So if there is a PC I can use tonight I will be shopping.
 Old 01-10-2014, 03:24 PM   #60
theurgy's Avatar
Engine Computer
Mazda 3 5/08,2.3,M.T.,FWD,L39S18881E 13D0357 $110 Morrison's Auto Inc USA-WI(Edgerton) Request_Quote 1-800-866-2277 Request_Insurance_Quote
The Following 2 Users Say Thank You to theurgy For This Useful Post:
 Old 01-10-2014, 03:33 PM   #61
There are many part numbers for the PCM from 07-08. You want any 07-08 PCM. Not 09. Unless your car is an 09.
Now, this is very important. Most wrecked PCMs have tunes on them. The dealer tool can't communicate with an ECU that has a tune on it. They will tell you the PCM is bad. You must go there with your AP, plug it in, uninstall any prior tunes that are on the car prior to the dealer being able to program it. This will save you a lot of headaches.
Easter Bunny (01-16-2014), Funkster777 (01-10-2014), maisonvi (01-10-2014), meicalnissyen (07-15-2015), theurgy (01-10-2014)
 Old 01-10-2014, 04:11 PM   #62
maisonvi's Avatar
Groans: 75
Well I have to figure out how to un marry my ap from an ecu it can't connect to
 Old 01-10-2014, 04:27 PM   #63
ihasmazda's Avatar
Posts: 1,011   (View Stats)
from what i've been told if you're the original AP owner and can prove to cobb that your ecu is dead they should re-license it for $50
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
The Following User Says Thank You to ihasmazda For This Useful Post:
 Old 01-10-2014, 05:11 PM   #64
I would contact COBB and send them the AP and faulty PCM.
Funkster777 (01-10-2014), maisonvi (01-15-2014)
 Old 01-15-2014, 02:16 PM   #65
maisonvi's Avatar
Groans: 75
Ok further updates for those who care or love to read about my plight:
Picked up a PCM off of @apena85; Big thanks man.
Got it in today and borrowed a work truck to take it to the dealer. Talked to the service tech there (super nice guy and understands my car is not stock by any means) He is going to reprogram my keys and everything else that needs to be mached up, but not start till until tomorrow when I should have my V3 AP in (V2 is married to bricked ECU and cant be unmarried).
So assuming things go according to plan, my car should be running again tomorrow evening....I hope.
kritz likes this.
The Following 8 Users Say Thank You to maisonvi For This Useful Post:
apena85 (01-16-2014), Funkster777 (01-16-2014), HawkeyeGeoff (01-15-2014), kritz (01-15-2014), mzr0818 (01-15-2014), nortigid (01-18-2014), taf0422 (01-15-2014), theurgy (01-15-2014)
 Old 01-15-2014, 03:50 PM   #66
theurgy's Avatar
May I ask what the PCM cost you?
 Old 01-15-2014, 03:54 PM   #67
maisonvi's Avatar
Groans: 75
New from the dealer they quoted me $1283, but onlinemazdaparts had it for $900 something. Bought mine for $215. Found cheaper ones at junkyards, but I knew this one was unmarried and from a forum member, which I like to support when possible.
kritz likes this.
The Following 5 Users Say Thank You to maisonvi For This Useful Post:
apena85 (01-16-2014), Easter Bunny (01-16-2014), Funkster777 (01-16-2014), taf0422 (01-15-2014), theurgy (01-15-2014)
 Old 01-16-2014, 11:31 AM   #68
apena85's Avatar
Posts: 470   (View Stats)
apena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the world
Don't forget the specific model you were looking for too.
2008.5 MS3 totaled
2006 ms6 sold
2017 cx9
apena85 is offline   Reply With Quote
 Old 01-16-2014, 11:39 AM   #69
maisonvi's Avatar
Groans: 75
Yeah, you saved me big on that. Got a text from my buddy there this morning saying everything is good and they are waiting for me to come put a tune on it so they can start it.
Now I just need my AP to show up.
apena85 likes this.
 Old 01-17-2014, 11:31 AM   #70
maisonvi's Avatar
Groans: 75
Car started up and ran! Wooo!
I will go after work with the wife to pick it up.
Went in at lunch to tune it and brought pizza with me. Now I have a bunch of friends that work at a mazda dealer and they gave me a 10% discount on the labor (paid for the pizza pretty much)
So ready to have it back, but its snowing like crazy again so driving anything but nice will have to wait a bit.
Big thanks to everyone who helped out. Especially all my supportive Nator MI people, and also @Micha; and @mzr0818; for all your trouble shooting help.
kritz likes this.
Funkster777 (01-17-2014), HawkeyeGeoff (01-18-2014), kritz (01-17-2014), Micha (01-17-2014), mzr0818 (01-17-2014)
 Old 01-17-2014, 11:01 PM   #71
Micha's Avatar
Looks like I wasn't much help in the end.
i hate tapatalk
I am slow again.
 Old 01-18-2014, 07:00 AM   #72
mzr0818's Avatar
Groans: 221
i hate tapatalk
I feel the same way @Micha; I hate to see this as the way things turnid out but I'm glad she's running
EMWNM 2013
Tuned by Nishan
The Following User Says Thank You to mzr0818 For This Useful Post:
Micha (01-18-2014)
 Old 01-18-2014, 08:15 AM   #73
maisonvi's Avatar
Groans: 75
i hate tapatalk
Yeah, didn't turn out to be any of what we came up with, but had it been something other than the ecu you both were a big help.
Micha (01-18-2014), mzr0818 (01-18-2014)
 Old 07-15-2015, 09:02 AM   #74
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
This should have been stickied
Or I should be less impulsive
 Old 07-20-2015, 11:58 PM   #75
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
What a pain in the ass this turned out to be, at least it was fairly inexpensive, could have been worse. Wonder what made the ecu take a shit randomly like that, were you able to find out?
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
 Old 12-31-2017, 01:07 AM   #76
aviator79's Avatar
Posts: 3,934   (View Stats)
Ive got a flashing key/security light on dash and no start. No power going to starter solenoid wire on start. Giggles wheel, not it. Just replaced engine wire harness due to blowing out coils. Now what? This is on an ms3. ECU shot? or PCM?
Security Light Flashing Question KoreanNightmare Gen2 MS3 General Discussion 4 02-08-2015 09:19 AM
MS6 - Security Key, Buttons work, Keyless start does not 89rotary MazdaSpeed 3/6 - Car Audio & Electronics 6 01-19-2013 07:59 AM
Security light flashing p057 Mazdaspeed3/6 General Discussion 2 03-24-2012 07:55 AM
Security Light jbaum06 Gen2 MS3 General Discussion 1 08-15-2011 07:06 AM
Cobb AP Wont work car wont start boosted_speed6 Mazdaspeed3/6 General Discussion 30 05-09-2011 11:11 PM
Page generated in 0.56622 seconds with 35 queries
