Like Tree56Likes
 Old 08-12-2011, 03:09 PM   #81
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Sweet...got it working
 Old 08-12-2011, 05:14 PM   #82
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
put your smoothing back to like 3. and make sure to enter the SAE data!
and since when do u weigh 300 lbs? lol
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
Last edited by superskaterxes; 08-12-2011 at 05:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-12-2011, 06:19 PM   #83
Groans: 35
Lolz. I'm like 215
- Sent from my iPhone using Tapatalk
 Old 08-12-2011, 06:23 PM   #84
Must Have Teh 10's!
lol the stock weigh of the built in MS6 is 3589 and your graph says 3905
86AmishMs3 (08-12-2011)
 Old 08-15-2011, 08:00 PM   #85
irishking03's Avatar
Posts: 2,136   (View Stats)
I need to DL this shit.
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
 Old 08-16-2011, 09:03 AM   #86
bbarnhill's Avatar
Posts: 271   (View Stats)
bbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the world
irishking ... yes you do.
superskaterxes ... he cant help it if he likes the buffet a little more than you
Brad Barnhill
VIRTUAL DYNO
The ONLY way to graph your runs.
www.bradbarnhill.com/projects/VirtualDyno
bbarnhill is offline   Reply With Quote
The Following User Says Thank You to bbarnhill For This Useful Post:
superskaterxes (08-16-2011)
 Old 08-16-2011, 09:07 AM   #87
Groans: 35
^^ fuck you asshole, I'm just big boned
jk lol
 Old 08-16-2011, 09:21 AM   #88
fywdyl's Avatar
Posts: 370   (View Stats)
fywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the world
VD is awesome for keeping track of changes that you are making to your tune.
2010 Black Mica MS3
Mods to date:
Corksport TMIC || cp-e HPFP || COBB Accessport || JBR 3.5" WP SRI + 80 Duro Trilogy Mounts + RSB + IM TIG + TB Coolant Bypass & TIG + SSP + Bushings + Heavy Shift Knob || HKS SSQV III VTA || Denso ITV-22 || Ultimate Racing V2 Catted DP+Resonated TP || Ported IM || GT3071
Mods to come:
Driver Mod || Snow Performance Meth Kit
fywdyl is offline   Reply With Quote
 Old 08-16-2011, 10:30 AM   #89
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
Groans: 65
What is everyone using for the smoothing number on the VD? I have been using 2.
 Old 08-16-2011, 10:52 AM   #90
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I use 3. It's what every real Dyno run I've had used.
- Tapadatass
AZSPEED3 (08-16-2011)
 Old 08-16-2011, 11:32 AM   #91
AZSPEED3's Avatar
Groans: 65
Ok thanks man, I will swtich over to the 3 smoothing from now on.
 Old 08-16-2011, 08:36 PM   #92
LuczOr's Avatar
Posts: 462   (View Stats)
LuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the world
Groaned at 15 Times in 12 Posts
Subbed for updates and whatnot. Hopefully I can compare this to an actual dyno later, because we all know that all dynos are correct and all read the same numbers.
You know, Apples to Nuclear Missles.
Cool sig coming soon.
LuczOr is offline   Reply With Quote
 Old 08-21-2011, 11:19 AM   #93
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
hey Brad...I know this is no priority and that's why I've put off asking. but is there any chance you can offer options to use Celsius and Kilopascals?
-- Mario Andretti --
 Old 08-21-2011, 12:54 PM   #94
bbarnhill's Avatar
Are you talking about in the SAE correction settings?
Brad Barnhill
VIRTUAL DYNO
 Old 08-21-2011, 03:44 PM   #95
Driver
Fobio's Avatar
Groans: 44
Yes.
 Old 08-21-2011, 10:02 PM   #96
snailD's Avatar
Posts: 3,039   (View Stats)
alright so here is the latest of my logs and virtual dyno. idk why my maf isnt 0 the whole time, i didnt adjust it since last revision which was 0...... it just makes me wonder because my HP jumped up right where i went down to 0 LTFT. also i noticed it adjusts the maf g's too. any thoughts on that?
o and there were a shit load of ppl out tonite so this was the longest i could get a pull goin
i just took pictures of my old actual dyno, which is a heartbreak mustang dyno at 4500ft btw. the good is the curve looks very similar so this program does a really good job! i took a pic of the dyno and the power output because it has the rpms of the max levels on it.
