 Old 05-24-2016, 09:27 AM   #1
furinax's Avatar
Posts: 220   (View Stats)
furinax is a glorious beacon of lightfurinax is a glorious beacon of lightfurinax is a glorious beacon of lightfurinax is a glorious beacon of lightfurinax is a glorious beacon of light
Groaned at 7 Times in 3 Posts
Default Throttle blips on gear change
When I am driving and shift out of a gear (usually 2, 3, 4, 5) the throttle blips slightly, about 1-200 rpm. It is most noticeable on upshift. This did not used to happen I believe and currently happens about 80% of the time. Could it be due to a dirty throttle body or ECU? I was tuned by freektune.
2007 Mazdaspeed 3
furinax is offline   Reply With Quote
 Old 05-24-2016, 10:53 AM   #2
Finchee's Avatar
Posts: 306   (View Stats)
Finchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond repute
Probably due to the tune. I remember the stock map doesn't do this, but when I flashed to the Cobb OTS map for the first time, I had to adjust how much I press the accelerator pedal after a shift because the car would lurch forward a little.
2013 Mazdaspeed3 with Tech Package
Autotech Fuel Pump Internals
Cobb Accessport V3
Continental ExtremeContact DWS06
CorkSport SRI, TIP
CP-E xFlex Stage 1 65A Rear Motor Mount
Damond Motorsports Short Shift Plate
ETS TMIC
James Barone Racing Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit
Magnaflow CBE
NGK Iridium IX Step Colder Plugs
Dizzy Tune in progress...
Finchee is offline   Reply With Quote
 Old 05-24-2016, 12:47 PM   #3
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
why not ask your tuna? @Justin@Freektune;
WetzMS3 (05-24-2016)
 Old 05-24-2016, 02:52 PM   #4
Bzammitt's Avatar
Posts: 71   (View Stats)
Bzammitt has a brilliant futureBzammitt has a brilliant futureBzammitt has a brilliant futureBzammitt has a brilliant futureBzammitt has a brilliant futureBzammitt has a brilliant futureBzammitt has a brilliant futureBzammitt has a brilliant futureBzammitt has a brilliant futureBzammitt has a brilliant futureBzammitt has a brilliant future
My car started doing this over winter with my Cobb stage 1+ map. I thought the cold weather contributed to it, but its been consistently doing it. I was hoping it would go away in the next month or two when I get a real tune...
2009 Black Mica Mazdaspeed 3 GT
Cobb AP V2, JBR TIP, K&N Typhoon Intake, Forge V1 BPV, AP Shift Hammer SSP, Rally Armor UR, STI S204 Lip
Bzammitt is offline   Reply With Quote
 Old 05-24-2016, 07:22 PM   #5
Quigs's Avatar
Posts: 1,152   (View Stats)
My car has been doing this for years. It only does it when shifting from 4th to 5th and from 5th to 6th once the car is at full operating temperature. It doesn't do it when the engine is still cold. Revs higher between shifts when doing WOT runs.
I used to think it was the tune, but even flashing back to the stock map once it started happening didn't fix it. I've been over the issue with my tuner and no resolution has been found yet.
Through logging I've seen that the throttle plate is opening slightly between those shifts for some reason, even with my foot completely off the gas between each shift. Foot off gas, watch throttle close on AP, shift gears, go to engage clutch and throttle opens a touch, then foot back on gas. It doesn't effect normal driving at all other than being annoying, but during 4th to 5th WOT shifts you kind of have to anticipate for it. It's also recognizable on my boost gauge, as the needle jumps during the brief RPM "hang."
There are known RPM hang issues with other vehicles that are supported by the AccessPORT that are known to be Cobb related, but I have not seen anything similar on our cars.
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
 Old 05-24-2016, 07:56 PM   #6
jtday's Avatar
Posts: 650   (View Stats)
My car has always done this as well, even on stock tune. Not sure why, don't really care.
2009 MS3 GT
 Old 05-30-2016, 10:47 AM   #7
MSMS3's Avatar
Posts: 2,826   (View Stats)
Sounds like seeking a solution to something that is really not a problem. It is also in the stock tune and my HT "can o tuna" for 4-5 and 5-6. Must be something inherent in Mazda's engine management for MZR. Seems harmless.
 Old 09-18-2017, 10:16 AM   #8
Toot's Avatar
Posts: 1   (View Stats)
Toot is an unknown quantity at this point
i have the same problem... do you have an solution for this?
Toot is offline   Reply With Quote
Car jerks in 1st/2nd gear at light throttle NRBt Mazdaspeed3/6 General Discussion 21 04-10-2015 07:46 AM
Throttle blips in 5th gear WOT TSIGabe MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 03-11-2012 08:55 AM
nasty pop noise on throttle blips cpolly69 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 01-23-2012 11:06 AM
car jerking light throttle 3rd gear Kydizzle MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 12-15-2011 01:32 AM
KR in 6th gear with slight throttle florindi
Cobb Access Port/Maps
6 02-24-2009 06:59 PM
Page generated in 0.28799 seconds with 27 queries
