 Old 04-22-2008, 02:26 PM   #1
ptperformance's Avatar
Posts: 4,123   (View Stats)
Default Turbo upgrade pictures...
Got the smaller wheel upgrade, shipping it out soon to a lucky tester.
27% greater flow with a clipped exhaust wheel. The testing has been done for compressor to turbine pressure ratios and the clip has been done in results to that testing (don't ask how much clip was done because will not tell you). Testing to get this done is very expensive and I don't want the others trying to copy us.
This is the smaller unit that flowed enough for 350 WHP based on CFM, but we have no idea how this is going to respond to the DI motor. If the eff from DI vs standard injected motors is consistant and crosses over to the turbo's out put, 370 should be possible to the wheels with this first of 3 upgrades we have planned.
I hope you guys enjoy the pictures. I have several updates planned with this so stay tuned to the big wheel thread. Thanks.
MORE DETAILS IN WHAT WE HAVE FOR YOU THE MS3/6 MARKET
STOCK WHEEL: INDUCER 45 MM / MAJOR 56MM
VERSION 1 : INDUCER 48.0 MM / MAJOR 60 MM 35 LB. PER MIN.
VERSION 2 : INDUCER 48.3 MM / MAJOR 70MM 37 LB. PER MIN.
VERSION 3 : INDUCER 48.3 MM / MAJOR 76MM 40 LB. PER MIN.
VERSION 1 & 2 AVALIBLE NOW!
VERSION 3 NEEDS TO BE TESTED IN LATE MAY.
Testing is getting done right now for the version 3, we hope to have more info on this before the end of June but the first 2 options are running the stock and upgraded pumps out of fuel near 24 psi. The stocker appears to be 28 to 30lbs per hour, so each lb you gain should be 10 to 15 WHP added to the car. 35lb wheel should make 350 WHP, 37lb 370WHP, 40lb 400WHP... you see what I am getting at. I will have more info and test data when we are all done testing the 3 versions.
File Type: jpg parts for the MS3 and other items 013.JPG (165.9 KB, 182 views)
File Type: jpg parts for the MS3 and other items 012.JPG (163.5 KB, 201 views)
File Type: jpg parts for the MS3 and other items 014.JPG (148.0 KB, 148 views)
 Old 04-22-2008, 02:27 PM   #2
Forgot to add that the inlet is ported out to max so the volume is there for the larger compressor wheel.
 Old 04-22-2008, 02:38 PM   #3
digitaljedi's Avatar
Posts: 1,222   (View Stats)
digitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the world
Groaned at 51 Times in 34 Posts
couple questions.
1. What is the cost, estimated if you aren't sure yet.
2. Will we have to run an upgraded fuel pump to use this turbo?
I am not really to excited about the current fuel pumps that are available, I want to get a look at yours before I go that route.
3. Where do I sign up? lol.
Great work John.
2008 speed3- FOR SALE!!!!!!!!!!!!!!!!!! SEE HERE!
http://www.mazdaspeedforum.org/forum/forum/f665/2008-speed-3-sale-177096/
2000 Honda S2000(track car)
digitaljedi is offline   Reply With Quote
 Old 04-22-2008, 02:49 PM   #4
kraz3y's Avatar
Posts: 193   (View Stats)
kraz3y has a spectacular aura aboutkraz3y has a spectacular aura aboutkraz3y has a spectacular aura about
Originally Posted by digitaljedi View Post
couple questions.
Great work John.
+1
kraz3y is offline   Reply With Quote
 Old 04-22-2008, 02:57 PM   #5
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
is this mine? lol i still have no clue whats going on! Anthony alive?
Laloosh is offline   Reply With Quote
 Old 04-22-2008, 03:11 PM   #6
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
What pre-turbine pressure/intake pressure ratio are you trying to stay below? I run about 2.2 on my Mustang, but I have no idea what is typical for stock or modded MS3s.
Any idea on lag with the clippage? I wouldn't mind a little slower spool due to fuel limitations down low...
