 Old 01-13-2019, 12:16 AM   #1
redvine's Avatar
Posts: 58   (View Stats)
redvine is a splendid one to beholdredvine is a splendid one to beholdredvine is a splendid one to beholdredvine is a splendid one to beholdredvine is a splendid one to beholdredvine is a splendid one to beholdredvine is a splendid one to beholdredvine is a splendid one to behold
Default Thoughts on compression test please
delete
redvine is offline   Reply With Quote
 Old 01-13-2019, 04:53 AM   #2
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
Sounds like your gonna need either rings or a valve job but I'd lean towards you needing rings, save up and buy forged pistons and good rods so it doesn't go zzb
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
Thoughts on this compression test please redvine MazdaSpeed 3 - Engine, Transmission & Driveline 9 01-16-2019 09:57 AM
Compression test bross2009 MazdaSpeed 6 - Engine, Transmission & Driveline 6 10-30-2017 11:58 AM
Compression test..... Colepidd55 MazdaSpeed 3 - Engine, Transmission & Driveline 18 07-07-2014 01:56 PM
compression test SLOWHATCH Gen2 MS3 General Discussion 35 03-14-2013 07:47 AM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
Page generated in 0.22931 seconds with 21 queries
