  • 1 Post By Mizzle
 Old 05-13-2012, 02:06 AM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default Simple controller design and programming
Anyone know how to design a controller module that is 12vdc powered, can controll a stepper motor on a 0-5v map reference? It cant be that damn hard but that really isnt something that I know anything about.
The fleece performance Holset he351ve turbo controller is exactly what I stated and it is usb programmable with a single table... and its $600... I dont need it to be pnp or anything, it just needs pigtails.
The table is basically 0-5vdc in and specific voltages equal a certain number of steps on the stepper motor on the turbo. I believe the stepper on the turbo has 42 steps.
Is this something that can be done for less than $600?
Edit1: the stepper on the turbo has 4 wires, a power, a ground, a high data link, and a low data link. The two data link wires are pulsed. Gonna look for voltage and Hz specs.
Edit2: inside the vgt controller there is are three position sensors, a stepper, and a microprocessor and communication is can-bus based.
Edit3: hmmm.. http://www.orionbms.com/features/ful...oJEMR67MtMWC7A getting warmer I think
2006 Mazdaspeed 6
 Old 05-13-2012, 03:10 AM   #2
TriO's Avatar
Posts: 676   (View Stats)
TriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the world
Ever come across this in your search?? Sure you could design and build what you are looking for on the cheap.
http://www.arduino.cc/
TriO is offline   Reply With Quote
The Following 4 Users Say Thank You to TriO For This Useful Post:
06Speed6 (05-13-2012), chuckms6 (05-13-2012), daafisch (05-13-2012), Mizzle (05-13-2012)
 Old 05-13-2012, 06:34 AM   #3
chuckms6's Avatar
Posts: 1,618   (View Stats)
arduino sounds perfect for this.
tapatalkin to you
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 05-13-2012, 08:39 AM   #4
Speeeeeed
06Speed6's Avatar
Arduino - HomePage
Wow that looks great, they offer alot for cheap! Now to figure out which board is best and how to program it... Anyone have a suggestion?
2006 Mazdaspeed 6
TriO (05-13-2012)
 Old 05-13-2012, 09:08 AM   #5
Speeeeeed
06Speed6's Avatar
Arduino Compatible ATmega328 Board with added feat
That one looks like it has everything I need, industrial temp range, usb programmable, 9-30vdc power, and a expansion port for a digital/analog i/o board which can support can and pwm...
Man I really need to do some research on this lol, I am getting over my head fast.
2006 Mazdaspeed 6
helmetface (05-13-2012)
 Old 05-13-2012, 09:15 AM   #6
chuckms6's Avatar
im sure there is at least one person who has done a project similar to this somewhere on the interwebs
The Following User Says Thank You to chuckms6 For This Useful Post:
 Old 05-13-2012, 09:38 AM   #7
chuckms6's Avatar
wait wait wait... would it be possible to splice a connection from the pigtail to the stock ebcs to the wires on the turbo? you would have to bypass and ignore the sensors and processor on the turbo but you could use the wdgc and boost tables already in atr to control the turbo. but that sounds much too easy...
 Old 05-13-2012, 09:47 AM   #8
First you need to define exactly how the VGT controller works. What inputs does it expect and need, electrical ranges for the inputs, and what they do to control it. For example you mention there are 2 wires that are pulsed. What frequency, voltage, and what does do they actually do?
 Old 05-13-2012, 09:51 AM   #9
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
I've seen CNC machines powered by an Arduino so I'm pretty sure you're gravy. Check out Instructables - Make, How To, and DIY
The Following User Says Thank You to Mizzle For This Useful Post:
 Old 05-13-2012, 10:01 AM   #10
chuckms6's Avatar
heres a smidgen of useful info Electronic variable vane control
 Old 05-13-2012, 10:39 AM   #11
Mizzle's Avatar
Groans: 324
Let me google that for you
e.g.
Arduino - StepperUnipolar
Controlling a Stepper Motor with an Arduino | Azega
 Old 05-13-2012, 11:01 AM   #12
Speeeeeed
06Speed6's Avatar
It seems that the can bus is protocol based so signal replication shoudnt be needed, you just need to know what commands to send and the vgt microprocessor converts that into steps for the stepper motor. Supposidly the can bus is kind of like usb in that you have devices that all connect to a host using the same communication language and the devices identity themselves to the host and the host loads a driver to use it.
I know nothing about can bus communication but if its half as easy as usb stuff my brother can program it. He knows like 13 programming languages or some crazy shit. I just need to be able to tell him exactly what I need and he can figure out the code side.
Like obd2 gives commands and receives a answer I assume can is the same way. Command the vane open and it opens not any differently than a dbw throttle body.
I am sure there is a startup self check which determines the range and throws a error if its outside of limits, then it locates the position of the vanes, that is probably dont by the internal microprocessor. Then it accepts commands to move the vanes.
2006 Mazdaspeed 6
 Old 05-13-2012, 11:17 AM   #13
Mizzle's Avatar
Groans: 324
Relatively speaking, CAN BUS is super easy.
Having said that, your brother needs to program a box for the center console display LCD <3
CosmicArkie likes this.
 Old 05-13-2012, 03:45 PM   #14
I know CAN quite well. Does the turbo have a CAN based receiver? You'd have to know what messages it is expecting. The ECU drives the throttle directly (not across the bus) so this would be a little different.
 Old 05-13-2012, 09:58 PM   #15
Speeeeeed
06Speed6's Avatar
It doesnt have a standardized command structure? I figured that you could just basically look it up lol.
The turbo does have a can based receiver
2006 Mazdaspeed 6
Last edited by 06Speed6; 05-13-2012 at 09:58 PM. Reason: MSF Database - Automerged Doublepost
Programming new key fob question S7EED3 MazdaSpeed 3/6 - Car Audio & Electronics 4 07-19-2012 08:17 PM
Programming PAC SWI-PS on Pioneer Qtip MazdaSpeed 3/6 - Car Audio & Electronics 5 06-16-2010 08:47 PM
New Releases - Official Sony DualShock 3 Controller and Nyko Controller (PS3) w/ RUMBLE $44.99 Haltech Hot Deals Section 0 04-04-2008 07:31 PM
Page generated in 0.38916 seconds with 24 queries
