Mazdaspeed Forums
-   Mazdaspeed3/6 General Discussion (http://www.mazdaspeedforum.org/forum/forum/f505/)
-   -   When In Doubt Check It Out! (http://www.mazdaspeedforum.org/forum/forum/f505/when-doubt-check-out-128578/)
Payne Racing 67 10-27-2012 06:43 AM
Guys, I cannot stress this enough...ive heard of a few blown motors lately, all with the same situation. The car was acting up, so the person did a pull and ZZB! When in doubt, check it out. Stop and inspect for any suspects under the hood. If nothing is suspect feel the clutch for vibes. If its ok, drive it home very carefully and get it to the shop asap. If there are vibes in the clutch pedal theres a good chance you have a bent rod, so get it towed! Such a simple step can be so crucial and save you thousands and a lot of headaches. NEVER go WOT if it doesnt feel right! @Raider maybe this should be a sticky?
Sent from my GS3
rigor 10-27-2012 07:14 AM
that's what people don't understand is, these cars have enough powa to literally tear them selves apart, if something is over looked ...
this is a boosted car!, not a n/a car witch you can get away with murder and they will hardy never come apart ....
a boosted car is not going to put up with any shit for hardy anytime
2 good hard pulls, with a fair amount of kr on a boosted car, and your going to be picking your junk up out the street, and at the very least a bent rod...
Raider 10-29-2012 06:53 AM
ok, so drain the oil, drain the coolant, and do a pull. Got it.
Thread stuck.
Payne Racing 67 10-29-2012 07:10 AM
Quote:
Thread stuck.
Exacary!
Sent from my GS3
93silvergt 10-29-2012 07:10 AM
Thread stuck.
I like to let the freon out, weight reduction. And gets me high/dead.
helmetface 10-29-2012 07:17 AM
Quote:
Worse high for the money.
Ask me how I know.
twincitySPEED6 11-04-2012 04:54 PM
The vibs in the clutch I'm still not certain on that. Are they very noticeable? I feel very light ones in mine seemed normal as my previous car did the same. I've also noticed it a while ago when I first came to research through this forum and that was about 25,000 miles ago
Payne Racing 67 11-04-2012 05:20 PM
Quote:
Its natural to feel some, especially with motor mounts. If theres a bent rod itll really be noticeable and gradually get worse
Sent from my GS3
manila 11-04-2012 05:27 PM
Just curious if you had a bent rod would it show in your logs? For example, while doing a log would it show up in the KR table?
I've noticed a small amount vibes after my TP install, but those could possibly be from the movement of the TP? I have the SURE TP and it doesn't use hangers.
Payne Racing 67 11-04-2012 05:38 PM
Yeah thats related to the TP...it depends how bad it is. If the rod is pretty bent yes it should show in the logs
Sent from my GS3
cowboyup31078 12-25-2012 08:54 PM
i just replaced 2 bent rods in my ms6. i didnt know it until i thought i had a bad piston ring. come to find out i had a bad injector seal on #4 piston and 2 bent valves and a soon to be leaking head gasket.
Payne Racing 67 12-25-2012 09:14 PM
Quote:
And you werent getting any KR/clutch vibes???
Sent from my GS3
cowboyup31078 12-26-2012 11:19 PM
no i didnt get anything. and then i had a bad rough idol. that was all
Evan002 01-06-2013 10:34 PM
Ok I've been trying to figure it out, what is a TP?
silvapain 01-06-2013 10:46 PM
Quote:
TP = Test Pipe. It's the section of the exhaust containing the second catalytic converter.
Tapadatass
Evan002 01-07-2013 12:32 AM
Quote:
Tapadatass
Thank you for clearing that up for me
cowboyup31078 01-25-2013 08:39 PM
well finally got all of it running great and then my timming chain tensioner took a dodo.
SeeMeGovan 06-17-2013 01:42 AM
Not engine stuff but I heard a wub-wub driving back from the gym the other day, so I turned down my dubstep and it was still going wub-wub. Pulled over immediately and my front left wheel had half the lugnuts so loose I could unscrew them with my fingers. I check them bi-weekly. I'd driven ~500 miles last weekend but that's scary as hell how loose they were. I keep a 150 ft-lb torque wrench in my car for this kind of stuff so I hit them all with an 85 and the sound went away. Crisis averted but it coulda been a really shitty day if I didn't pull over right away.
JBerry 07-26-2013 10:20 PM
Thought I did check everything out the day I lost my engine. The crown of my third piston cracked off and was floating around in the cylinder. I also found I had a cracked turbo. Shit balls for shitty days.
bunta 02-16-2014 06:18 AM
Will the vibration be extremely noticeable? Sometimes just driving on crappy roads make it hard to tell what is really vibrating.
Page generated in 0.18743 seconds with 11 queries
