  • 1 Post By anodizedeeznutz
 Old 01-04-2014, 06:14 PM   #1
JgamB's Avatar
Posts: 2,566   (View Stats)
Default What the hell is that noise?
I experienced the chirping fuel pump on cold start a few days ago, and that got me thinking we get a lot of questions on clunks, rattles, grinding, scraping, etc pretty frequently, so I figured I'd make a compilation. Feel free to add anything you can produce a discernible video/audio clip for or a short guide for something obvious.
DRIVETRAIN
Transaxle clunk MS3, passenger side
Aluminum lightweight flywheel clack / clutch chatter (severe)
Video - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Wheel bearing
ENGINE
VVT actuator ticking / chain loose
https://www.youtube.com/watch?v=2s6u44l6xzw
https://www.youtube.com/watch?v=6Qqal3sK5fw
HPFP relief valve squeak / cold start
Tensioner Pulley
SUSPENSION / BRAKES
Generic instructions on how to isolate suspension noise
Lower spring perch dirty / coil spring deterioration
2006 Mazdaspeed6 Suspension Noise - YouTube
Caliper anti-rattle clip missing
Suspension rattling/clunking
Upgraded struts clunking on bumps
End links / sway bar
Cold weather bushing squeaks
INTERIOR
Glove Box
How-To: Eliminate Glove Box Rattle
Dash / Cowl rattle
http://www.mazdaspeedforum.org/forum/for...sh-area-15819/
The Following 14 Users Say Thank You to JgamB For This Useful Post:
Agent_Orange (01-04-2014), ArmanRus (01-04-2014), darth_speeder (01-06-2014), galens47 (01-06-2014), gmoney542 (01-05-2014), hihosilver (01-04-2014), Hush (01-04-2014), jbmazda6 (01-05-2014), jharris243 (01-04-2014), jm211 (01-06-2014), magicka (01-05-2014), n810e (01-05-2014), SpencerC (08-06-2014), [R]usty (01-04-2014)
 Old 01-04-2014, 06:18 PM   #2
jbmazda6's Avatar
Posts: 1,230   (View Stats)
jbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the world
Very informative posts. I think I have some videos around here somewhere of endlinks creaking. I know you already have that but more is always better.
JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray
Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers
Sponsored By: JamesBaroneRacing.com
jbmazda6 is offline   Reply With Quote
 Old 01-04-2014, 07:07 PM   #3
ArmanRus's Avatar
Posts: 1,566   (View Stats)
Groans: 42
Here's a vid of my car when it had a bad front wheel bearing. Noise is more noticeable around the 10 second mark.
 Old 01-04-2014, 07:44 PM   #4
JgamB's Avatar
Thanks, added!
 Old 01-04-2014, 11:46 PM   #5
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Good shit, subbed.
Sent from my KFAPWI using Tapatalk HD
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 01-04-2014, 11:56 PM   #6
anodizedeeznutz's Avatar
Posts: 2,796   (View Stats)
anodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the world
@cassfolk666; end link / sway bar noise video
cassfolk666 likes this.
2013 CWP Mazdaspeed3 - SOLD
2014 Mitsubishi Evo X - time for some fun.
anodizedeeznutz is offline   Reply With Quote
 Old 01-05-2014, 12:23 PM   #7
n810e's Avatar
Posts: 274   (View Stats)
n810e is the leader of the worldn810e is the leader of the worldn810e is the leader of the worldn810e is the leader of the worldn810e is the leader of the worldn810e is the leader of the worldn810e is the leader of the worldn810e is the leader of the worldn810e is the leader of the worldn810e is the leader of the worldn810e is the leader of the world
for the endlinks/swaybar noise and for the bushings noise are these something that needs to be dealt with or just the normal noises?
n810e is offline   Reply With Quote
 Old 01-05-2014, 12:29 PM   #8
n810e's Avatar
Mine did this once when it was super cold, but not nearly as loud.
 Old 01-06-2014, 10:35 AM   #9
twincitySPEED6's Avatar
Posts: 276   (View Stats)
twincitySPEED6 has a reputation beyond reputetwincitySPEED6 has a reputation beyond reputetwincitySPEED6 has a reputation beyond reputetwincitySPEED6 has a reputation beyond reputetwincitySPEED6 has a reputation beyond reputetwincitySPEED6 has a reputation beyond reputetwincitySPEED6 has a reputation beyond reputetwincitySPEED6 has a reputation beyond reputetwincitySPEED6 has a reputation beyond reputetwincitySPEED6 has a reputation beyond reputetwincitySPEED6 has a reputation beyond repute
yeah wtf is up with the duck call? when it gets really really cold ive been getting it every single start. its only happened this year too (2nd winter owning my ms3)
SOLD - 2007 Mazdaspeed3 210k
Current - 2007 Mazdaspeed6
twincitySPEED6 is offline   Reply With Quote
 Old 01-06-2014, 10:38 AM   #10
n810e's Avatar
Here's this, in case anyone ever figures it out.
Name that noise! (Video)
 Old 01-06-2014, 10:51 AM   #11
galens47's Avatar
Posts: 1,616   (View Stats)
galens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the world
Groaned at 19 Times in 10 Posts
Think I've narrowed my problem to endlinks and strut bearings. She is going into the shop tomorrow
Excellent post!
Cheers,
G
2008 Toyota Prius Grand Touring. Slow, no mods. Saving $600/month - Fuck off you judgmental Assholes. I miss the fuck out of my speed3 way more than the mustang. Alas I'm waiting for the next one.
2014 Mustang GT Premium, Deep Impact Blue. Boss 302 Steering wheel (Alcantara), SR Shift bracket, Roush Axelback -sold
2010 ms3 Black Mica Tech Package -sold
Internals are easy. Who the fuck thought it would be a good idea to point the genjuan's valve cover recirc tube at the EGR?
“It is the mark of an educated mind to be able to entertain a thought without accepting it.” --Aristotle
galens47 is offline   Reply With Quote
 Old 01-06-2014, 11:06 AM   #12
doctavus's Avatar
Posts: 1,728   (View Stats)
This is very informational!
I drove my car to work this morning when it was 19 degrees and the car made some noises I never heard before going over bumps, also the hatch was rattling.
I also noticed the blower motor makes a weird noise too when it's really cold, no noises when it's warmer than say 40 I guess.
This is on a 2012 MS3.
What the hell is this noise. DoMiNic MazdaSpeed 3 - Engine, Transmission & Driveline 34 01-24-2014 09:41 AM
What the hell is that noise? painfulpillow Gen2 MS3 General Discussion 15 12-19-2012 06:26 AM
bearing noise vs wheel noise? drag0nfire Mazdaspeed3/6 General Discussion 14 06-20-2012 07:32 PM
What the hell is this noise? event MazdaSpeed 6 - Engine, Transmission & Driveline 7 05-23-2010 01:26 AM
Lotus and Harman partner on noise-cancelling, noise-creating tech Haltech Automotive News 0 04-16-2009 05:00 PM
Page generated in 0.46918 seconds with 28 queries
