![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
(Thread Starter) | Not Ranked : 0 score After I installed my JBR 88/80 trilogy I never noticed a difference in the amount of torque steer my car had. I was discussing this with @Gr8Speed; after his review and decided to make a comparison video. This is not scientific, but I don't believe it needs to be, the video speaks for itself. @jbmazda6; was kind enough provide video equipment and edit for us and condense 3 runs each into one short clip. @kevdog; was our install host and present for the video and @El Beaner; was driving the silver genpu while I drove my CB gen1. We started from a roll in 1st gear and punched it around 3000 rpm's. I apologize to @09Speed3Z; for double posting (didn't know the user reviews required to be looked at first), but I wanted to get this up.
__________________ 3rd rebuild on the way...maybe... |
![]() Join Date: Jul 2011 Location: Bowling Green, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 140
| Not Ranked : 0 score While editing the video I had some time to think about this and have a few things to add.. 1) @Cheapspeed;'s (genone) car is making more power than @El Beaner; (genpoo) which means he may be targeting higher boost in first allowing the car to torque steer more 2) This is not the same generation Speed3.. could be a difference in many things here 3) IMHO I could not come to a conclusion after watching these videos upwards of 100 times. It looks like @Cheapspeed;'s car has more torque steer but he went WOT closer to the camera by ~50 feet which makes his car look like it veers off quicker but in reality I don't think it does. Just a mini "optical illusion" for lack of better words. Just some thoughts to keep in mind.
__________________ JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers Sponsored By: JamesBaroneRacing.com |
| The Following User Says Thank You to jbmazda6 For This Useful Post: | Cheapspeed (03-29-2014) |
![]() Join Date: Oct 2013 Location: Ponder, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
| Not Ranked : 0 score Just got to say again great job on the video edit. As far as the issues, considering the gen 1 and 2 share similar if not the same suspension characteristics the only thing that would affectttorque steer would be the amount of power being produced. Both Cheapspeed and I are running tuned maps (granted he's full etune vs my ots+ tune) but both maps get rid of boost restrictions that Mazda has stock in 1st.
__________________ Current 2017 Ford Fusion Sport - TT AWD V6 Upgraded LED lighting, Steeda Oil Catch Catch SOLD 2012 LSM Tech - 11/17/17 |
| The Following User Says Thank You to El Beaner For This Useful Post: | jbmazda6 (03-29-2014) |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score I saw you guys discussing this. So many variables... Tires, tune, power made, etc. and different gens. Not to mention the wear and tear on the car. I think it's a good thought. and good on you for trying to solve a question. I just can't see how they are an equal comparison. I don't think there'd be a huge difference to begin with, so you're dealing with lots of variables that may or may not matter, but in such a small margin for variation, i can't see how this is more than anecdotal. Sorry fellas Sent from my LG-MS770 using Tapatalk
__________________ it's fun to do bad things |
| The Following User Says Thank You to jack_hammer For This Useful Post: | jdmage_mx5 (03-29-2014) |
| Not Ranked : 0 score If there was a way to completely remove torque steer, I wouldn't do it. I like the sensation, and it's only a nuisance when under hard acceleration over broken pavement, and I haven't driven a car that behaves well in that scenario. As far as mounts doing anything to reduce it - the geometry should be more static with stiffer mounts as our anchor point on the block for the passenger half shaft should move less. If there is any benefit it's probably minor and likely more apparent on a hard 1-2 shift. (and my E-Focus mount is still holding up great after ~12K miles )
| The Following User Says Thank You to JgamB For This Useful Post: | Playaj (03-30-2014) |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score Only limpwrists care about torque steer anyway. |
| The Following 5 Users Say Thank You to Agent_Orange For This Useful Post: | bioevolve (03-30-2014), btstarcher (02-19-2015), Easter Bunny (02-18-2015), emag remrofni (03-30-2014), JgamB (03-31-2014) |
| Not Ranked : 0 score I would think a video of pre and post install would be more scientific than two different generation/mileage/tires/mods/tunes/drivers/etc. Great video editing though and respect the effort everyone put into it. I personally don't get near as much torque steer fully mounted as I did stock.
