  • 1 Post By 2.0t03speed
  • 1 Post By WetzMS3
 Old 09-17-2014, 10:55 AM   #1
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Default Underside routed FMIC Piping
So Im building an engine for my speed. Right not Im running an older PG piping kit to a tr8l core, but its really not a great set up. Looking to possibly do something new and thinking about the possibility of going underside for the routing.
I know @Realgib3; has done it, but Im having trouble finding anyone else. I know there is no kits out there for it. Debating on seeing what I would need to make my PG kit work, or get an idea of what a decent cost would be to just have it made up custom.
Looking to get others thoughts on this. Bad idea for a DD? any benefits besides a nice clean look? Any down sides?
The Following 2 Users Say Thank You to maisonvi For This Useful Post:
speed3 britz (09-18-2014), WetzMS3 (09-17-2014)
 Old 09-17-2014, 11:37 AM   #2
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Are you talking about having the outlet of the turbo compressor facing down? If so try find pics of the way fswerks routes their duratec focus turbo kit.
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 09-17-2014, 11:39 AM   #3
maisonvi's Avatar
Groans: 75
Yeah, thinking of clocking the turbo and running all the piping below.
And thanks, I will look that up.
 Old 09-17-2014, 12:03 PM   #4
I also have been considering this, and I'm pretty sure I have seen/read about a few other people on here that have done this. I'll try to find the threads/pictures I am thinking of.
I can't see there being much change or benefit in performance, but I haven't really looked into it and am not smart enough to figure that out without testing both. My desire to do this was based on slight concerns about rubbing on coolant lines up front, a cleaner look, and I'm lazy and would prefer not to remove a pipe to change plugs.
 Old 09-17-2014, 12:08 PM   #5
maisonvi's Avatar
Groans: 75
the only benefit I could really see is if the routing ended up being shorter. That plus not having to remove anything to work on certain things.
 Old 09-17-2014, 12:15 PM   #6
That was my thought too. Just haven't measured it and guessed that it can't be much longer than current routing options.
 Old 09-17-2014, 12:10 PM   #7
They routed the piping on the underside of the focus only because it lacked the space between the valve cover and the hood. It is for sure a clean look but kind of a pita. The speed with the raised hood is perfect for running over the top side. I have this kit on my focus and it is 2" piping from the turbo to the fmic. There was room to go 2.5 but I left it as is. I did go 3" from the intercooler to the throttle body however. I wish I had pics of the setup but I dont have any of the under side.
Soon to come.
 Old 09-17-2014, 12:23 PM   #8
btstarcher's Avatar
Posts: 4,852   (View Stats)
Kyle Cross has done it. Can't remember his username here because old.
SnailTune in progress
 Old 09-17-2014, 12:35 PM   #9
btstarcher's Avatar
@burn813;
maisonvi (09-17-2014)
 Old 09-17-2014, 12:57 PM   #10
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
@carrottop;
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 3 Users Say Thank You to CWP_MS3 For This Useful Post:
btstarcher (09-17-2014), jdmage_mx5 (09-20-2014), WetzMS3 (09-17-2014)
 Old 09-17-2014, 12:50 PM   #11
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
Cobb piping and TR8L or the new Threadstone kit are great options, its the same route as the PG but better quality and less couplers, and it works fine.. i see a lot of fabbing and customizing work over little difference in bats. but that's my opinion GL with the project
 Old 09-17-2014, 12:52 PM   #12
maisonvi's Avatar
Groans: 75
Honestly I would expect no difference in BATs because of it.
 Old 09-17-2014, 12:56 PM   #13
btstarcher's Avatar
Shorter path to the FMIC though, so that's a benefit. Slightly less lag.
