 Old 08-30-2018, 11:19 AM   #1
mirak's Avatar
Posts: 3   (View Stats)
mirak will become famous soon enough
SOLVED
Fuel Pump resistor - located under the air filter box. A lot of corrosion and overheat, cables damaged. I´ve just tried to bypass this resistor - just connected these two wires together.
Everything seems to be OK now, 45km driven and no more problems at all...
Pictures attached
mirak is offline   Reply With Quote
The Following User Says Thank You to mirak For This Useful Post:
JSmith (08-30-2018)
Weird misfire problem Speed3Pedro Mazdaspeed3/6 General Discussion 34 08-27-2016 08:40 AM
Weird problem Woodyspeed3 Gen2 MS3 General Discussion 5 06-05-2015 08:04 PM
Weird Problem danfbh CX-7 > Issues & Troubleshooting 12 06-11-2014 03:09 PM
Another weird problem with shifting into first Mazdaspeed3KHP 2010 MS3 - Engine, Transmission & Driveline 6 05-20-2013 09:15 PM
Weird start up problem Mazdaspeed3KHP 2010 MS3 - Engine, Transmission & Driveline 17 05-20-2013 10:57 AM
Page generated in 0.22610 seconds with 22 queries
