Like Tree3Likes
 Old 07-22-2011, 07:46 AM   #1
irishking03's Avatar
Posts: 2,136   (View Stats)
Default Turbo XS FMIC INSTALLED!
Title says it all. Took me about 4.5 hours to do cause it was HOT AS AFRICA out. But came out good.
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
The Following 15 Users Say Thank You to irishking03 For This Useful Post:
08.5MS3 (07-23-2011), 4G63 (08-08-2011), abovie3 (07-23-2011), AZSPEED3 (08-10-2011), Blackspeed (07-22-2011), Broxer (08-04-2011), Don06speed6 (07-23-2011), faeker (07-24-2011), I Love Brownies (08-08-2011), kmac (07-22-2011), mazpro (08-11-2011), MGM_GT3 (07-26-2011), MS3-a(sore)ASS-rex (07-22-2011), ridenfish39 (07-22-2011), zpele (07-22-2011)
 Old 07-22-2011, 01:55 PM   #2
Rich-PMS's Avatar
Posts: 1,461   (View Stats)
Rich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the world
Groans: 68
Cooler in PA than in NJ. 117 according to my cars amb temp.
Rich-PMS is offline   Reply With Quote
 Old 07-22-2011, 02:00 PM   #3
wankular's Avatar
Posts: 4,343   (View Stats)
Looks good, that's a nice wide core. Now lose that rear TMIC bracket.
And my car's ambient temp read 124. temp noobs.
2009 MS3 sport MGM
The Following 2 Users Say Thank You to wankular For This Useful Post:
86AmishMs3 (07-23-2011), MS3inDC (08-11-2011)
 Old 07-22-2011, 02:45 PM   #4
461_SS's Avatar
Posts: 1,160   (View Stats)
461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world
That intercooler is sex
461_SS is offline   Reply With Quote
 Old 07-22-2011, 03:08 PM   #5
kmac's Avatar
Posts: 1,792   (View Stats)
Looks good, that's a great i/c imo
 Old 07-22-2011, 03:24 PM   #6
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
any major complications or fitment issues?
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
 Old 07-23-2011, 08:09 AM   #7
Hmmm. No major complaints. Just follow the directions and you should be golden. I have to adjust the HKS SRI a bit just because there is fake me out bolts on the back of the filter that are rubbing on the "pipe". Yes rubbing on the pipe. If you dont have the right tools it will def slow you down. I had to use the basic OEM clamp that is attached to the silicone coupler and turbo because I wasnt able to get a socket to turn very far when using the supplied T-Bolt Clamp. I love it though. I just need to get back under the car and loosen the 2 couplers holding the core on because its not lined up to bolt to the bottom of the car. But other than than its golden. Now I just need a Tune.
You mean the bolt sitting in the back looking like an errect penis.
2012 Liquid Silver
Cobb AP
Last edited by irishking03; 07-23-2011 at 08:09 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-23-2011, 08:12 AM   #8
MS3inDC's Avatar
Posts: 3,070   (View Stats)
MS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the world
Groaned at 56 Times in 37 Posts
How hot is africa...?
cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp
jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob
ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com
311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM]
12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14]
I would wear a pink unicorn shirt, and still call someone a faggot. Since when did MSFers begin to give fucks?...
MS3inDC is offline   Reply With Quote
 Old 07-23-2011, 08:42 AM   #9
Davy180's Avatar
Posts: 256   (View Stats)
Davy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the world
It's actually winter time in Africa right now so the weather is real nice.
Davy180 is offline   Reply With Quote
The Following User Says Thank You to Davy180 For This Useful Post:
 Old 07-23-2011, 09:12 AM   #10
BReif61's Avatar
Posts: 403   (View Stats)
BReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the world
Looks good. Shouldve replaced your moustache bar while you were in there.
-Brad
BReif61 is offline   Reply With Quote
 Old 07-23-2011, 09:34 AM   #11
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
That intercooler is fucking huge!
And yes, it's winter in Africa, nice try!
 Old 07-23-2011, 09:56 AM   #12
Well it was hot like an African Summer..
2012 Liquid Silver
Cobb AP
 Old 07-23-2011, 08:19 PM   #13
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Tired of all these nubs complaining how hot it is. Fuck, story of our lives for half the year.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
AZSPEED3 (08-09-2011), wankular (07-25-2011)
 Old 07-23-2011, 08:24 PM   #14
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
Nice quality looking kit, I still don't get why the bpv is placed on the hot pipe though.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
 Old 07-23-2011, 08:43 PM   #15
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
with the routing it is easier i think. if you see it in person it would of been harder to do the cvold pipe like most kits. this kit is backwards on the core, meaning cold pipe on passanger side of core and hot pipe on driver. versus cold on driver hot on passanger. it works where it is and i have no issues and its a little easier to access the bolts.
