![]() Join Date: Nov 2015
Rep Power: 0 ![]() ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score thanks! |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Just fix the problem and stop trowing bushings at it. Sand the rust, hit it with Krylon, and install new lubed polys.
| Must I drop the rear diff to do sway bar bushings? | BoostedRide | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 11-20-2015 07:16 PM |
| Bushings for hotkiss rear sway bar | seige123 | Revolution Performance Motorsports | 5 | 07-21-2014 11:29 PM |