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | mride23 (02-17-2015) |
![]() Join Date: Feb 2010 Location: Dallas
Rep Power: 1531 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,819
Groans: 145
| Not Ranked : 0 score Ok i have an idea for a new test. Line up next to each other and punch it at the same time. If the fully mounted car gets hit by the no mounts car the torque steer is cured a bit if not then torque steer is the same Sent from Pu
__________________ 2011 MS3"Princess GRU" GT2876r AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, E85 FREEKTUNE |
| The Following 3 Users Say Thank You to Zdraveca For This Useful Post: |
![]() Join Date: Mar 2010 Location: San Francisco, CA
Rep Power: 295 ![]() Thanks: 14
| Not Ranked : 0 score The only thing we learned from that video is that, both drivers are dead and the people in the adjacent lanes got f***ed sideways for no good reason at all. |
| The Following User Says Thank You to Say Chi Sin Lo For This Useful Post: | Cheapspeed (03-30-2014) |
![]() Join Date: Apr 2012 Location: irving,tx
| Not Ranked : 0 score if you guys could set it up again as you had it but have a piece of chalk (or something to tagged the ground) taped onto the bottom of your side skirt to mark your actual torque steer. this way you could do a walk comparision of both vehicles. have a start point (A) leading to your next point (B) which would be at 3000rpms when you WOT it causing the torque steer. nice job anthony and El beaner |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,747
| Not Ranked : 0 score A 70d rmm would be enough for about 90% of the cars on this forum, imo. I just don't get the push for guys to throw such stiff mounts on these cars when most of them only see normal day to day driving.
__________________ 2013 CWP - HPFP - 80d RMM - 3.5" INTAKE - CAT LESS EXTENDED DOWN PIPE - 3PORT - METH/WATER INJ D03 [SIGPIC][/SIGPIC] First 11 sec stock turbo MS3: 1.688, 7.676 @ 91.71 11.977 @ 113.85 |
| The Following User Says Thank You to MZRSPEED For This Useful Post: | Easter Bunny (02-18-2015) |
Groans: 549
| Not Ranked : 0 score Vibes make your penis bigger Sent from my LG-MS770 using Tapatalk
(Thread Starter) | Not Ranked : 0 score Before we even made the video I was discussing @Gr8Speed; that it would not be scientific. Too many variables and very subjective if you wanted the driver to give their opinions on the ability to control the vehicle. People can make their own conclusions as far as the effectiveness of motor mounts on torque steer. It's obvious both cars drastically changed direction and anyone being careless could get into trouble. Was a fun project on a lazy Saturday afternoon. I think @jbmazda6; almost shit his pants my first run. He was manning the outside camera and I cut it a little close but had moment of "shit, maybe it did solve torque steer"
Was at about 50% on the about to shit your pants scale
__________________ JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers Sponsored By: JamesBaroneRacing.com | |
![]() Join Date: Jan 2013 Location: Buffalo/NYC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
If I were to do it again, I would just go 70 all around. I would be very curious to know whether the 88a vibes more than all three mounts at 70 duro. Thanks for attempting the comparison guys, we knew it wouldn't be perfect, but thanks for trying.
__________________ Current 2013 Ingot Silver Focus ST - ST3 Injen: 3in SES Exhaust TT Tips SOLD! 2008 Sunlight Silver MS3: BNR: S3 V2 Cobb: V3 AccessPort CNT: Catted Downpipe / Cat-Back Exhaust Damond Motorsports: RMM Eibach: Prokit HTP: 3" Intake System (One-piece) JBR: Rear Sway Bar Koni: Yellows MAC: 3-Port EBCS Morimoto: HID Kit / The Retrofit Source clear lens swap. NATOR FMIC: Cx Racing piping / Treadstone TR8 | |
| The Following 2 Users Say Thank You to alextheguineapig For This Useful Post: | CaptObvious75 (03-31-2014), MZRSPEED (03-30-2014) |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
| Not Ranked : 0 score Interesting. Still not completely convinced it doesn't help with torque steer at all. I will say it isn't eliminated, but I think it definitely help a little. That "help" I felt could have very well just been that the car was driving a little smoother with the mounts (better shifts, smoother power delivery, lack of wheel hop) so it gives the illusion that there is an effect on torque steer, just because of the ability to control the car better. Don't know if that made any sense but its Monday morning so cut me some slack haha.
__________________ https://www.youtube.com/user/JustinBieberVEVO |
"The Trilogy 70duro is less NVH than the just the 88duro RMM lol."
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
| The Following 2 Users Say Thank You to JgamB For This Useful Post: | alextheguineapig (03-31-2014), Easter Bunny (02-18-2015) |
__________________ 3rd rebuild on the way...maybe... | |
![]() | | #19 | ![]() |
![]() Join Date: Dec 2013 Location: Surprise, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 368
| Not Ranked : 0 score Somehow this topic slipped by me. Has anyone added a Lower control arm bar in their speed? I have the Corksport one with 80a RMM and Tranny insert and there is absolutely no need for me to deathgrip my steering wheel.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Video it and throw it up. Eliminating torque steer would be nice.
