 Old 02-12-2009, 07:27 PM   #1
Smokehouse's Avatar
Posts: 653   (View Stats)
Smokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the world
Default Why is the battery box vented via the "ram air" system?
This one confuses me...The first time I really got under the hood of this thing I noticed there's a duct running over to the battery box...does this seem like a waste of ram air or am I missing something?
I swear I can smell your stinky hands from here...
Smokehouse is offline   Reply With Quote
 Old 02-12-2009, 07:29 PM   #2
i guess they figured it would help longevity due to being placed so close to the turbo.
 Old 02-12-2009, 07:37 PM   #3
Smokehouse's Avatar
Hmmm...never thought of that one, I've just never seen that done before.
 Old 02-12-2009, 07:40 PM   #4
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
Groans: 38
a cool(not cold) battery will perform better than a battery thats hot as fuck. It will give more consistent performance and will start the motor faster/better. This car is pretty high compression so the battery needs to be good to get it cranking.
bykeryder4life is offline   Reply With Quote
 Old 02-12-2009, 07:44 PM   #5
fbpem1's Avatar
Posts: 1,159   (View Stats)
fbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the world
Groaned at 47 Times in 40 Posts
i would consider this car a low compression motor, its not high by any standard.
fbpem1 is offline   Reply With Quote
 Old 02-12-2009, 07:49 PM   #6
Smokehouse's Avatar
sub 10 is low to me when considering a stock motor..doesn't the MS3 run some 9.5?...my GTO was 10.1...then again a Terminator Cobra is 8.5...
 Old 02-12-2009, 08:14 PM   #7
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
9.5:1 compression is high for a factory turbo car. My dsm is 7.8:1 compression.
My ford truck was only 9.1:1 compression from the factory naturally aspirated
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
 Old 02-12-2009, 08:34 PM   #8
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
yes, you are right, it is high for a turbo.
9.5:1 does not require a 1200 amp battery or something like that to crank the engine though. 400 amps and even less is probably enough.
Where you really need massive cranking amps is on diesels. Even the tiny turbo ones. Not jsut due to pressure in the comb chamber but also centrifugal mass.
You can probably hand crank the ms3.
 Old 02-12-2009, 07:50 PM   #9
Bob Ross Fanclub
Tomas's Avatar
Incorrect 1.
Cold batteries output lower amps than hot ones.
Keeping a maintenance free battery ( closed cell ) cool is for safety issues. Too hot = expand = crack / or even boom
Incorrect 2.
on the compression theory.
The high compression ratio is only under boost.
When the car is at still stand and the turbo isn't spooling the compression is less than a NA engine. Not sure on ms3 but probably about 8:1 or so???
 Old 02-12-2009, 07:54 PM   #10
Smokehouse's Avatar
Either way it seems a bit silly to me (other than the heat in the engine bay part due to the turbo).
If it didn't draw in so much water driving in the rain I'd find a way to pump it into my SRi instead of the battery box...
 Old 02-12-2009, 08:08 PM   #11
Bob Ross Fanclub
Tomas's Avatar
I've muled that idea too. One could even connect the chute to the stock air box. There are ways to circumvent water getting in the intake like cutting a ridge 1/2" wide along the engine facing side of the plastic elbow just after it starts going upward for drainage. Not sure if this would work.
You'd lose some of the positive pressure but there should still be plenty left. At nay rate more than the stock choker set up.
 Old 02-12-2009, 08:33 PM   #12
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
Thought about the ram air for SRI idea too.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
 Old 02-12-2009, 09:05 PM   #13
smakdown61's Avatar
Posts: 1,069   (View Stats)
smakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the world
Groaned at 37 Times in 23 Posts
Incorrect 1.
Incorrect 2.
Compression ratio has nothing to do with the turbo. The ratio of volume at BDC to TDC. You use bore, stroke, and clearance volume to calculate it. None of which change at any rpm.
smakdown61 is offline   Reply With Quote
The Following User Says Thank You to smakdown61 For This Useful Post:
mdogg (02-13-2009)
 Old 02-12-2009, 11:50 PM   #14
igve2shtz's Avatar
Posts: 72   (View Stats)
igve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant future
Right on. Thank you.
