 Old 10-02-2018, 08:07 PM   #1
Analytical's Avatar
Posts: 42   (View Stats)
Analytical will become famous soon enough
Groaned at 6 Times in 2 Posts
Default Swaped MAP sensor now car wont crank over
Tried smogging car w/ original map sensor, but CEL said it was bad. Swapped it out w/ used 3 bar map sensor, still getting same code when I took it back in for smog. Got some MAF cleaning spray & cleaned the original MAP sensor. Installed clean old MAPsensor now car won't crank to start. I should add that i left the battery terminals connected to battery while I did the swap. It's always recommended to disconnect battery before working on a car I understand, but what I didn't shouldn't have put anything at risk. Besides checking that all the fuses are good & that my plugs were connected, what do you guys suggest i do to troubleshoot problem. I cannot believe this is happening, urgh.
Tricks get applause, style gets respect.
Analytical is offline   Reply With Quote
 Old 10-03-2018, 08:18 AM   #2
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Wiggle the starter wire. Jump the car. The map sensor has nothing to do with the starter. What was the code.
What did you touch when under the hood other then yourself.
Fwiw the only time i unhook the battery is when i unplug the ecu or a air bag harness. The worst that will happen with koeo a code could pop up.
MECP
2012 BM
Rfinkle tune in progress
Db09ms3 (10-03-2018)
 Old 10-06-2018, 10:13 AM   #3
Analytical's Avatar
Yes there was a bit of fondling once I got it all back together for the second time. Urgh was heated for sure. I'll give that a shot & report back to the thread.
Reoccurring crank position sensor code. Funktionull 2010 MS3 - Troubleshoot/Diagnostics 6 10-07-2016 09:51 AM
need a how to on setting tdc to replace crank sensor turd burglar MazdaSpeed 3 - How-To's 7 12-22-2015 11:09 PM
Car wont Crank Oalmon CX-7 > Issues & Troubleshooting 30 07-23-2014 11:41 AM
swapped map sensor now car wont start TWOptSL0W MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 11-05-2011 06:50 AM
Page generated in 0.23291 seconds with 21 queries
