(Thread Starter) | Not Ranked : 0 score i was confident everything was the same but once in the car, i noticed an extra connection point on the passenger elbow for a tiny hose but everything was already hooked up. Both have the top one that rub against a larger TIH but the 3 have an extra one just bellow... went back to my old engine and that one missed the extra connection....i could have swapped the elbow but i just plugged the top one and used the bottom for the TB winter heating since the bloc was already there and painted... My speed3 burned including all the hoses so i'm wondering what was this extra connection used for ? i just want to be sure i'm not missing something since it usually work in pairs...
| No Start after small custom work 07 speed6 | Jbarnesiii88 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 09-27-2016 04:05 PM |
| Bending small AC line | ZTune | MazdaSpeed 3/6 - Turbo Induction | 2 | 01-18-2016 08:39 AM |
| Oil return line for a speed6 where? | leka | MazdaSpeed 3/6 - Turbo Induction | 11 | 11-21-2014 07:13 PM |
| Would 17" wheels look to small on speed6 | 609speed6 | MazdaSpeed 3/6 - Wheels & Tires | 24 | 01-29-2011 06:57 PM |