 Old 09-17-2014, 01:12 PM   #14
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
I had mine done, I originally had the turboxs kit and @HTP; took my piping and we reduced the length of the over all piping by 2.5 feet. I have verified proof that with this routing, I am able to spool about 3-500rpm quicker
@carrottop;
It's @firecrotch; damn, get that shit right
2008 MS3 gt
470hp/463tq on GT35r at 29psi
Last edited by burn813; 09-17-2014 at 01:12 PM. Reason: MSF Database - Automerged Doublepost
The Following 6 Users Say Thank You to burn813 For This Useful Post:
btstarcher (09-17-2014), chaser27 (09-17-2014), maisonvi (09-17-2014), Mauro_Penguin (09-19-2014), ryguy 3 (01-20-2016), WetzMS3 (09-17-2014)
 Old 09-17-2014, 01:12 PM   #15
maisonvi's Avatar
Groans: 75
Is there a thread with pics somewhere? or do you have some you could share? Any info would be sweet, as Im not afraid to fab my own if need be.
 Old 09-17-2014, 01:12 PM   #16
btstarcher's Avatar
This is the only way I would even consider a FMIC. I wants my quick spool.
 Old 09-17-2014, 01:16 PM   #17
lulz @Raider
burn813's Avatar
Mason I will post them later, I don't have any right now
2008 MS3 gt
The Following 2 Users Say Thank You to burn813 For This Useful Post:
maisonvi (09-17-2014), Mazdazilla6 (09-17-2014)
 Old 09-17-2014, 01:19 PM   #18
Cevaes_64's Avatar
are you planning on going bigger than BNR later with the forged engine?
 Old 09-17-2014, 01:25 PM   #19
Doesn't PG have underside piping now? I swore I saw something on their facebook
 Old 09-17-2014, 01:26 PM   #20
ArmanRus's Avatar
Posts: 1,566   (View Stats)
Groans: 42
@RE-ACTIONENGSPEED3; also have underside piping.
11.41@127.50 !!!!!!!
The Following User Says Thank You to ArmanRus For This Useful Post:
 Old 09-17-2014, 01:51 PM   #21
lulz @Raider
burn813's Avatar
@HTP; should be releasing a piping kit soon
2008 MS3 gt
btstarcher (09-17-2014), maisonvi (09-17-2014)
 Old 09-17-2014, 02:00 PM   #22
maisonvi's Avatar
Groans: 75
Well shit, everyone is releasing kits now. About damn time. HTP, JBR, Treadstone. Hopefully like everything else I own of HTP's its low cost but super nice.
 Old 09-19-2014, 02:06 PM   #23
MS3KO's Avatar
Posts: 579   (View Stats)
MS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the world
Im running the original raceroots intercooler piping kit. I love the fact that my engine bay is cleaner without the piping flowing over it. I know they had a bad rep but if they are still around you can order it from them.
2009 MazdaSpeed 3 Metro Grey-T3 Gt3071, Re-flanged RR mani, 44mm Tial WG, Cusom DP, Custom 4in to 3.5in intake, Custom 3.5in maf, Custom FMIC kit, Tial BOV, EVO Prosport Boost gauge, EVO oil temp gauge, AEM wideband, TRZ RMM, JBR PMM, JBR TM, JBR Shifter Plate, TWM SS, Hks CBE, COBB AP, Road Magnet Springs.
PERM Tuned!///389hp 360tq///Best time:12.2 @117 (with new tires 11's here i come!)
Hit up BC Autoworks for all your powder coating needs!
MS3KO is offline   Reply With Quote
 Old 09-19-2014, 02:21 PM   #24
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
I am the guy running the protege garage turbo kit w/ the borgwarner s360. i'll post a pic of my under motor hot pipe routing when i get home.
The Following 3 Users Say Thank You to 2.0t03speed For This Useful Post:
Code Monkey (09-19-2014), maisonvi (09-19-2014), Mauro_Penguin (09-20-2014)
 Old 09-19-2014, 02:23 PM   #25
maisonvi's Avatar
Groans: 75
Yeah they dont make it any more looks like. Plus, banned from here means probably a no go for me.
Sweet, if you could make your PG kit work theres hope for me. Pictures would be awesome.
 Old 09-19-2014, 03:14 PM   #26
ledfootrob's Avatar
Posts: 195   (View Stats)
ledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the world
I'm planning an underside hot pipe at the moment too. I was playing around with my Turbo yesterday and found a custom wastegate actuator bracket will have to be made up. The one on the BNR sits too close for the chunkier side of the inlet housing once the turbo is clocked upside down. GL with yours, keen to see how you go.