 Old 07-23-2011, 09:31 PM   #16
mzr0818's Avatar
Groans: 221
Shit looks good.
Not winter in all of africa. Only below the equator. I just gone back from there and it is mother eiffin hott...
irishking03 likes this.
EMWNM 2013
2008 mazdaspeed 3 true red
Tuned by Nishan
 Old 07-24-2011, 08:13 AM   #17
I've noticed the BOV doesnt go off as much as it did when I had TMIC. I almost have to lay more than 2-5psi before it gives me a sign that it works. LOL.. But I keep that to my advantage. Was heading to my shore house in wildwood and about 3 miles from my house I had a older accord come flying up on my right. So as we got to light I let him peel off. Played with him (NO HOMO) for about 3 lights. About after the 4th light I ripped him apart and the look on his face when we got to the following light was like "WTF" after that I was able to drive normal to the shore.. DAMMM RICERS..
2012 Liquid Silver
Cobb AP
 Old 08-04-2011, 02:05 PM   #18
booostin's Avatar
Posts: 41   (View Stats)
booostin is a glorious beacon of lightbooostin is a glorious beacon of lightbooostin is a glorious beacon of lightbooostin is a glorious beacon of lightbooostin is a glorious beacon of light
Looks really nice... how much $ did that run you?
booostin is offline   Reply With Quote
 Old 08-04-2011, 02:19 PM   #19
mysleeper6's Avatar
Posts: 204   (View Stats)
mysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the world
Shit looks good.
Yeah, I was in Egypt last June. 115 F. Definitely not winter.
mysleeper6 is offline   Reply With Quote
 Old 08-04-2011, 04:31 PM   #20
TriO's Avatar
Posts: 676   (View Stats)
TriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the world
horey sheet that thing looks huge.... nice
how much did it set you back?
TriO is offline   Reply With Quote
 Old 08-04-2011, 11:58 PM   #21
Dahouse702's Avatar
Posts: 487   (View Stats)
Dahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the world
Badass man! One day I'll have a fmic!
2007 MS3 Black Mica-Totaled @98500 on 09/2014
Current Car...
2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK
Zoom Zoom
Dahouse702 is offline   Reply With Quote
 Old 08-05-2011, 05:24 AM   #22
$800
2012 Liquid Silver
Cobb AP
Last edited by irishking03; 08-05-2011 at 05:24 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-05-2011, 06:33 AM   #23
MSFer87's Avatar
Posts: 1,162   (View Stats)
Groans: 83
One of my favorite kits looks great!
 Old 08-08-2011, 09:48 PM   #24
mh3kgt's Avatar
Posts: 188   (View Stats)
mh3kgt has a reputation beyond reputemh3kgt has a reputation beyond reputemh3kgt has a reputation beyond reputemh3kgt has a reputation beyond reputemh3kgt has a reputation beyond reputemh3kgt has a reputation beyond reputemh3kgt has a reputation beyond reputemh3kgt has a reputation beyond reputemh3kgt has a reputation beyond reputemh3kgt has a reputation beyond reputemh3kgt has a reputation beyond repute
That thing is a monster. Looks sick
-08 Black Mica MS3-/Cobb SRI/Cobb TIP/Cobb lowering springs/18" Konig wheels
mh3kgt is offline   Reply With Quote
 Old 08-08-2011, 09:57 PM   #25
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
Favorite fmic kit for the Speed 3 wish I could have had that when I was fully bolted. Go big or go home looks awesome man
2003 Evo VIII
 Old 08-09-2011, 01:47 AM   #26
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
intercooler < meth
 Old 08-09-2011, 02:25 PM   #27
MS3inDC's Avatar
what are your BATs lookin like? whats the variance between that and your IATs?
has your tab broken yet?
is there a benefit to the bpv being on the hot pipe?
 Old 08-10-2011, 04:23 PM   #28
Originally Posted by DerekB View Post
intercooler < meth
Looking to get the devils own kit soon but I might just wait till I go BT..
Tab?? What tab do you mean?
I dont know if there is a benefit, its the first turbo + fmic I have ever had.
I have done a log recently and I will post when I get home but I think since after I installed FMIC I can def say I need a tune because my shit pops from the exhaust every now and again. Also I think my Boost is down. Im running a stage 2 sf + FMIC 93 octane and I could of swore that I should be running 20psi +/- 1.5 at wot until 6700 rpm redline which should start to drop. Im hoping DJ will get back to me to see if I can get him to do a custom map for me. I will post log later and tell me what you think.
2012 Liquid Silver
Cobb AP
Last edited by irishking03; 08-10-2011 at 04:23 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-10-2011, 05:39 PM   #29
MS3inDC's Avatar
i was just fuckin around about that tab. The one smack-dab in-front of your face when you pop the hood (holds the hot pipe to the IM). I've seen them break on other people's cars. They have a fix so I've been told, should yours happen to give.
