Like Tree9Likes
 Old 01-03-2014, 07:35 AM   #1
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Default Security light on and car wont start
Ok, so this morning went to start my car. Key in normally but didn’t want to start it because I wanted to flash a new tune on it. Connect the AP and then go to the tune screen. AP says it cant connect.
Try and start the car and no go. Have the flashing key security light thing. (see attached shitty picture for reference). Not sure if it was on when I first put the key in as I didn’t look at the dash. Spent 45 minutes trying to get it to start before I had to drive the wife to work so I could use her car.
Things I have done:
Unhooked the battery multiple times (once for at least 15 min, and with my foot on the brake for a bit to try and drain the system)
Tried my spare key (A side note, this is a copy of the other key I have. When I bought the car it only came with one and I had a copy made)
Unhooked the ECU
Checked the connections at the ECU. Everything here seems fine no broken wires that I could see.
Unhooked all things plugged into the OBD2 (wanted to make sure Aeroforce gauge or AP wasn’t causing issues)
Heated up the garage. It was 2 degrees out this morning and I know cold can do stupid things to cars. Got the garage to at least 45-50 degrees.
That’s what Ive done, and none of them have worked. Anyone have any suggestions? Ive made no changes to the car recently. Tonight I plan to start checking over the wiring harness to see if something is broken somewhere, but other than that I have no idea on what to do.
I read though the shop manual a bit at work here at there are a lot of possible things, most of them are a bad key. But trying both keys and no luck leads me to believe something else. AP cant connect to read the any DTC so Im not sure what to do to check that. Will an autozone one read the codes?
 Old 01-03-2014, 07:42 AM   #2
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Start a small fire under the motor?
Car won't Start
Nator is what it does.
 Old 01-03-2014, 08:02 AM   #3
Drag it to the dealer. The car thinks its stolen.
 Old 01-03-2014, 08:24 AM   #4
jm211's Avatar
Posts: 943   (View Stats)
Steering wheel locked? Try inserting key and turning the wheel back and forth when key has the acc on.
Mine does that sometimes. Key light with key in the car flashes like a bat out of hell. Steering wheel is locked and i jiggle it as i try to turn key to on and it eventually lets go. Only happens when i turn the wheel when car is off and the wheel locks in place.
The Following User Says Thank You to jm211 For This Useful Post:
maisonvi (01-03-2014)
 Old 01-03-2014, 09:30 AM   #5
maisonvi's Avatar
Groans: 75
Thanks, I will try that when I get home.
 Old 01-03-2014, 11:16 AM   #6
Funkster777's Avatar
Posts: 1,254   (View Stats)
Funkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the world
I have the reset code stuff from the dealer but it's in the Speed (not where I'm at). I'll see if I can find that online to get the key to work. Maybe a low battery in the key.
Funkster777
2010 Black Cherry Metallic Mazda 6 DD (well as needed)
2006 Black Mica Mazdaspeed6 Sport
Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.
Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS
Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails
Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod
Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port?
Funkster777 is offline   Reply With Quote
 Old 01-03-2014, 11:58 AM   #7
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Yeh shake that mother f'er!
Silver 2007 Speed3 GT
 Old 01-03-2014, 05:54 PM   #8
maisonvi's Avatar
Groans: 75
Well no luck thus far. The garage is up to 60 degrees, so its not the cold.
Also tried connecting my bluetooth OBD2 adapter and torque app to see if I could read the code, app says I cant connect to the ecu with that either.
Any one know if there is a way to bypass the security key sensor. A guy at my work said he had a similar issue, and he ended up putting a few resistors in line with a specific wire and the system was bypassed. Cant find anything too similar on the forum here.
Funkster777 (01-03-2014)
 Old 01-03-2014, 06:00 PM   #9
mzr0818's Avatar
Groans: 221
It's probably a problem with the code ring. It is what reads the chip inside the key. If neither key works then the ring is not receiving. Try banging on the cyl area while the key is turned full over maybe you could get it to clip on for a sec to start the car. if tow it in.
EMWNM 2013
2008 mazdaspeed 3 true red
Tuned by Nishan
 Old 01-03-2014, 06:06 PM   #10
cthomp's Avatar
Posts: 114   (View Stats)
cthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the world
Check all of your fuses... if it was a bad key/immobizer you would be able to communicate with your accessport/pcm but still not start or crank.
HawkeyeGeoff likes this.
Cobb accessport. Cpe rmm. HTP 3.5 in. Intake. Gtx3076 w/atp ewg hotside, tial 38 w/g, 3 bar map senor, grimmspeed ebcs, A/T internals. TR 8 core w/cx racing pipes. Relentless Customs PNP I/M. M2 downpipe with Ultimate Racing cat back. Swift springs. Some accessories. Freektuned.
cthomp is offline   Reply With Quote
 Old 01-03-2014, 06:07 PM   #11
maisonvi's Avatar
Groans: 75
Banging on where? Im willing to try anything at this point.
Towing is not a great option. Im heavily modded, and the nearest dealer is over an hour away.
