  • 1 Post By rfinkle2
 Old 02-16-2012, 06:58 AM   #1
dpolseno41's Avatar
Posts: 1,819   (View Stats)
Default Serious HPFP Issues
Running the Stage 2 OTS map from Cobb with some serious issues. My HPFP numbers have shit the bed in the middle of the log then rebounded. It looks like I have to tear down the pump and have a look which I have no time for these days. I never had KR previous to this map either, any ideas?
 Old 02-16-2012, 07:03 AM   #2
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
yeah, looks like it drops when you hit a load of 2 and comes back up when you go under 1.9, must just be working to hard and crapping out on you. kmds have been doing that lately it seems. wouldnt do anymore wot runs.
and the kr doesnt look serious, <1 whatever.
also did you ever do a maf calibration? your ltft are 10 and 5 before you go into OL.
Last edited by ScarMS3; 02-16-2012 at 07:03 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to ScarMS3 For This Useful Post:
Tokay444 (02-16-2012)
 Old 02-16-2012, 07:23 AM   #3
dpolseno41's Avatar
I'm just getting into all of this. I was hoping to hand it over to Lex but he won't touch anything until I get this resolved. I'll have to scour the forums and try and do a MAF cal without fucking up.
 Old 02-16-2012, 07:33 AM   #4
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
read abilor's tuning guide, it's very clear on how to do the maf cal. and it looks like you need new internals.
Blue Pu.
 Old 02-16-2012, 07:39 AM   #5
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Yes.
I don't blame Lex for not taking on a problem, I've made that mistake a couple of times...
Make sure you have the correct OTS map, check your intake/ vac lines/ etc. for leaks, and pull/ clean/ reinstall the HPFP internals.
403whp/451ft/lb Dry Shot
 Old 02-16-2012, 07:42 AM   #6
I was helping username CCC with his tune, and KMD warrantied his internals. His logs looked somewhat similar to yours.
TiGraySpeed6 likes this.
ak_spray (02-16-2012)
 Old 02-16-2012, 11:55 AM   #7
bnoon's Avatar
Posts: 1,770   (View Stats)
Bucker, you mention in the max load tables that you use the values 1.1 for gas and 1.25 for E85 mixes. Is that across the board for all RPM values? Seems after reading the help file that these values are a transition value, meaning below this value would be CL and above OL, right?
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 02-16-2012, 12:55 PM   #8
Bucker's Avatar
Groans: 451
I use those values in all of my CL max load tables for consistency. You CAN get a lot more anal with EVERY table the AP gives you access to, but I almost always simplify these tables to allow for environmental differences.
The Following 2 Users Say Thank You to Bucker For This Useful Post:
rfinkle2 (02-16-2012), Tokay444 (02-16-2012)
 Old 02-16-2012, 12:00 PM   #9
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Yes, but it would be best to just wait for Cobb to release fuel scaling rather than having to fuck around with redoing every load table/value on the map.
 Old 02-16-2012, 12:36 PM   #10
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
when did you get these? know what version?
BNR3-FREEK-PU-398HP
I lost track of the mods in my car.
dereeek is offline   Reply With Quote
 Old 02-16-2012, 01:24 PM   #11
dpolseno41's Avatar
I got the KMD internals a month ago. I just pulled the fuel pump apart and everything looked great. There is some play between the shaft and the collar however, could this be the trouble spot for KMD? I cleaned the shit out of everything and threw it back together and am still getting awfully low numbers. Should I go through with trying to exchange them? It seems that all my lines are good, it holds boost just fine.
 Old 02-16-2012, 01:33 PM   #12
BobbleHead's Avatar
Posts: 2,237   (View Stats)
Groans: 186
i dont know guys, seems like a new thread on KMD failures every week
 Old 02-16-2012, 01:38 PM   #13
dpolseno41's Avatar
Does anyone know what the exact failure is with the internals? It doesn't seem like there is much to go wrong.
 Old 02-16-2012, 01:43 PM   #14
ScarMS3's Avatar
Groans: 97
@Tokay444 .....tolerances and stuff. im guessing that the new coating that is awesome and better than ever isnt.
 Old 02-16-2012, 02:33 PM   #15
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
i see these threads and every time i come in and say what do you guys expect just because some of them work people go out of there way to waste time trying internals when cpe sells a perfectly working pump with warranty. and also ptp as well does.
i tried 5 sets of internals they all failed eventually one after 5k miles Ill never waste the time and energy again i got a cpe pump ...
i think all the internals fail because they are not getting the exact tolerance and material correct i think materials play a huge part. (i.e. special coating)
 Old 02-16-2012, 01:54 PM   #16
dpolseno41's Avatar
I figured it was a tolerance issue, even though it's so miniscule it gets magnified greatly at the pressures its under.
 Old 02-16-2012, 02:21 PM   #17
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Without knowing what the specs of a working set are, I wouldn't be able to tell you if yours are out of spec even if I measured them.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 02-17-2012, 02:33 AM   #18
BobbleHead's Avatar
Groans: 186
3k on mt ATs so far and holding strong.
The Following User Says Thank You to BobbleHead For This Useful Post:
ScarMS3 (02-17-2012)
 Old 02-18-2012, 07:47 AM   #19
dpolseno41's Avatar
Went back to stock internals on a stage 1 OTS map and still having issues at a load around 2. I believe my sensor contacts were dirty. I was showing pressure around 40 at turn key prior to cleaning! Back up to 1700 now. Time to clean the spill valve maybe? I'm starting to go crazy and hate leading on Lex.
 Old 02-18-2012, 11:31 AM   #20
ScarMS3's Avatar
Groans: 97
Could be the pressure relief...apparently our friend John at hpfpupgrade is making replacements...I'm probably wrong though, and he is most likely still shady, but it could be a good part regardless.
E85 Discussion - HPFP lubrication and Flow issues phate MazdaSpeed 3/6 - E85 Fueling 2580 03-06-2015 12:42 PM
CP-E.com 20% off Everything but HPFP neofandango Gen2 MS3 General Discussion 1 11-27-2011 11:39 PM
HPFP internals or new HPFP? JAGspeed6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 11-26-2011 02:34 PM
Page generated in 0.39980 seconds with 31 queries
