 Old 10-03-2017, 05:51 PM   #1
Nickhxc4life's Avatar
Posts: 27   (View Stats)
Nickhxc4life will become famous soon enough
I just did the VVT repair myself. Started getting chatter at idle and at startup. have 200k on the motor. Those marks on the inside are from the chain slapping because the vvt had failed. There is a sensor on the vvt and chances are when it went your ecu caught it before it got to bad and threw your car in limp mode which would explain your sudden loss of power. I'd say check out your valves with a boroscope and if they're ok I would pony up and get the VVT job done. I wouldn't call the motor a total loss just because of those marks. If you get the VVT job done those marks won't affect the functionality of any parts.
Nickhxc4life is offline   Reply With Quote
Second VVT Failure? spikeanoid MazdaSpeed 3/6 - Troubleshoot/Diagnostics 34 09-03-2014 11:32 AM
PCV Failure EvoFire MazdaSpeed 3 - Engine, Transmission & Driveline 20 06-04-2014 05:04 PM
3rd VVT Failure JumpingJackson MazdaSpeed 3 - Engine, Transmission & Driveline 41 06-22-2011 11:12 AM
Failure Dave092 Mazdaspeed3/6 General Discussion 18 05-06-2011 09:24 AM
WTF do I have to do to fix my RMM after PMM failure. Adam is so pro MazdaSpeed 3 - Engine, Transmission & Driveline 2 04-18-2009 08:23 PM
Page generated in 0.22696 seconds with 22 queries