 Old 04-22-2008, 03:21 PM   #7
shadrag's Avatar
Posts: 7   (View Stats)
shadrag will become famous soon enough
Purdy, I didn't realize that you were actually increasing the compressor inducer size, nice. What's the exducer look like on these beauts?
shadrag is offline   Reply With Quote
 Old 04-22-2008, 03:29 PM   #8
We are trying to keep them under 2 to 1 due to the smaller turbine housing and the small shaft we are dealing with. The stock pressures are over 2.9 and on one pass we hit 3 to 1 in 5th gear down low, not good for turbo life.
The clip seems to add about 200 RPM of lag but the boost curve looks great and seems to add 2 to 4 psi on the top end for boost hold. Its a + + if you ask me.
 Old 04-22-2008, 03:30 PM   #9
Inducer and exducer on this one. It moves way more air then the stocker. I will try to get some pictures up of the wheel when we have a few more running on the streets.
 Old 04-22-2008, 03:32 PM   #10
Did you send me your core yet? Thats about the only way you will be getting one.... LOL.
I have another one on the way back to me and there are 4 more getting done as I type this. I should have everyone taken care of on these in the next 2 weeks.
 Old 04-22-2008, 03:35 PM   #11
Laloosh's Avatar
no, mine is sitting in my garage. Last i heard anthony was suppose to send me his as he is having problems. not to sound like a dick but we were also suppose to take car of other matters that we didnt, so untill we do im not sending anything when im unsure of whats even going to happen to it.
 Old 04-22-2008, 03:36 PM   #12
couple questions.
Great work John.
The turbo upgrade is $649 and the tubine housing work (not pictured) is $199. The finished units will be all ceramic and the turbine housing will only come in a ceramic finish. $799 if you get them both together at the same time.
I recommend a pump upgrade for every MS3 or 6 due to the problems that many are having with the performance falling off up top on the stock turbo. You can use this turbo on the stock pump (we have done this) but you need to keep the boost levels at stock, do not raise them more then 2 psi because the car leans out really bad.
Send me a core and thats your ticket in.
Keep an eye out for cores for me and that will get you an "IN" with me. Thanks.
 Old 04-22-2008, 03:39 PM   #13
I have not talked to him so I hope you get that turbine housings soon???
I have the CAT back sitting here if thats what your talking about, DP is jigged just waiting for some final parts to show up so I can start on them. I hope thats what your talking about????s
 Old 04-22-2008, 03:39 PM   #14
jlarson1983's Avatar
Posts: 887   (View Stats)
jlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the world
i cant wait!
jlarson1983 is offline   Reply With Quote
 Old 04-22-2008, 03:59 PM   #15
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
sub
 Old 04-22-2008, 04:03 PM   #16
Eth/Meth Junkie
cld12pk2go's Avatar
What exhaust components were used when you saw 2.9-3.0 ratio on "stock pressures"?
I know from experience the turbo back can have a hell of an influence on that pressure ratio! Tks I dropped from ~4:1 to 2.2 by going from a restrictive cat back to a bullet off the downpipe. :-)
 Old 04-22-2008, 04:04 PM   #17
Laloosh's Avatar
im not even talking about the TBE. Im just simply talking about the turbo. What it is that im getting and paying for. Im sending you two cores.
options so far: I send you a core u do what u do, send it back, i put it on and send you the stocker thast on my car to keep.
2: I get anthony's(which i have heard nothign about for him) and send you the core and the stocker thats on my car.
3: I don't even know what it is im getting, which option, port work? wheel? lol im completly lost, hence the reason im hesitant to send out my stuff.
I need to be filled in on to whats going on and what im actually getting, how am i testing it? Track dyno both? Alot of "ifs" I have track times and i have dyno times. 302whp 336wtq and 12.90 @ 111 are the "bases".
 Old 04-22-2008, 04:14 PM   #18
lol i am wondering where all these extra turbos came from, how does the average person have one laying around?
 Old 04-22-2008, 04:16 PM   #19
Laloosh's Avatar
i bought a core and the one that is on my car. Most who went BT have gotten rid of their stocker and many of us picked them up for a price.
 Old 04-22-2008, 04:21 PM   #20
TBE all 3".
The pressure is crazy high just like on the SRT4 turbo. 90% of it comes from the poor design of the turbine housing. Its a balance between clip, thrust pressures and pressure ratios. It takes time to get it right but when you do, damn it makes for a great driving turbo.
 Old 04-22-2008, 04:25 PM   #21
so in theory we should be able to get more out of these turbo's at lower boost? i was running 20-21psi but with this i can run like 18-19psi and make more power?