2012 Black Mazda 3 MPS
CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC
2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate
OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors
Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks
Versus Eurolace 19 x 8 +45 - Hankook RS3
Built & Tuned by Rob
Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18
DBA T3 Rotors - Carbotech XP10 Brake Pads
ledfootrob is offline   Reply With Quote
 Old 09-19-2014, 03:31 PM   #27
maisonvi's Avatar
Groans: 75
@speed3 britz; had the same issue
Sent from my XT907 using Tapatalk
ledfootrob (09-19-2014), speed3 britz (09-19-2014)
 Old 09-20-2014, 03:01 PM   #28
Here are the best shots I have at the moment
ImageUploadedByTapatalk1411246841.715070.jpgImageUploadedByTapatalk1411246858.301988.jpg
Mauro_Penguin likes this.
The Following 7 Users Say Thank You to 2.0t03speed For This Useful Post:
ArmanRus (09-21-2014), Code Monkey (09-20-2014), ledfootrob (09-23-2014), maisonvi (09-20-2014), Mauro_Penguin (09-20-2014), speed3 britz (09-22-2014), WetzMS3 (09-21-2014)
 Old 11-27-2015, 07:34 PM   #29
MY DICK IS SMALL-beautfpowers@gmail.com's Avatar
Posts: 327   (View Stats)
MY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these parts
Groaned at 212 Times in 84 Posts
need this for ms6 like yesterday!!
MY DICK IS SMALL-beautfpowers@gmail.com is offline   Reply With Quote
The Following 4 Users Say NO Thank You to MY DICK IS SMALL-beautfpowers@gmail.com For This Un-useful Post:
MS3Shadow (12-01-2015), speed3 britz (12-01-2015), Vansquish (12-01-2015), WetzMS3 (12-01-2015)
 Old 11-27-2015, 08:20 PM   #30
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
You bumped a thread over a year old to say that?
The Following 6 Users Say Thank You to jdmage_mx5 For This Useful Post:
btstarcher (11-27-2015), MS3Shadow (11-30-2015), nojjy (12-01-2015), speed3 britz (12-01-2015), Vansquish (12-01-2015), WetzMS3 (12-01-2015)
 Old 11-27-2015, 08:48 PM   #31
apparently
 Old 12-01-2015, 01:28 PM   #32
apparently
Sigh.
Since you seem to struggle with reading, or even looking at your own car, these kits are being run on gen1 and gen2 3's. The 6 has a lot more going on down there that makes it damn near impossible to route the piping underneath. I have looked at it with at least two 6 owners, to see if it is feasible, while looking at their cars. I suggest you go take a look underneath your car. Check HTPs website or FJ for pictures of how the piping is routed, compare to your car and report back.
The Following 6 Users Say Thank You to WetzMS3 For This Useful Post:
derek13p (09-06-2016), jdmage_mx5 (12-01-2015), maisonvi (12-01-2015), Micha (12-01-2015), MS3Shadow (12-01-2015), speed3 britz (12-01-2015)
 Old 12-01-2015, 04:52 PM   #33
Sigh.
yeah code monkey was nice enough to inform me about the space limitations, i can't look under my car because my engine and transmission are out so it wouldn't do me much good or i obviously would have
I've READ some vendors saying they were going to make one so i had assumed it was feasible and was just checking to see if any progress was made, so i guess that makes me struggle with reading right?
i wish i could have a good look under the car to see what its like under there because "damn near impossible" and actually impossible are very different...wanna be a doll and snap some pictures for me since i won't be able to get that view until spring or do you just want to continue to be a cunt, thanks bro!
The Following 2 Users Say NO Thank You to MY DICK IS SMALL-beautfpowers@gmail.com For This Un-useful Post:
g00s3y (12-01-2015), Vansquish (12-01-2015)
 Old 12-01-2015, 05:16 PM   #34
maisonvi's Avatar
Groans: 75
It's not impossible but I don't think any vendor would be willing to take the work it would be to make one for a limited market. You could spend the money and have a shop custom make you one I'm sure
 Old 12-01-2015, 05:33 PM   #35
Damn dude. You may think I've been a cunt, but I've been rather tame. Your posts lately have been lazy, lacking foresight, and without background information. Things you seem to show eventually after being flamed in your threads. You claim you like to start discussions, but your posts come off as uninformed and lazy like some many brownie posts in the past. 90% of the information you've been looking for has already been discussed at length with information readily available here. There is no point to repetitive discussions. If you have specific questions or ideas, present them with background information and knowledge, and discussions will be had.