![]() | | #21 | ![]() |
| Banned ![]() Join Date: Jan 2015 Location: Space Mountain, Honey
Rep Power: 0 ![]() ![]() Thanks: 142
Groans: 30
Groaned at 132 Times in 57 Posts
| Not Ranked : 0 score I don't know how it could control torque steer. It's not a product of engine movement, it's a product of the engine being held in place and not spinning like a gyroscope. If Mazda could have found an easy fix, they would have. Ford and GM have designed new suspension layouts to try to deal with it, with moderate success. It's much worse, meaning more violent, in older cars from the early to mid-90s with crappy automatic transmissions under full throttle kickdowns, even with only half the torque of the Mazdaspeeds, because it's all or nothing at the pedal. |
![]() | | #22 | ![]() |
| Not Ranked : 0 score I was just out on my lunch break to Taco Bell, when I first realized that I dont notice any torque steer and I had been stepping on it. That's what made me Search 'torque steer'. What were the conditions of the runs? Rolling speed, gear, when you gunned it, lightly holding steering wheel vs not holding it with hand at the ready? I can do an internal shot, but not an external as all I have is my iPhone to record. Lemme know.
![]() | | #23 | ![]() |
Groans: 30
Shown extensively here: http://youtu.be/OISFrU4I_7s?list=PLA97180860447EE6A | |
![]() | | #24 | ![]() |
Groans: 549
| Not Ranked : 0 score WTF is a lower control arm bar?
![]() | | #25 | ![]() |
Groans: 30
![]() | | #26 | ![]() |
| Not Ranked : 0 score Ok. I just took a break from work and took the best vid I could with what I have: my iPhone. I had to prop my phone up in my passenger seat, as holding it would be way too zoomed in. Lame iPhone Camera. On the first run, you can't really see that I am not holding the wheel. But I assure you that I am not. The second run, you can see my left hand is open and away from the wheel until I noticed movement. I was on a two lane street so I had to be careful. I started rolling in 1st gear, til I hit 3000rpm's then gunned it to 6000. Hardly any movement. When in he rpm range did the steering wheel jerk on the two cars in the original vid? YouTube greatly destroyed the resolution and I uploaded as HD I'll try to get someone to hold a cam in the passenger seat as soon as possible to show this. But this is all I have for now.
| The Following User Says Thank You to Atticaz For This Useful Post: | Cheapspeed (02-17-2015) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score I thought the same thing when I first heard about them. Product Release! CorkSport Mazdaspeed 3/Mazda 3 Front Lower Arm Bar | CorkSport Mazda Performance - Blog
![]() | | #28 | ![]() |
Groans: 549
| Not Ranked : 0 score Someone on mazda3forums makes those for something like $50/ea
![]() | | #29 | ![]() |
| Not Ranked : 0 score Yeah, they are not difficult to make, if you got the means. 👍
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score Torque steer has more to do with unequal halfshaft lengths in FWD cars. Here's an article. What the heck is torque steer? (ABCs of Car Tech) - CNET That being said, I'd like to see pictures of this mod.
| The Following 3 Users Say Thank You to Cheapspeed For This Useful Post: |
![]() | | #31 | ![]() |
According to this link (below), bad alignment can cause torque steer as well. My alignment is slightly off, from when i replaced my front swaybar bushings. So perhaps bad alignment is counteracting the torque steer in some way. My last torque steer test attempt (not recorded) resulted in my steering wheel actually torquing left. That should be impossible, yes? I must admit, before my alignment got all out of whack, my torque steer was less, just not this much less. After I get an alignment, I will truly know. That won't be for a while though. I still neEd to do some work and don't want to waste the money. Torque Steer: Causes and Cures
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD | |
![]() | | #32 | ![]() |
Groans: 30
![]() | | #33 | ![]() |
![]() Join Date: Nov 2013 Location: Killeen, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 724
| Not Ranked : 0 score @Atticaz; are you tuned, or on ots map, or anything at all? I only bring this up because the orginal video featured 2 cars that were tuned, which DOES NOT restrict boost in 1st gear like the stock map, etc. This may, or may not play in to tq steer, especially in 1st gear. Just my .02 cents.