 Old 08-22-2011, 06:50 PM   #97
jman46's Avatar
Posts: 3,169   (View Stats)
jman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the world
Groaned at 26 Times in 20 Posts
@speedyD, I don't really think you're making 320wtq with the mods listed in your sig.
'06 F350 Lariat PSD - 458whp/818wtq
'07 MS3 - 313hp/323tq - sold - the FIRST EVER FREEKPerm.
'06 F150 SCrew 4x4 5.4l - sold
'03 Marauder - Vortech on only 8psi 485whp/435wtq - sold
'95 Mustang GT - sold
'95 SHO MTX - sold
jman46 is offline   Reply With Quote
 Old 08-22-2011, 06:53 PM   #98
atvfreek's Avatar
Posts: 7,787   (View Stats)
@jman46, do you have a log for VD we can compare to saturdays dyno?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 08-22-2011, 07:29 PM   #99
jman46's Avatar
Justin, I didn't have my AP hooked up when Fred was in my car during that run, so I can't compare it to VD sadly .
'95 SHO MTX - sold
 Old 08-22-2011, 09:39 PM   #100
bbarnhill's Avatar
You can not log while on the dyno. You MUST do your runs on the street as wind resistance is taken into account. So if you log a run and then get on the dyno ... that would be the best comparison.
Just my 2 cents worth ...
Brad Barnhill
VIRTUAL DYNO
phate (08-22-2011)
 Old 08-22-2011, 09:41 PM   #101
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Brad, I'm glad you finally pointed that out. Rates of acceleration are slightly different between a dyno run and a street run.
Bucker likes this.
 Old 08-22-2011, 09:44 PM   #102
jman46's Avatar
Thanks for clarifying that Brad.
'95 SHO MTX - sold
 Old 08-22-2011, 10:10 PM   #103
snailD's Avatar
im not sure, but this thing has been pretty accurate and i have a friend who just dynoed in the area and did 298 and 333 with the same mods as me except he has a front mount.
also, if on that dyno from last year, i had the 2nd highest torque rating compared to about 8 other speeds ranging from mild bolt ons to fully bolted, they all had AP i was on stock tune.
i'm going to get a dyno in the next month probably so we will be able to compare that soon
 Old 08-22-2011, 10:38 PM   #104
jman46's Avatar
I'm not saying you're wrong, or its wrong, but I've tossed a few logs in, and when I put 3rd gear, it seems more accurate...but when I switch it to 4th, sometimes it reads crazy high, and dyno wise 4th gear is perfect for our car, and I get stuff way different on a legit dyno.
'95 SHO MTX - sold
The Following User Says Thank You to jman46 For This Useful Post:
Bucker (09-04-2011)
 Old 08-22-2011, 10:46 PM   #105
snailD's Avatar
word, well this was from the same tune, except when i changed the throttle tables for some reason it was cutting my throttle down, i went full throttle to 70 then slowly back up to full throttle towards the end of the graph. so i just went back into atr and undid what i did and got the graph i prevously posted.
as far as everything goes it seems to be pretty consistent. although im not gonna lie, i did put up the higher of the two logs i did, but they were both very similar.
 Old 08-30-2011, 12:16 AM   #106
silvapain's Avatar
Groans: 136
Either my car's a factory freak, or this thing is off, 'cause I find these numbers hard to believe. I even logged IAT's and Barometric Pressure and put those into the SAE correction factor to make it as realistic as possible.
Someone really needs to do a good comparison between VD and a real dyno.
 Old 08-30-2011, 12:28 AM   #107
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
If you are calculating for wind resistance, is CdA taken into account?
 Old 08-30-2011, 01:21 AM   #108
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
I made 350hp on my mods......downhill
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
Fobio (08-30-2011)
 Old 08-30-2011, 08:27 AM   #109
Driver
Fobio's Avatar
Groans: 44
road condition and slope makes a huge dif. I have a plot of me going 400whp after correction...slight downhill. I also have one making over 800whp/800wtrq cuz it was drying up after spit of rain and I had DSC/traction off...spun right to 6000rpm.
With re: to comparison with a real dyno, I have one. During that day, my baseline dyno was at 348/366...that same night I pulled a street log and it registered somthing like 338/360 on VD.
The Following User Says Thank You to Fobio For This Useful Post:
Realgib3 (08-30-2011)
 Old 08-30-2011, 09:44 AM   #110
silvapain's Avatar
Groans: 136
I live in a ruralesque part of Northern IL. Roads here are very flat and very straight for the most part.