I tried to be somewhat helpful in this post, since as I mentioned, you seem to be somewhat informed after the information is pulled out of you by others. Put more effort into your original posts, and you'll receive more help.
As for me taking pictures for you, fuck you. Do your own research asshole.
Lastly, to tag someone, type "@" "username" ";" you brownie faggot.
KennyFish likes this.
 Old 12-01-2015, 07:03 PM   #36
jdmage_mx5's Avatar
yeah code monkey was nice enough to inform me about the space limitations, i can't look under my car because my engine and transmission are out so it wouldn't do me much good or i obviously would have I've READ some vendors saying they were going to make one so i had assumed it was feasible and was just checking to see if any progress was made, so i guess that makes me struggle with reading right? i wish i could have a good look under the car to see what its like under there because "damn near impossible" and actually impossible are very different...wanna be a doll and snap some pictures for me since i won't be able to get that view until spring or do you just want to continue to be a cunt, thanks bro!
Personally I'm getting pretty tired of seeing your lame ass post. You do zero to no research. You come on this forum wanting everyone to spoon feed you to 700hp but yet you lack so much intellectually. I take that back you may be smart as hell but you lack forum etiquette.
Just like stated before, if you have a specific idea or question then by all means start a thread about but provide your scientific thoughts or something showing you have done at least SOME research.
I'm excited to see another person wanting to push another speed into the 700+ hp range but just wish you would provide data and scientific knowledge to your post vs "umm yea, hey guys what do you think about this old ass stand back", or "I like your injection setup how do I replicate it to a T so I don't have to put any thought into it".
 Old 12-01-2015, 08:53 PM   #37
I put plenty of thought into the injection setup by emailing jmf and asking them about my options for meth injection with the aux fuel set up they told me i would have to have the bungs on the underside and off centered which i was on the fence about. His bung setup was really clean and much better than the route i was considering due to their suggestions so i thought i would ask him some questions. its very clean, i don't see what is wrong with that, imitation the sincerest form of flattery... and i asked about his nozzles to see what he was doing, what is wrong with that i personally think am going to go with 4gph 5 seems like overkill based on the calculator...
you guys think i have done 0 research and make a lot of false assumptions, but i have, thats why i know that vendors said they were working on an option for the speed... sorry i didn't know it wasn't going to happen maybe i missed it, sorry i have no read every post on here and sorry if i miss some stuff and ask a dumb question , that is why i asked. you guys are ready to jump down my throat because i didn't know it wasn't happening, i just asked because from the forums i read i thought it was just a waiting game...perhaps it still could be, i know when i have my car put back together i will be looking for a way to make this happen. maybe its impossible maybe its not, i don't think i need IC piping more than 2.5 inches. i bet if there was a solution to this the 6 guys would be all about it right?
I'm going to try and meet you guys half way here and try to really be clear about my posts so you guys don't think I'm being lazy since this makes you all very mad and i guess i see your point though we just have different styles and perspectives on the matter, I'm not being lazy I'm being casual. I'm not trying to write a research paper every time i post, just shooting the shit about cars with people who have the same or a similar platform as i do.
 Old 12-01-2015, 07:09 PM   #38
nojjy's Avatar
Posts: 238   (View Stats)
nojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the world
What oil should I use?
GTX3071R IWG, HTP 3.5" Cs cbe, jbr 80 duro trilogy, autotech internals, cp-e tmic and DP.
E33 Freektune 387 hp, 366 lb/ft .
nojjy is offline   Reply With Quote
The Following 2 Users Say Thank You to nojjy For This Useful Post:
Cx racing piping or pg piping for my fmic blake0521 2010 MS3 - Turbo Induction 34 09-25-2014 03:51 PM
PG FMIC Piping vs CX Racing Piping GreyGhost 2010 MS3 - Turbo Induction 2 04-17-2013 08:37 PM
Page generated in 0.59848 seconds with 35 queries
