![]() | | #241 | ![]() |
![]() Join Date: Apr 2011 Location: Boynton Beach FL/Flanders, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,007
Groaned at 64 Times in 49 Posts
| Not Ranked : 0 score
__________________ Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq. #HAR Hidden Agendas Racing | |
![]() | | #242 | ![]() |
![]() Join Date: Nov 2012 Location: Kansas City, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15,426
| Not Ranked : 0 score Damn it! I've tried to type out this long ass post 3 times now and each time I keep getting an error. So I'm going to try typing this, then editing my post to see if that works. Edit: Fucking figures. Will type out my original post shortly. Edit x 2: This was a lot to read, lol. I only have one thing to add that I don't think I have seen anyone else say yet. Correct me if I'm wrong, but at one point you said that you were afraid to ask the dealer about the rumbling for fear that they would quote you more to fix it. If you ever have to take your car to another dealer or car repair shop for anything at all, do not ever be afraid to ask them what's wrong. You're paying them a diagnostic fee to diagnose what's wrong with the car. What good does that do you if they don't check everything that you are concerned about? Perfect example. My rear diff is semi-fucked. Needs to be repaired or replaced. Before I knew what was wrong with it, I took it to the dealership. They took a look at it for a while and came back to the waiting room to tell me this. "It's going to be $1,420 to fix it or $1,900 to replace it with a used diff that has 55k miles on it." That's all they told me. I had to probe to get answers on what exactly is wrong with it, what parts am I going to need to fix it, can I get a printed quote of the parts and labor, several other questions that I needed to know to be able to fix it myself. But if I never would have asked those questions, then I could have ended up buying the wrong parts and not having what I need or just blindly paying them to do something that might not have needed to be done. Even when you're working on the car by yourself or with someone else, never be afraid to ask questions about something that you're unsure about. That's how you learn. I think that's all that I had to say. I'm trying to hurry to type, because my boss is standing behind me now, lol.
__________________ 2006 Velocity Red MazdaSpeed 6. JBR 80 duro RMM. SURE Aeros SRI. EBC dimpled and slotted rotors. EBC Redstuff brake pads. Leaking Oil Cooler. Broken Rear Diff Casing. Iffy Starter. Banged Up Intake Filter. More performance parts to come once my stock parts quit breaking. [SIGPIC][/SIGPIC] Last edited by edmsmallcash; 06-06-2013 at 10:17 PM. |
![]() | | #243 | ![]() |
![]() Join Date: Mar 2012 Location: Toronto,Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,065
0-60 in 45 Min Boarderline dangerous in the snow
__________________ 2007 Mazdaspeed 6 Black Mica Richtuned ~Some things have been bolted on~ [SIGPIC][/SIGPIC] | |
| The Following 2 Users Say Thank You to johnredding For This Useful Post: | Payne Racing 67 (06-07-2013), Style (06-07-2013) |
![]() | | #244 | ![]() |
![]() Join Date: Aug 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,355
Groans: 279
That thing was a tank though, being young and reckless I would rip through dirt/gravel roads at retarded speeds and it never broke down on me.
__________________ 2010 LSM Speed3 Bolted + Corn + Meth + ACT 6-Puck #BakeryTuned | |
| The Following User Says Thank You to Roddiy For This Useful Post: | Style (06-07-2013) |
![]() | | #245 | ![]() |
It was covered in snowboard stickers. I think it almost went a year once without being washed.
| The Following User Says Thank You to johnredding For This Useful Post: | Style (06-07-2013) |
![]() | | #246 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | Payne Racing 67 (06-07-2013), Style (06-07-2013) |
![]() | | #247 | ![]() |
![]() Join Date: Feb 2013 Location: Austin, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 92
(Thread Starter) | Not Ranked : 0 score That's not what I mean haha I'm saying that I had never experienced anything that would lead me to believe my clutch was bad. I never had the clutch slip, I never had a hard time going into gear, I never had a problem with how the pedal felt. Everything was pretty good. The car shifted great. Then out of nowhere that shit happens? That's why I'm saying that Payne's explanation is probably what actually happened.
__________________ Freek Tuned ● 2008 Sunlight Silver MS3 GT w/ Nav ● BNR Stage 4 Turbo ![]() Cobb AP ● Cobb DP ● Cobb EBCS ● Autotech HPFP Internals ● CorkSport CBE ● JBR 3.5 Inch Wide Path Intake ● JBR/Treadstone FMIC JBR OCC ● JBR Front/Rear Sway Bar ● JBR EGR Block Off/Valve Delete ● JBR Trilogy ● JBR Rear Camber Arms ● JBR Shift Knob JBR Short Shifter ● JBR Shifter Bushings ● JBR Small Battery Box ● MOOG Endlinks ● Stop Tech Brake Pads ● Stop Tech SS Brake Lines Stop Tech Slotted Rotors ● Forge BPV ● H&R Springs ● Koni Yellows ● NGK Iridium Plugs ● Bosch 3-Bar MAP Sensor |
![]() | | #248 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
This just in, I called it all the way back on page 2....
Either way, glad you got it figured out and taken care of.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson | ||
| The Following 2 Users Say Thank You to El_Diablo For This Useful Post: | Payne Racing 67 (06-07-2013), Style (06-08-2013) |
![]() | | #249 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
@OP glad it's fixed and over with! This has me second guessing going with a BT upgrade even though I make plenty to pay for everything with my car + maintenance and mods.
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning Last edited by impossible; 08-29-2013 at 10:33 AM. | |
| Waking the neighbors / reliable cold start approaches to getting along with your neighbors | rfinkle2 | 2010 MS3 - ECU Computer Tuning | 72 | 06-11-2012 10:48 AM |
| painted my neighbors rims | b-ron | MazdaSpeed 3/6 - Wheels & Tires | 23 | 09-08-2008 11:46 PM |