__________________ 08 TR MS3 - totaled and stocked out 1-5-2014 Daily Driver - 2016 WRX w/STI lip kit 2009 CWP MS3 1-23-2014 CXRacing FMIC with TR8 Core /// HKS Turbo Timer /// 6000k HIDs /// Yellow Fog Covers /// Cobb SRI /// Ultimate Racing TBE /// White Avid 21 18x8.5 Wrapped In Kuhmo 225-40-18s /// Short Throw Shifter /// Kozmic Motorsports EGR Delete /// Corksport HPFP internals /// CS Front Sway Bar /// /// JBR RMM, TMM, and PMM (all 80a) /// Slotted Rotors /// CS Foglight Kit /// CS License Plate Bracket /// CS Bypass Hose /// Rolled Fenders /// JBR Weighted Red Shift Knob /// Cobb AP //////![]() |
![]() | | #34 | ![]() |
Groans: 30
| Not Ranked : 0 score The Mazdaspeed3 is mentioned in this C&D article as the modern poster child, but the article explains the geometry changes Ford and GM have recently implemented, basically moving the steering axis outside the strut to the hub with a new knuckle. If you watch the Motor Trend Head to Head video I linked above, you can see that the Focus ST still suffers from it anyway, and they've used the brakes to lessen it in that car. Ford RevoKnuckle and GM HiPer Strut Explained - Tech. Dept. - Car and Driver With that, keeping wheel offset more positive will also help. With a 52mm offset on the stock wheels, Mazda seems to have maxxed that idea out already, and it's hard to find aftermarket wheels with offsets over 45mm. Last edited by license2ill; 02-18-2015 at 06:27 AM. Reason: added offset |
![]() | | #35 | ![]() |
| Not Ranked : 0 score I'm a tire pressure nazi. They are all set to to the pressures stated on the door label. 34 front /32 rear.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 02-18-2015 at 07:19 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to Atticaz For This Useful Post: | hatchedspeed3 (02-18-2015) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score ^^IM glad that came to light. Definately make another video when 1st gear boost restrictions are lifted. Im curious to see how much of a difference it is.
| The Following User Says Thank You to hatchedspeed3 For This Useful Post: | Atticaz (02-18-2015) |
![]() | | #37 | ![]() |
![]() Join Date: Apr 2013 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,526
| Not Ranked : 0 score Interesting. Not sure how I missed this thread in the past, though personally I think all "torque steer is crazy" really isn't proved or unproved based on flooring a car with your hands off the wheel. I've never done that in any car I own, my hands are always on the wheel. We did have several track and drag guys that loved our lower traction bar. Said it really helped keep the wheels from hopping. Of course, in my opinion... torque steer is remove completly with the simple fix of... intake, exhaust, downpipe, intercooler, rmm, pmm, tmm, lower control arm bar, mid chassis brace, rear chassis brace, coilovers, hpfp, accessport, rear swaybar, front swaybar, front strut bar and of course.... short shifter, shift knob, hoodscoop, carbon wing, led lights, fog lights, and eyelids. MORE MODS = LESS TORQUE STEER! It's a FACT!
__________________ SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount - CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit 1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3? [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to SpencerC For This Useful Post: | hatchedspeed3 (02-19-2015) |
![]() | | #38 | ![]() |
__________________ 08 TR MS3 - totaled and stocked out 1-5-2014 Daily Driver - 2016 WRX w/STI lip kit 2009 CWP MS3 1-23-2014 CXRacing FMIC with TR8 Core /// HKS Turbo Timer /// 6000k HIDs /// Yellow Fog Covers /// Cobb SRI /// Ultimate Racing TBE /// White Avid 21 18x8.5 Wrapped In Kuhmo 225-40-18s /// Short Throw Shifter /// Kozmic Motorsports EGR Delete /// Corksport HPFP internals /// CS Front Sway Bar /// /// JBR RMM, TMM, and PMM (all 80a) /// Slotted Rotors /// CS Foglight Kit /// CS License Plate Bracket /// CS Bypass Hose /// Rolled Fenders /// JBR Weighted Red Shift Knob /// Cobb AP //////![]() | |
| The Following User Says Thank You to hatchedspeed3 For This Useful Post: | Agent_Orange (02-19-2015) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score My air freshener does. So cams have to. lol.
![]() | | #40 | ![]() |
| Not Ranked : 0 score ah. Now I understand Everything. lol
| Torque steer corretion | poisonouschimp | Gen2 MS3 General Discussion | 29 | 01-14-2013 12:12 PM |
| Torque steer? | Limeybastard | Gen2 MS3 General Discussion | 38 | 11-21-2012 09:58 AM |
| Torque steer - Is my car broken? | Cambelious | 2010 MS3 - Engine, Transmission & Driveline | 31 | 12-07-2009 09:35 AM |
| Torque Steer | FWD=WWD | MazdaSpeed 6 - Engine, Transmission & Driveline | 10 | 06-02-2009 12:53 AM |
