 Old 05-05-2009, 07:44 PM   #1
richie b 74's Avatar
Posts: 84   (View Stats)
richie b 74 will become famous soon enough
Default turbo questions
im shore this has been asked a few times but i searched it and couldnt find anything. whats the inlet size of the stock turbo? also whats trim size? ive heard it before but dont know anything about what it is. im a newb when it comes to turbos.
thanks
richie b 74 is offline   Reply With Quote
 Old 05-05-2009, 08:01 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
thanks
The inlet is ~2".
The turbo is a borg warner K04, I've got no idea what the trim size is, it's so small I never bothered to find out...
 Old 05-07-2009, 05:45 PM   #3
one more question. how much does it limit boost in first and second gear?
 Old 05-07-2009, 05:53 PM   #4
is the turbo smaller than a TDO4-16g? thats pretty small, i think thats like 5cm. pretty bad.
 Old 05-07-2009, 07:18 PM   #5
Groans: 60
I've got an MS6 not an MS3 so I don't know what the pcm in the MS3 limits boost to.
The TDO4-16g can flow near 34 lbs/min, the K04 is closer to 32 lbs/min, so it's just a little smaller..
 Old 05-08-2009, 04:32 PM   #6
o cool thanks i was just curious
 Old 05-21-2009, 07:16 PM   #7
im not really shure how boltons effect the turbo, so i want to ask a few more questions if you dont mind. if you get say a cai or sri this shouldnt effect the efficiency range right? the turbo doesnt have to spin faster but is dealing with more air. how does a dp effect it? i just dont understand if our turbo is already too small how do you make gains with airflow enhancing mods.
 Old 05-21-2009, 07:26 PM   #8
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
Groans: 38
gains with airflow mods are simple, the air can flow with ease so the turbo can make boost easier and many times faster as well because it doesnt have to suck air in through a small ass intake or push out exhaust through a small catted/blocked DP. it is free flowing so the energy is all focused on spinning the turbo up for powah
bykeryder4life is offline   Reply With Quote
 Old 05-21-2009, 08:15 PM   #9
Groans: 60
Any mods you do to the intake/exhaust will effect the VE of the motor allowing the motor and turbo to flow more CFM for a given pressure ratio and rpm, allowing the turbo to reach boost onset and peak boost earlier.
This increase in VE is why you can still see significant gains even when your nearing the choke line of the compressor. The turbo isn't necessarily doing more work, the engine/turbo system has just become more efficient..
 Old 05-22-2009, 05:21 PM   #10
so its the same as an NA motor then just getting rid of restriction. could you tell me if the turbo runs at the same temp with these mods? or is it possible it runs cooler? so the wastgate will still keep the tubo in its efficency range.
 Old 06-07-2009, 12:40 PM   #11
i know i must sound like a complete noob right now but i want to understaind this better. lets say you get the cai, all your doing is suppling the turbo with more air so it can make boost easier, right?
ive read that you dont want to work the turbo harder on these cars as the turbo is too small for the size of the engine. so basicly the turbo spools faster and around 5500-6000 the engine can use more air than the turbo can produce and it becomes a restriction.
if the wastgate is the same and you raise the ve of the engine does that mean you run out of power at a lower rpm?
also what is overboosting?
 Old 06-07-2009, 01:55 PM   #12
Zeya's Avatar
Posts: 992   (View Stats)
Zeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the world
A good place to start reading is this awesome guide by Demi:
http://www.mazdaspeedforum.org/forum/foru...ers-guide.html
2008 MS3 GT ~ Cobb SRI, Cobb turbo inlet, CPE rear motor mount, Koni FSD shocks
Zeya is offline   Reply With Quote
 Old 06-08-2009, 06:55 PM   #13
thanks that real basic stuff. how about this, should i have any problems with the car if i get a cai and a dp and maybe a tbe. will i need a fuel pump? can i run the stock tune or does shit hit the fan.
GT Series Turbo Questions. JimmyMac MazdaSpeed 3/6 - Turbo Induction 71 11-07-2013 05:47 PM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
MS6 Turbo back exhaust Questions Mazdagoat324 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-16-2009 03:33 AM
Questions about porting the WG on the stock turbo Lymerock MazdaSpeed 3/6 - Turbo Induction 2 11-30-2008 02:49 PM
Upgraded/reworked turbo questions red07 Mazdaspeed3/6 General Discussion 5 11-08-2008 12:08 PM
Page generated in 0.33813 seconds with 23 queries