I'm really just curious as to the logic in their kit. Huge core (not that I'm complaining), driver-to-passenger side flow, and the bpv on the hot pipe... na'mean?
 Old 08-10-2011, 06:39 PM   #30
Tab is still holding thank God. I was going to try and do some more logging but don't think I will be able to tonight so I will do one tomorrow morning on my way to work. Any specifics on what you want me to log to see what you think.
2012 Liquid Silver
Cobb AP
 Old 08-10-2011, 06:42 PM   #31
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
Groans: 65
In late, but that IC looks so sexy. Fills up the whole bumper space like a FMIC should.
 Old 08-10-2011, 08:30 PM   #32
MS3inDC's Avatar
Most specifically the variance between your IAT and BAT, any kind of pressure loss (from thecore size), and the reason for the bpv thing may not be something that you can tell from just a single log. But opinions are welcome.
 Old 08-11-2011, 07:15 AM   #33
Agree!
I did a log this morning and I will try to do another after work and post up 2 logs plus 2 from the other day. The only thing that concerns me is I am running a stage 2 sf + fmic 93 octane map on my AP and I could of swore I read on it that with this map my boost target is about 20 psi tappering down to 19 at 6700 redline +/-1.5psi. But I have noticed that when I do WOT it holds maybe 16-17 if lucky. I checked every coupler to make sure they were on securly so no boost leak.
I was thinking about heat wrapping the piping but dont know if there is much benefit in doing this.
2012 Liquid Silver
Cobb AP
Last edited by irishking03; 08-11-2011 at 07:15 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-11-2011, 07:41 AM   #34
TRex's Avatar
Posts: 3,139   (View Stats)
i would like some more people to comment on BPV on the hotpipe.......you are reseric right? or no? i have heard not to put the bpv/bov on the hot pipe unless you are vta....other wise you are putting hot air into the intake track....but then again it is pre turbo so wtf does it matter right?
 Old 08-11-2011, 08:11 AM   #35
HMMMMMMMMM! Never thought about that.. I am in Recirc mode. I would like to know what people think as well. Should I leave in recirc mode or put that bitch in VTA. Basically its just hot air doing a 360, correct. Coming in through intake - through turbo - down hot pipe and out BOV - back into turbo???????????????????? I wonder if it would be okay to put in VTA for I heard that it messes up the DP/Cat
2012 Liquid Silver
Cobb AP
 Old 08-11-2011, 08:28 AM   #36
TRex's Avatar
i have never looked hard but is it recircing pre or post maf?
 Old 08-11-2011, 08:31 AM   #37
MS3inDC's Avatar
Don't forget....
The majority if the compressed air that is passing though the bpv is having to travel back through the core after the throttle plate closes. Correct me if I'm wrong, but outside of emissions the recirc pulse keeps the turbo spinning (fights compressor surge) during gear shifts, right?
Since the air has to come back through the core it doesn't vent as quickly as when the bpv is on the cold pipe...
The flip side is, compressed air slamming back into the turbo is bad. With this set up, the bpv vents the charged air closer to what is designed to protect, the turbo. This if where I feel they went left in design. I want to know if it was to improve on the performance, or was it something predicated by engineering (piping routes)?
Whatever the logic, this kit is damn near the exact opposite of everything else on the market... and it works really well... sok why are they alone in a design like this???
 Old 08-11-2011, 08:48 AM   #38
Wouldnt it be post since its being recirced back into TIP?
Don't forget....
So another words is you think having the BOV in recirc mode is basically not a good idea. It would be nice if @MS3-a(sore)ASS-rex could help me out here and give an input because I know he has/had the same kit but using VTA.
2012 Liquid Silver
Cobb AP
Last edited by irishking03; 08-11-2011 at 08:48 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-11-2011, 08:51 AM   #39
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Ran VTA on this bitch for about 10-12k miles lol.
It recirculates post MAF
NATOR PA
 Old 08-11-2011, 09:22 AM   #40
Do you think VTA is better to do on this setup or recirc.
2012 Liquid Silver
Cobb AP
The Following User Says Thank You to irishking03 For This Useful Post:
86AmishMs3 (05-06-2012)
INstalled Corksport FMIC crazyp MazdaSpeed 3/6 - Turbo Induction 13 05-13-2012 11:02 AM
CXRacing FMIC Installed MS3_65 MazdaSpeed 3/6 - Turbo Induction 92 02-24-2011 05:51 PM
Judder after FMIC and BOV installed neally MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 08-13-2009 10:40 AM
CPE FMIC and Towplate installed!! SgtP Custom Performance Engineering (cp-e.com) 18 11-14-2008 10:16 AM
Page generated in 0.56918 seconds with 45 queries