The road I use for tuning is pretty new and smooth as well.
Tapadatass
Fobio (08-30-2011), Realgib3 (08-30-2011)
 Old 08-30-2011, 01:09 PM   #111
Driver
Fobio's Avatar
Groans: 44
Tapadatass
looking at your log, it seems like you also have realtively lower baro numbers. for reference, our airport always reports a slight lower baro than the city, and using the airport's numbers will always give me high read-out on VD.
and who knows...maybe you have a really fast car...mods?
 Old 08-30-2011, 02:42 PM   #112
Realgib3's Avatar
Posts: 2,443   (View Stats)
Tapadatass
Yeah what are your mods? You're about the same power as I'm making. A little less than me but not much and Im pretty much fully bolted without ex-mani or catback at 21-22 psi no meth.
 Old 08-31-2011, 08:00 AM   #113
silvapain's Avatar
Groans: 136
I logged barometric pressure during the run and used that number plus the IAT reading for the SAE correction. If I remember correctly that dropped the numbers down a bit.
Power mods are minimal. SRI, TIP, catless DP, AP. Mods that may add power are ITV-22's and catback. Stock HPFP and TMIC as said before.
Tapadatass
 Old 08-31-2011, 08:03 AM   #114
silvapain's Avatar
Groans: 136
FWIW, the local weather station is showing the baro as 29.26 inHg right now, at an elevation of 662 ft above sea level.
I'll post my logs tonight for reference.
Tapadatass
 Old 08-31-2011, 07:46 PM   #115
silvapain's Avatar
Groans: 136
My logs in .xlsx and .csv formats:
 Old 08-31-2011, 08:13 PM   #116
bbarnhill's Avatar
Coeff of drag is taken into account in the wind resistance calculations.
To all the non-believers ... I welcome you to do a comparison between a dyno pull and virtual dyno. I do caution you to make sure you abide by the rules for getting a decent log to graph though (flat road, no wheel spin, good clutch ... you know ... no rookie stuff).
Ive seen this same thing on multiple forums and they all come to the same conclusion in the end. When used right ... its accurate. Check HPTuners, EvolutionM, EvoXForums, Subaru Legacy forums, 3si, NASIOC ... etc
Brad Barnhill
VIRTUAL DYNO
The Following 3 Users Say Thank You to bbarnhill For This Useful Post:
phate (09-01-2011), rigor (04-01-2012), silvapain (09-02-2011)
 Old 09-02-2011, 09:03 PM   #117
bbarnhill's Avatar
got some dedicated webspace but moving the site is being a pain. So in the next few days when they transfer my domain if I dont have everything moved there may be some server outages till I get it rebuilt. Just warning you guys of the move. Grab it now if you want it or it may be down for a few days.
Thanks ... and bear with me as I move this thing to a more reliable connection and server environment.
Brad Barnhill
VIRTUAL DYNO
 Old 09-02-2011, 09:45 PM   #118
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Very Nice!
I need MOAR BOOST!
And four more injectors
 Old 09-02-2011, 10:29 PM   #119
Enki's Avatar
Even if it goes down we can host it here for a while, I'm sure.
For VIP members anyway.
 Old 09-03-2011, 06:49 AM   #120
bbarnhill's Avatar
I should have everything moved to the new server now ... the domain takes a few days for the hosting to switch. Im waiting on that to flip over to the new host and see if it breaks anything. I should have everything up on the new server though. Granted there are always hiccups.
Brad Barnhill
VIRTUAL DYNO
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/virtual-dyno-85289/
Cobb Dyno - Colorado Mazda Club This thread Refback 11-21-2011 11:22 AM
Mazda Owners Club SA • View topic - Virtual Dyno This thread Refback 09-09-2011 04:44 AM
Virtual Dyno Program kyoo Mazdaspeed3/6 General Discussion 58 08-01-2011 08:57 PM
Dyno runs: Renault Megane RS, Mazdaspeed 3 and Focus RS [Pics, dyno sheet and Video] ganque MazdaSpeed 3/6 - Dyno Sheets/Discussions 25 01-20-2011 02:03 AM
Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? desperado callado MazdaSpeed 3/6 - Dyno Sheets/Discussions 10 05-18-2009 11:27 AM
Page generated in 0.56748 seconds with 37 queries