 Old 04-22-2008, 04:54 PM   #22
Im so in, time to request overtime :thumbsup:
 Old 04-22-2008, 05:21 PM   #23
fqspd3's Avatar
Posts: 136   (View Stats)
fqspd3 has a reputation beyond reputefqspd3 has a reputation beyond reputefqspd3 has a reputation beyond reputefqspd3 has a reputation beyond reputefqspd3 has a reputation beyond reputefqspd3 has a reputation beyond reputefqspd3 has a reputation beyond reputefqspd3 has a reputation beyond reputefqspd3 has a reputation beyond reputefqspd3 has a reputation beyond reputefqspd3 has a reputation beyond repute
subing
(fqspd3) as in F**cken quick speed3
fqspd3 is offline   Reply With Quote
 Old 04-22-2008, 05:33 PM   #24
Laloosh's Avatar
jon, you said in a previes thread that your reworked stockers made 30 whp on stoock boost and probably 50-70 on raised. You also said you were running out of fuel on the big wheel set up that broke and were making very good power. Do you have any proof of this? Dyno numbers?
 Old 04-22-2008, 06:07 PM   #25
 Old 04-22-2008, 06:38 PM   #26
ultraspeed619's Avatar
Posts: 268   (View Stats)
ultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the world
SWEET!!! subbing and hoping one of them them turbo's are heading my way in 2 weeks! thanks fo r the update, john!
MAZDASPEED6
Engine: Cobb SRI/AP | CPE FMIC/DP/MM/HPFP | MagnaFlow 3in CBE | HKS TwinPower Ignition | Denso plugs |
Suspension/Wheels: SSR GT10 19x8 +37 | RPM Street Springs | AutoExe F/R braces | WhiteLine RSB | GT Spec Ladder Bar/Trailing Braces |
Exterior: SSG AE Lip Kit | HomeDepot Front Lip Mod | JDM Tailights | Black Emblems |
Interior: AutoExe ShiftKnob | TWM STG2 | ProSport BoostGauge | Dashawk |
ultraspeed619 is offline   Reply With Quote
 Old 04-22-2008, 07:03 PM   #27
mazdaspeedjay's Avatar
Posts: 99   (View Stats)
mazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the world
I'm in talks with john right now. My car is basicly stock so i will be trying to send him a core this week. once i get it i will go be going back to the dyno for him to get some numbers which should make everyone happpy since i still have stock TMIC and DP and exhaust. just a Cobb SRi and Turbo x's Test pipe thats all.
My car: 2008 Mica black Mazdaspeed3 sport model:
-Currently Serving in the United States Marine Corps. as a Machine Gunner ( 0331 ):
-Afghanistan southern heldman province Oct.09'-May.10'
MODS: COBB Short air intake, ONE OF THE FIRST PEOPLE TO HAVE THE ACCESS PORT BETA TESTER, Cobb access port, CP-E Catted Down pipe ( now no cat.'s ), Custom Exhaust,Turbo X's Hybrid BOV , Coil Pack spring mod, MY Very own Intercooler Cover mod, 8000K HiD Head Light upgrade, Stri electric boost gauge, EGT and turbo timer, AEM UEGO Wide band A/F Gauge, CP-e Dog bone lower mount with race bushing, Red Calibers, yellow fog lights. CP-E fuel pump upgrade.
mazdaspeedjay is offline   Reply With Quote
 Old 04-22-2008, 09:39 PM   #28
MStempted's Avatar
Posts: 199   (View Stats)
MStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the world
I have stocker laying around that i want to rework, i just need to get some $$$.
MStempted is offline   Reply With Quote
 Old 04-23-2008, 01:10 PM   #29
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
looks gorgeous.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
 Old 04-23-2008, 01:18 PM   #30
Originally Posted by mrlilguy157 View Post
looks gorgeous.
Your just excited that this will help you move more fuel pump....