 Old 01-03-2014, 06:07 PM   #12
I have a hundred miles of towing haha
Sent while granny shiftin' and not double clutching like I should
The Following 2 Users Say Thank You to HawkeyeGeoff For This Useful Post:
Funkster777 (01-03-2014), maisonvi (01-03-2014)
 Old 01-03-2014, 06:16 PM   #13
mzr0818's Avatar
Groans: 221
calling
EMWNM 2013
Tuned by Nishan
The Following User Says Thank You to mzr0818 For This Useful Post:
 Old 01-03-2014, 06:16 PM   #14
calling
Got ze digits?
maisonvi (01-03-2014), mzr0818 (01-03-2014)
 Old 01-03-2014, 06:17 PM   #15
mzr0818's Avatar
Groans: 221
Got ze digits?
yeah man. I have all you guys lol
EMWNM 2013
Tuned by Nishan
 Old 01-03-2014, 06:20 PM   #16
cthomp's Avatar
If I remember correctly there are a few fuses labeled eng. bar 1, 2, 3 in the engine compartment fuse box. Had a similar problem on a customer car before good luck.
The Following User Says Thank You to cthomp For This Useful Post:
 Old 01-03-2014, 06:25 PM   #17
spdtrux's Avatar
Posts: 481   (View Stats)
spdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the world
Groaned at 9 Times in 6 Posts
GREMLINS!
Seriously.
My car does this random nothingness(power to everything but won't even crank over) from time to time normally 3-7 key cycles/100miles into a flash.
I've had to pop start it to drive home a few times, always pop starts.
GLW it. My gremlins come and go as they please.
99 JEEP WRANGLER SPORT
4 liter- 5 speed- RCD BILTEIN 4" lift -32X12.5" tires-Xtreme 15"x12" wheels-JET Stage 2 ECU- K&N Intake-TB Spacer -Banks Power Monster Header back exhaust-Hurst short throw shifter-Fender Flares w/ clear corners -brush guard -Fog kit-8500lbs winch -tail light guards-Sound bar
2007 Sunlight GT Crash Smash Boom
ZOOM ZOOM = HTP Full Metal 3" // CS SRI FMIC // Cobb AP // Autotechs // CS TP & CBE // Stock Block // Stock Turbo //
Ralco RZ Shifter // JBR 88 RMM + 80 PMM + Spherical Knob + SSP + WEIGHT + Bushings // Saiko Michi OCC // Cobb Springs // KYB FRONT & BACK // Tri-point rear links // Redline hood shocks // Gen2 VC //
RICE = Rally Armor // 20% Tint All Around // Weather Tech // JDM Goodie Visors // CF Eyelids // Red/Black CF Dash Kit // Bumper Covers // Extra Sub Mod //Stuby Antenna//Red&Blue Interior L.E.D. // 50w 10 L.E.D. Cree Reverse lights
spdtrux is offline   Reply With Quote
 Old 01-03-2014, 06:50 PM   #18
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Originally Posted by spdtrux View Post
GREMLINS!
Seriously.
I've been having this issue lately and also been pop starting it. I always park on hills now lol. I'm sure mine is battery tho and gonna replace it tomorrow
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 01-03-2014, 07:25 PM   #19
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Check the wire that runs from the main harness to the starter. I have been having problems with that wire since i installed my 3 bar map. Sometimes the car wont start and i have to giggle the wire to get the car to start. I though i had fixed it by disconnecting the wire of the starter and cleaning it. But the problem is back 4 months later.
 Old 01-03-2014, 07:50 PM   #20
maisonvi's Avatar
Groans: 75
Well I pulled almost all the fuses in my engine bay fuse box, they all check out fine on my multimeter.
I was scrolling though the shop manual and found a page that shows what the codes are with the flashing of the security light. the code I got was 1+5 flashes, so #15 . Looks like the instrument cluster forgot my keys codes, or the cluster has failed.
Still looking at other options, but its getting wicked cold, so Im gonna call it a night.
kritz likes this.
The Following 4 Users Say Thank You to maisonvi For This Useful Post:
Funkster777 (01-03-2014), HawkeyeGeoff (01-04-2014), kritz (01-03-2014), mzr0818 (01-04-2014)
 Old 01-04-2014, 02:02 PM   #21
maisonvi's Avatar
Groans: 75
Well I'm out of ideas, tried everything everyone has suggested. (Thanks Jeff!) But no luck, I'm out of ideas. Tried calling the Mazda dealer but one service department was closed the other was busy and told me to leave a message. They have not called back.
So unless I figure out something else, its going to the dealer at some point with no idea what's wrong (can't wait to see this bill)
Sent from my XT907 using Tapatalk
 Old 01-04-2014, 02:09 PM   #22
Sorry nothing works. I'll keep thinking about it.
Funkster777
The Following User Says Thank You to Funkster777 For This Useful Post:
maisonvi (01-04-2014)
 Old 01-04-2014, 02:11 PM   #23
theurgy's Avatar
Posts: 2,580   (View Stats)
My guess, your passenger junction box needs programming.
 Old 01-04-2014, 02:23 PM   #24
maisonvi's Avatar
Groans: 75
Which means to the dealer is goes I assume.