2006 MS6 Velocity Red Mica
SP63 built motor - SP63 9.5:1 Pistons - Manley Rods - JBR TRU-3" intake - BNR S3 - ETS 3.25" TMIC - Cobb XLE BPV - SP63 IM Port n' Polish - JBR TB TIG - JBR IM TIG - 3 Bar PnP (RPM) MAP - Autotech HPFP Internals - cp-e SafeSeals - NGK Plugs - Streetlite Flywheel - ACT 6 Puck Clutch - GrimmSpeed EBC - BSD - cp-e Catted Downpipe - Magnaflow CBE - cp-e RDM - cp-e Motor Mount - BC Coilovers - 215/45/18 Kuhmo 4x All-Season - Cobb Accessport V2- Prosport Premium Boost Gauge - Vent Pod - Dashhawk - Audiolink iPod Adapter
igve2shtz is offline   Reply With Quote
 Old 02-12-2009, 07:41 PM   #15
FCmaniac's Avatar
Posts: 330   (View Stats)
FCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond repute
Batteries need a form of ventilation. All cars that have the battery enclosed should have some form of ducting going to it to keep it cool. My RX-7 had a duct tube going to it too from the grill area.
FCmaniac is offline   Reply With Quote
 Old 02-12-2009, 07:43 PM   #16
Smokehouse's Avatar
I know my Mustangs and GTO didn't...might be a Mazda thing.
 Old 02-12-2009, 07:57 PM   #17
FCmaniac's Avatar
Here's some info I found:
What is the purpose of the battery exhaust vent tube ?
Answer: When a battery is charged and discharged, water contained in the electrolyte is decomposed, generating hydrogen and oxygen gases. These gases are vented out of the battery through the exhaust vent tube to prevent potentially damaging high pressure gas accumulation.
 Old 02-12-2009, 08:11 PM   #18
It's to vent harmful and potentially explosive gases. This is why you can't use the stock battery in the trunk - you need a sealed battery for that.
 Old 02-13-2009, 11:42 AM   #19
Thermonuclear Skeet
FantasmoNegro's Avatar
Posts: 2,810   (View Stats)
FantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the world
Groans: 188
Groaned at 333 Times in 222 Posts
Both sides of the Compression arguement are correct. The Mazda is high compression for a factory force induction motor. Most NA cars that run this CR required premium fuel before the advent of knock sensors. Most factory FI engines ran about 1 to a full 2 points below what our car comes with. But because Mazda is running direct injection in this car they got a little bit braver with the CR, but not totally confident, thus the reason why we have such a cocksucking knock sensor. (Mazda making up for the benefits of direct injection with higher CR is why I say yall are stupid for running a higher AF ratio than 12-12.5:1 and thinking it will be fine.)
Now what Thomas was saying is correct to a degree as well. Different things can effect the static compression ratio and I think that is what he was hinting at. When your motor is in motion more things than just the mechanical aspects effect how much compression happens within the cylinder. Cams play a major role and so does any added atmospheric pressure, timing, as well as variable valve events. Which makes me even more iffy about being brave with my engine as far as so called "New tuning methods and theory for DI" are concerned.
Just trying to prevent a future shit fest.
El Fantasmo Del Negro
Helicopter Cat LIVES
FantasmoNegro is offline   Reply With Quote
 Old 02-13-2009, 05:04 PM   #20
Bob Ross Fanclub
Tomas's Avatar
Exactly, thanks.
I just didn't want to get into bmep ( break mean effective pressure ) and other stuff. Just wanted to make a simple argument that the ms3 does not really have to overcome a lot of resistance to get cranked up. If you are really interested in this stuff, though, please read on!
