12Likes ![]() |
![]() Join Date: Aug 2014
Groaned at 3 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score My tuner is on vacation, should have some dyno results in a few weeks. We got most of the part throttle tuning done before he left.. But I was having issues with misfires, that turned out to be spark plug related.. Lets just say I dont like denso plugs anymore, neither does my car.. Back to Autolite plugs. 12074733_10206496729589795_5471651206051482962_n.jpg 12036929_10206496729429791_3221694386574976561_n.jpg 12074663_10206500651047829_1376060757931700109_n.jpg 12109148_10206515631622334_4976916570640211326_n.jpg 12038097_10206446594456448_103079373121819481_n.jpg
__________________ 89 Volvo 244- MZR VVTi, Eagle rods, CP pistons, Crower springs, ARP head and main studs, custom intake with 65mm mustang tb, GT3071R, 4ch EGT, Innovate, PCS D200 with electronic boost control @20psi, Aeromotive 340 stealth feeding a Walbro 255 inline, AEM FPR, Deka 60-lb/hr, 5R55E with PCS paddle shifters and TCU. Last edited by MS3Shadow; 10-05-2015 at 10:40 AM. Reason: removed s to embed |
| The Following 22 Users Say Thank You to TerribleOne For This Useful Post: | ArmanRus (10-07-2015), Code Monkey (10-05-2015), cshunter (10-09-2015), dale_gribble (10-05-2015), dan7225 (10-05-2015), DaUberSchwebel (10-05-2015), Easter Bunny (10-08-2015), Hush (10-27-2015), ItsNox (10-08-2015), macdiesel (10-05-2015), MacheteJames (10-09-2015), MS3Shadow (10-05-2015), nekret (10-05-2015), PapaBone (10-06-2015), Pu Manchu (10-08-2015), Snyeed (10-05-2015), SofaKingAwesome (10-05-2015), speed23 (10-05-2015), SpeedRebirth (10-05-2015), Thepedigree13 (10-05-2015), thrisnospork (10-27-2015), WetzMS3 (10-05-2015) |
![]() Join Date: Jan 2013 Location: Vancouver, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
| Not Ranked : 0 score cool build sir!
__________________ 2011 Mazdaspeed3 non-tech package Drivetrain CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune Chassis JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace Rice LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score Cool as shit! Who doesn't like an old beater with a nice turbo engine . And who would have thought the mzr would fit! Great job!Sent from my big ass Note 4 using shitty Tapatalk.
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
(Thread Starter) | Not Ranked : 0 score Thanks guys.. Fits with a stock ranger oil pan! and stock Volvo crossmember.
__________________ 89 Volvo 244- MZR VVTi, Eagle rods, CP pistons, Crower springs, ARP head and main studs, custom intake with 65mm mustang tb, GT3071R, 4ch EGT, Innovate, PCS D200 with electronic boost control @20psi, Aeromotive 340 stealth feeding a Walbro 255 inline, AEM FPR, Deka 60-lb/hr, 5R55E with PCS paddle shifters and TCU. |
| Not Ranked : 0 score What did you end up doing for a transmission? Stock rear end? Sent from my SM-G900V using Tapatalk
(Thread Starter) | Not Ranked : 0 score The transmission is a 5R55E ranger trans with a PCS TCM-2000 standalone controller. Rear is stock with a modified Eaton G80 locker. 3" steel one piece driveshaft.
| The Following User Says Thank You to TerribleOne For This Useful Post: | nekret (10-27-2015) |
| Not Ranked : 0 score Holy shit thats a lot of custom work
![]() Join Date: Aug 2014 Location: Bethlehem PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
Groaned at 5 Times in 1 Post
| Not Ranked : 0 score That build is really cool! Nice work love those old Volvos just always so slow but not anymore! |
![]() Join Date: May 2012 Location: orlando, fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score Awesome build! Looks like there were enough space to make it AWD Brick))
__________________ ---------------------------------------- Building it from ground up: ![]() |
![]() Join Date: Oct 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,593
| Not Ranked : 0 score Where are you located @TerribleOne;? Is Matt Shue tuning your car?
__________________ 2009 Mazdaspeed3 Bolted, Mounted, Hypnotic Tuned 2000 Mazda Miata MX-5 NASA TTE build ongoing |
![]() Join Date: Nov 2013 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Had no idea this was being done to our platform https://www.youtube.com/user/Mangohi...rsports/videos The speed3 build is crazyy |
| Boost issue >7psi | browerl | 2010 MS3 - Troubleshoot/Diagnostics | 20 | 08-19-2015 08:23 PM |
| Bullseye Billet S259 build (soon to be double Batmowheel S366) | Erich | MazdaSpeed 3/6 - Big Turbo Builds | 443 | 08-19-2015 06:08 AM |
| Video: Volvo's 'ditch test' of the new XC90 makes for radical video | Haltech | Automotive News | 0 | 12-04-2014 01:10 PM |
| Official: Volvo lifts up new Volvo V40 Cross Country for the whole world to see [w/video] | Haltech | Automotive News | 0 | 09-19-2012 12:00 PM |
| s362, s366, or PTE6262 | Jarods7920 | MazdaSpeed 3/6 - Turbo Induction | 6 | 03-04-2012 09:54 PM |