 Old 01-04-2014, 02:51 PM   #25
nortigid's Avatar
Posts: 503   (View Stats)
nortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the world
Same thing happened to me when my steering wheel was locked. I had to wrench on it uncomfortably hard, and it broke free. All was good after that.
nortigid is offline   Reply With Quote
The Following User Says Thank You to nortigid For This Useful Post:
 Old 01-04-2014, 02:53 PM   #26
maisonvi's Avatar
Groans: 75
Steering wheel isn't locked at all.
 Old 01-04-2014, 03:01 PM   #27
nortigid's Avatar
No click from the starter at all, right? I wont believe the key code has been lost. That shit is beyond rare. Does the key turn at all?
Sent from my ADR6400L using Tapatalk 4
 Old 01-04-2014, 03:03 PM   #28
maisonvi's Avatar
Groans: 75
No clicks at all. The starter gets no power, so I don't think anything is being sent. I tested both the starter and main relays and they both are working.
 Old 01-04-2014, 03:11 PM   #29
nortigid's Avatar
did you put a multimeter to the starter while it's connected? or did you remove the starter/relays and test them in a different environment? security/immobilizer should lock the column and the ignition. i assume you've eliminated the battery as a possibility.
edit: sorry, my reading comprehension is low because i'm at work. don't know if this stuff has been mentioned already. AINT ABOUT TO START READIN NOW
 Old 01-04-2014, 03:13 PM   #30
maisonvi's Avatar
Groans: 75
Yep checked them all.
Relay checked with a spare battery (that I checked to be good) plus the one in the car is an optima red top less than 3 months old.
The starter is seeing no voltage when I attempt to start it based on the same multimeter.
Funkster777 (01-04-2014)
 Old 01-04-2014, 03:33 PM   #31
nortigid's Avatar
My ideas, in no particular order: ignition switch, faulty wiring (assuming no current at wires preceeding terminals), extremely dead battery (unlikely, due to no engagement gear clicking). The solenoid gets 0 voltage?
 Old 01-04-2014, 03:34 PM   #32
by any chance did it start to flash it then it stopped?
 Old 01-04-2014, 03:35 PM   #33
maisonvi's Avatar
Groans: 75
It flashes for one minute then changes to a pattern of 1+5 flashes. That means that its throwing the B1601 code
 Old 01-04-2014, 03:40 PM   #34
nortigid's Avatar
I just spoke to an alarm installer at work and he said if you are reading 0 at the solenoid paired with a security light, it's been immobilized
The Following 2 Users Say Thank You to nortigid For This Useful Post:
Easter Bunny (01-05-2014), Funkster777 (01-04-2014)
 Old 01-04-2014, 03:41 PM   #35
maisonvi's Avatar
Groans: 75
Yeah. That's kinda what I was coming up with. Any idea on if I can reset that? I duno why it would have done it.
 Old 01-04-2014, 03:44 PM   #36
nortigid's Avatar
Outside of a tow, I don't know. Sorry mayne :/
 Old 01-04-2014, 04:20 PM   #37
maisonvi's Avatar
Groans: 75
Thanks anyway man. The whole situation kinda sucks.
The Following 2 Users Say Thank You to maisonvi For This Useful Post:
Funkster777 (01-04-2014), nortigid (01-04-2014)
 Old 01-04-2014, 04:27 PM   #38
nortigid's Avatar
Hopefully it's something cheap and dumb. And self-correcting once you've given up hope.
 Old 01-04-2014, 04:27 PM   #39
Had this issue several times when an ECU bricked and no longer recognized the key during a flash. The key ring energizes and reads the key, then it sends the info to the cluster which verifies against the ECU. If any of these parts (key ring in ignition, key, cluster, ECU) have an issue you won't be able to start. Did the flash start at all?
In the end ECU had to be replaced, keys reprogrammed. The dealer is the only one that can reprogram keys and that's the first step to seeing if the ECU will talk.
Any chance you have some wiring or grounds damage from parts rubbing?
 Old 01-04-2014, 04:33 PM   #40
maisonvi's Avatar
Groans: 75
Had this issue several times when an ECU bricked and no longer recognized the key during a flash. The key ring energizes and reads the key, then it sends the info to the cluster which verifies against the ECU. Did the flash start at all?
God I hope its not the ecu, but I can't connect the obd so that scares me a bit. I cant imagine that's cheap.
Why would it just stop working? I can't take the intake off and see if anything under there is rubbing. I know when I re-did my battery tray a month ago or so I moved the wires around down there.
Security Light Flashing Question KoreanNightmare Gen2 MS3 General Discussion 4 02-08-2015 09:19 AM
MS6 - Security Key, Buttons work, Keyless start does not 89rotary MazdaSpeed 3/6 - Car Audio & Electronics 6 01-19-2013 07:59 AM
Security light flashing p057 Mazdaspeed3/6 General Discussion 2 03-24-2012 07:55 AM
Security Light jbaum06 Gen2 MS3 General Discussion 1 08-15-2011 07:06 AM
Cobb AP Wont work car wont start boosted_speed6 Mazdaspeed3/6 General Discussion 30 05-09-2011 11:11 PM
Page generated in 0.57849 seconds with 34 queries