The mean effective pressure is an abstraction of the pressure exerted into the combustion chamber of an internal combustion engine. Mean Effective Pressure is defined as the average pressure that the gas exerts on the piston(s) through one complete operating cycle of the engine. This definition can be expressed in terms of the work per operating cycle as
Work Per Operating Cycle = (Mean Effective Pressure) x (Swept Volume per Operating Cycle)
Since the work per cycle can also be expressed in terms of torque, the work equation becomes
(Torque) x (2 π Revolutions per Cycle) = (Mean Effective Pressure) x (Swept Volume per Operating Cycle)
The Swept Volume per Operating Cycle is its Displacement. For a two-stroke engine, the operating cycle is one revolution; for a four-stroke, two revolutions. Hence, Mean Effective Pressure in terms of Torque and engine parameters is
Mean Effective Pressure = 2 π (Torque) x (Revolutions per Cycle) / Displacement (May be incorrect! 4th Feb 09 RicardoUK)
Mean effective pressure is abbreviated MEP. BMEP or "Brake" MEP is for denoting dynamometer testing. IMEP is the MEP produced in the combustion chamber (acting on the piston crown) while BMEP is what remains at the flywheel after friction losses in the moving parts of the engine. FMEP (friction mean effective pressure) is a measure of how much MEP is lost to friction so:
BMEP = IMEP - FMEP
BMEP is calculated by taking the torque exerted by the engine over a revolution for a two-stroke engine and two revolutions for a four-stroke, and dividing it by its displacement. In SI units, for MEP in pascals
MEP = 2 π T / V for a two-stroke,
MEP = 4 π T / V for a four-stroke.
where
T is torque (in newton metres)
V is volume (displacement) (in cubic metres)
if you want to calculate directly in Bar then use formula below,
MEP = 4 π T / (V*10^5) for a four-stroke.
For example, a four-stroke motor producing 160 N·m (the rotating speed is irrelevant, but the torque is the power divided by it) from 2 litres of displacement is going to have (4π)(160 N·m) / (0.002 m³) = 1005000 N/m² = 1005000 Pa = 1.005 MPa of BMEP (or 10.05 bar).
If the same engine produces 76 kW at 5400 rpm (90Hz), its torque is 76000 W (or N·m·s-1) / 2π / 90 s-1 = 134 N·m; its BMEP will be (4π)(134 N·m) / (0.002 m³) = 0.842 MPa (8.42 bar). As piston engines always have their maximum torque at a lower rotating speed than the maximum output, the BMEP is lower at full power, it's because the efficiency is lowered by more friction losses, air viscosity, below optimum combustion, etc.
Another way to look at this. Because power is proportional to torque x speed, the power will continue to increase until the point where torque is decreasing more rapidly than speed is increasing. Peak power will occur at the RPM where torque is falling at exactly the same rate as speed is increasing. Obviously peak torque (torque neither rising nor falling with change in speed) must have occurred earlier in the RPM range.
To gain a step, the formulas for coming directly from power are, because P / (2πf ) = T
MEP = P / (f·V) for a two-stroke,
MEP = 2P / (f·V) for a four-stroke
where
P is power (in Watts)
V is volume (in cubic metres)
f is rotating speed (in Hertz)
MEP is a useful comparison tool between different engines, and is a good indicator of the level of performance achieved by the designer and manufacturer. As suggested by the formula for BMEP, it can be considered as an indication of specific torque - ie torque per unit displacement. This makes BMEP useful for comparing the torque produced by engines of differing displacements. It is important to remember that the values produced by the formula are for theoretical analysis only, and do not reflect the actual pressures inside an individual combustion chamber.
 Old 02-13-2009, 05:09 PM   #21
Bob Ross Fanclub
Tomas's Avatar
oh, yeah.
that was a wikipedia quote. Not the people start thinking I am plagiarizing or unworthily taking credit here.
 Old 02-13-2009, 05:22 PM   #22
Thermonuclear Skeet
Groans: 188
oh, yeah.
That is what I thought the point you were making was. I beleive I was wrong in my post. I beleive that the normal CR people talk about is Static Compression and the pressure you were talking about was MEP, but to cam grinders its also called compression ratio as well. My other cars cams are so good at making power because it doesn't focus on clearing air as quickly as possible like most cams do but instead it increased the cylinder pressures within the cylinder.
VIDEO: Audi RS5 at the Nurburgring is "böse" - that's German for "evil" Haltech Automotive News 0 01-19-2009 06:10 PM
Nike outlet puts the "RS" in "sneakers" Haltech Automotive News 0 12-31-2008 04:30 PM
Spy Shots: BMW X6 5.0iS puts the "sport" in "sports activity coupe" Haltech Automotive News 0 07-28-2008 06:30 AM
Pics Aplenty: MANSORY McLaren SLR "Renovatio" and Ferrari 599 GTB "Stallone" Haltech Automotive News 0 04-08-2008 04:20 PM
Volkswagen drops "Passat" sticks with "CC" for new sedan Haltech Automotive News 1 04-03-2008 04:29 PM
Page generated in 0.44138 seconds with 31 queries
