 Old 11-16-2017, 12:40 PM   #1
Yao06ms6's Avatar
Posts: 20   (View Stats)
Yao06ms6 has a little shameless behaviour in the past
Default Suspension problem popping noise
Ive changed my axel control arms and shock still geting a popping noise when i hit pot hole go over a bump or shaking the steering wheel left and right. What can it be?
Yao06ms6 is offline   Reply With Quote
 Old 11-16-2017, 02:57 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
What are axel control arms? Do you mean the lower control arms front and rear? Where did you get them? What brand?
Most likely its your sway bar bushings and/or sway bar end links. Try spraying the sway bar bushings with lithium grease and see if the noise goes away.
Whats the condition of the upper ball joint? When you changed the shocks did you also replace the strut mount bearings?
 Old 11-16-2017, 03:44 PM   #3
Yao06ms6's Avatar
Control arms axel struts part from auto zone all cprrect parts noise happened before the replacement. I did not change Strust mount bearing due to it being in good conditions.
CX7 Popping Noise between 2000-3000rpm DeeOrzz340 CX-7 > Issues & Troubleshooting 6 03-07-2017 09:20 PM
Popping when turning wheel & general suspension questions lreyes66 MazdaSpeed 3/6 - Suspension & Brakes 16 01-17-2017 01:29 PM
Popping noise from Speaker on startup rastlun 2010 MS3 - Troubleshoot/Diagnostics 13 05-30-2013 05:54 PM
Rear Suspension Popping ABQ Speed6 MazdaSpeed 3/6 - Suspension & Brakes 6 08-25-2012 07:47 PM
front suspension popping frodaddyweez MazdaSpeed 3/6 - Suspension & Brakes 5 01-14-2011 08:24 PM
Page generated in 0.23532 seconds with 21 queries
