 Old 03-15-2018, 04:26 PM   #1
buckaroo30's Avatar
Posts: 1   (View Stats)
buckaroo30 is an unknown quantity at this point
Default Stage 1+ Datalog
I just installed Cobb SRI, Cobb TIP, and Autotech HPFP internals. I am using cobb ots stage 1+ tune. Does this log look normail? Or is boost a little low?
buckaroo30 is offline   Reply With Quote
 Old 03-15-2018, 06:19 PM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
seems pretty normal. cobb stage1 used to be for stock cdfp internals, not sure if that's still the case, but running low boost is an easy way to let the cdfp internals keep up. check the notes on your map.
94 M
MS6
IS350
 Old 03-15-2018, 09:00 PM   #3
MSMS3's Avatar
Posts: 2,826   (View Stats)
Seems like a stock tune with protected high pressure fuel pump. I note stock boost and a load limit of about 1.75, which seems stock or maybe a bit better, not much. Lots of wastegate reserve. No knock retard. Timing advance looks stock.
This is a good base to build on. No appreciable power gains, but very safe.
Stage 2 with SRI + TP datalog done.ski 2010 MS3 - ECU Computer Tuning 9 02-11-2014 06:36 AM
AP SUR Stage 1 first datalog Modbug12 2010 MS3 - ECU Computer Tuning 9 02-24-2013 04:38 PM
OTS Stage 1 Datalog. Issue? EdMazdaMan 2010 MS3 - ECU Computer Tuning 14 07-22-2012 10:40 PM
First datalog with my stage 2 2012 SamInAustinTX 2010 MS3 - ECU Computer Tuning 2 12-05-2011 10:19 PM
First Stage 2+ Datalog kahunab14 MazdaSpeed 3/6 - ECU Computer Tuning 42 04-22-2011 06:41 AM
Page generated in 0.23786 seconds with 23 queries