 Old 04-23-2008, 04:43 PM   #31
kraz3y's Avatar
hmm whats the core fee for the people who dont have stock turbos lying around =P
 Old 04-23-2008, 05:22 PM   #32
MStempted's Avatar
wait.... so how much is it to do all the good stuff if i send you my stocker?
|| CP-E CAI || CP-E Inlet || CP-E FMIC || CP-E Catback || SU TurboSmart BOV || PG Turbo Manifold || CDI/PG Fuel Pump internals+spring || Denso 1step colder plugs || ATP DP || ATP FCD || ATP CEL trick || TWM stage2 SS+bushings || AWR Engine mount || SU rear diff mount || TT rear diff Rear mount || Whiteline anti-sway bar || AWR Endlinks || BC racing CO's || matt black OZ Ultraleggeras + Kumho ASX || Cobb AP || VEI boost || VEI oil Pressure/Water Temp. || AEM wideband || ApexI Turbo Timer || N2MB WOTbox || SM catchcan || BS delete+baffle kit || Spin on Oil filter conversion + Prosport sandwich ||
Other: Other mods are BS!
Sponsored by: STREETUNIT.COM check them out :thumbsup:
 Old 04-23-2008, 07:45 PM   #33
lol not at all. PTP has their own fueling stuff coming to market soon enough in addition to what I offer now. The turbo really does look wonderful. If I cared about a warranty I definitely would go the reworked route. lots more power and it all looks the same to the dealer.
 Old 04-24-2008, 11:01 AM   #34
Yes it looks the same only down side is if they try to replace it under warranty if they don't notice right off the bat by looking at the turbos side by side then you are out a upgraded unit. I work for a dealer so i'm a little special because i'm able to do all my own work warranty and regular stuff since i work as a mazda tech for a mazda dealer. but still i mean this whole hearted if i had my way everyone would be allowed to mod their cars and not have to worry about warrantied voids or being voided and not have to worry about putting their car back to stock to have it worked on.
Anyone in Maryland baltimore area hit me up if you need stuff done and i'll help you out as best as possible i think this warranty void police are now getting to trigger happy and it's not fair to the average customer or consumer. It's so stupid cause when i goto training and talk to the higher ups at mazda when i'm at MNAO head quarters or their sister stations they mostly say if the aftermarket part didn't cause the problem or problems then who cares and they're getting sick and tired of getting calls from service people and managers bitching that the car has after market parts. Bottom line this is out of their mouths if the part isn't causing the problem then it shouldn't void the warranty no matter what and the car should be fixed and repaired under warranty just like everyone else. I laughed and told them thats not the case and i have many horror stories of friends and other people getting warranty voided because of stupid stuff.
Anyway sorry i rambelled on. PT is nice but LIL'Guy is the O.G> of CDFP's so i'm still stickin with him for any of mine or friends cars i work on that get upgraded pumps. Keep doing your thing play'a
 Old 04-24-2008, 11:39 AM   #35
JumpingJackson's Avatar
Posts: 967   (View Stats)
Probably shouldnt be pitching competitors fuel pump in PT Performances own subforum that they paid for.
 Old 04-25-2008, 09:33 AM   #36
Dyno's are on the way to me now. I will post them when I have them. Thanks.
 Old 04-25-2008, 09:34 AM   #37
$700 right now. Thats how much I have to pay for new ones right now. Cores are far and few between right now, so new units are about all I can get for you guys.
 Old 04-25-2008, 09:35 AM   #38
$599 for the turbo
$199 for the turbine housing
 Old 05-05-2008, 03:04 PM   #39
any new updates? i can't wait to get this i have been without my car for over 2weeks now. i get it back tomorrow finally
 Old 05-05-2008, 07:22 PM   #40
winniep's Avatar
Posts: 333   (View Stats)
winniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the world
So without a core, total price will be $1499? Also, for those of us with blown seals, will that issue be taken care of? My MAIN concern is not smoking, so that will pretty much make or break the deal for me . Also, how are you coming on those CDFP upgrades?
The fastest MS3 in the whole garage...
winniep is offline   Reply With Quote
Post your autox pictures Laloosh Auto-X / Road Racing / Time Attack 321 12-12-2019 02:33 PM
Installed my carbon fiber dash kit, pictures inside Death-From-A-Mile MazdaSpeed 3/6 - Appearance 26 04-26-2009 09:25 AM
Stock turbo upgrade mdogg MazdaSpeed 3/6 - Turbo Induction 20 03-31-2008 02:14 PM
Page generated in 0.58562 seconds with 36 queries
