 Old 04-11-2019, 03:36 PM   #1
SkippyScallop's Avatar
Posts: 65   (View Stats)
SkippyScallop is an unknown quantity at this point
Default Wheel bearing and/or hub issue?
I searched and saw a couple different thoughts on this, but I'll try to be as specific as possible.
Typically when pulling in or out of a parking spot and the wheel is cranked, more so at wheel lock, I hear a kind of "wah-wah-wah" sound. I gather that I likely need to replace the wheel bearing and possibly the hub as well? If this is accurate, what other parts are recommended to be replaced at the time this work is done?
Anything else I should know?
Sent from my Pixel 2 XL using Tapatalk
SkippyScallop is offline   Reply With Quote
 Old 04-15-2019, 11:01 AM   #2
MSMS3's Avatar
Posts: 2,826   (View Stats)
Where does the sound come from? Can you isolate it to the wheel-well area either far left or far right?
If it comes more from the center of the engine bay, then it may be an inner CV joint on either side or might just be the limited slip differential needing some friction modifier (which wears out over time), or might be the power steering pump.
 Old 04-15-2019, 11:42 AM   #3
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
a wheel bearing would make noise while driving and get worse when turning the opposite way so i don't think it is your case.
Does it sound like a slipping belt ? if you turn each side when the car is not moving but engine running, do you ear the sound ?
Does it get worse if you give more throttle when turning ? (an axle joint)
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 04-17-2019, 11:31 PM   #4
Mazda3Blog's Avatar
Posts: 35   (View Stats)
Mazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to all
My money is on the LSD making normal noise in this car. Assuming it's a Speed3 of some sort.
My LSD has made the wah wah since new and it's held up just fine. Wouldn't worry about it.
Did you change your tranny fluid recently and that's why you didn't hear it before?
2010 Black MS3 (autocross/track duty)
Stratified tune, Accessport, Corksport HPFP, Corksport TMIC, Ultimate Racing test pipe, K&N intake, E-focus RMM, Corksport RSB, Corksport steering wheel + ebrake handle, solid shifter bushings, RE-71R tires
2007 Black Speed6 (daily driver)
Freektune, Accessport, Autotech HPFP, CPE TMIC, Ultimate Racing test pipe, Cobb intake + TIP, Corksport rear diff mount, CPE xflex RMM, Corksport rear brake pads, Matt Damond rear caliper bushings, solid shifter bushings, X-ice3 / AS3+ tires
Mazda3Blog is offline   Reply With Quote
Wheel Hub/Wheel Bearing Replacement Mashaustin MazdaSpeed 3 - Engine, Transmission & Driveline 1 08-07-2018 08:30 AM
Bad Wheel Bearing or Hub? qkrthnu2 MazdaSpeed 3/6 - Suspension & Brakes 3 05-28-2015 01:43 PM
Wheel bearing jracer MazdaSpeed 6 - Engine, Transmission & Driveline 94 11-09-2013 07:19 PM
MS3 wheel bearing going out??? buckeyepost MazdaSpeed 3/6 - Suspension & Brakes 22 01-07-2013 04:07 PM
Bad Wheel Bearing?? emag remrofni MazdaSpeed 3 - Engine, Transmission & Driveline 4 01-15-2012 10:43 PM
Page generated in 0.23749 seconds with 23 queries
