 Old 03-08-2017, 05:14 AM   #1
Tuff Gong's Avatar
Posts: 153   (View Stats)
Tuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant future
Default Tips on removing turbo mount bolt on speed 6
Hey guys so I'm trying to change this turbo and I've been stuck on the top bolt (the upside down one) that mounts the turbo to the block not the downpipe bolts or the bolts that mount it tithe exhaust manifold..... I've soaked it in penetrant overnight and no luck, cant do it from underneath because of speed6 transfer case. Anybody have any tips or what tool they used I'm all out of ideas
Cobb V3, Cobb XLE, Corksport TIP/Sri, Cp-e Tmic, SU Test Pipe, Denso ITV22, Autotech hpfp, Dizzy Tuned, Muffler Delete for race car sounds
Tuff Gong is offline   Reply With Quote
 Old 03-08-2017, 05:28 AM   #2
If you're talking about the bolt that holds the turbo onto the bracket I'm pretty sure I either use a ratchet and muscle it or stack two wrenches for more leverage.
 Old 03-08-2017, 05:45 AM   #3
zenit's Avatar
Posts: 1,364   (View Stats)
long handle wrench, with additional leverage as necessary.
11 Piece Metric Highly Polished Long Handle Combination Wrench Set
that's a bitch of a bolt.
-feejay
-wetzel
 Old 03-08-2017, 06:21 AM   #4
Tuff Gong's Avatar
I know I'm about to sound retarded but might as well ask.... So I'm on the passenger side pulling towards me..... That's correct right.... I gotta ask just cus this shot is mind boggling tight
 Old 03-08-2017, 06:26 AM   #5
Mmm if I'm thinking about what you're saying right, you should be pushing away.
The way I always think about removing bolts/nuts (if they're right hand threaded which 99% of stuff is) is spin right (clockwise) to move it away from you or spin left (counterclockwise) to pull it towards you. In this case, since the bolt head is upside down, you want it to move away from you so (looking down at it) you would want to spin it right.
 Old 03-08-2017, 06:33 AM   #6
Tuff Gong's Avatar
Yeah I'm dumb as shot brah.....thanks I got it off
The Following User Says Thank You to Tuff Gong For This Useful Post:
tom10122 (03-08-2017)
 Old 03-09-2017, 09:17 AM   #7
Tuff Gong's Avatar
So everything is back together and i get an error code for heated oxygen sensor bank 1 sensor one, got the sensor in as tight as possible (not rediculous) so i dont really know wtf.... this ever happen to yall after downpipe/turbo install
 Old 03-09-2017, 10:10 AM   #8
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
is it plugged in? Did you not route the cable correctly and melt something?
 Old 03-09-2017, 10:25 AM   #9
Tuff Gong's Avatar
Yeah routed it the same way it came on the car with those twisty clips on the downpipe, then under turbo then plugged in.... Ill double check on my next day off
 Old 03-09-2017, 01:09 PM   #10
Tuff Gong's Avatar
Actually just got the p0031 and p0134 code ... Ill change it tonight .... I hope its not the harness that the sensor plugs into thats dead.
 Old 03-09-2017, 04:43 PM   #11
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Righty tighty, lefty loosey. Have known that since I was like 5 when I was "helping" my dad remove wheels from his 70's dodge van.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Removing Shock/strut bolt cole_slaww MazdaSpeed 6 - Engine, Transmission & Driveline 2 07-14-2014 08:34 AM
Tips on removing intake duct... deyomatic 2010 MS3 - Engine, Transmission & Driveline 8 08-03-2012 06:38 AM
Removing bolt that is stripped? 79BlueSC 2010 MS3 - Troubleshoot/Diagnostics 9 07-27-2011 10:36 AM
st00pid fucking engine mount - RE: driver's side tranny mount bolt phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 23 12-31-2008 12:44 PM
Page generated in 0.31409 seconds with 24 queries
