  • 1 Post By Fstrnyou
 Old 10-22-2017, 11:17 AM   #1
meekerMS3's Avatar
Posts: 29   (View Stats)
meekerMS3 will become famous soon enough
Default WMI Advice
Hello All (this is posted in the fuel, nitrous, water section as well.mods feel free to move or delete one)
After reading numerous threads and researching as much as possible, I figured I would see if anyone can offer direct advice. I have a 08 MS3, no plans to go bigger than the K04, so just want to use the kit mainly for cooling purposes. (Mods: Cobb AP, fuel pump internals, TIP, SRI, TMIC, BPV, DP/RP, EBCS, one step colder plugs...protune scheduled for next Tuesday).
Just looking for current/up to date advice regarding the best kit to go with and any installation write ups out there.
I am leaning towards the Cooling Mist stage 2 CMGS kit with auto learn failsafe universal kit, and use the Damond Motorsports throttle body mounting plate. Just wanted to see if this is a good option or if there is something better to look into?
Thank you for any help/advice!
meekerMS3 is offline   Reply With Quote
 Old 10-22-2017, 01:53 PM   #2
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I have the same setup and it is working perfectly after more than 3 years now.
The only bad thing about the CM is that you need to run a boost tube from the engine bay into the cabin for the CMGS controller and you will have to drill the floor for that (pick a good spot near the steering column and run the wires and boost tune through a rubber collar/seal, then seal everything up with silicone), but once done it's done and no need to go back to it.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 10-22-2017, 03:58 PM   #3
meekerMS3's Avatar
Okay awesome, that sounds good to me. Did you get the kit with the failsafe?
Also, as far as the meth tank goes itself, what did you do for that (size/mounting location)
How challenging was the wiring?
 Old 10-22-2017, 06:30 PM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
http://www.mazdaspeedforum.org/forum/foru...on-kit-213997/
lovmyrx7 likes this.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 10-23-2017, 08:57 AM   #5
mituc's Avatar
Groans: 111
I did get it with the failsafe (even though I think it's kind of built-in).
I have the 1 gallon tank mounted in the driver fender.
First Romanian BT MS3
 Old 10-23-2017, 05:30 PM   #6
meekerMS3's Avatar
This is awesome!! Thank you for documenting the whole process!
 Old 10-23-2017, 06:18 PM   #7
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Go through my started threads, I have a bunch of methanol injection threads. In one thread, I remember comparing the damond throttle plate to pre-TB injection, and I had better performance pre-TB versus the throttle plate adapter.
MINI H1 6.0 - CAR LED TAILS
 Old 10-23-2017, 06:59 PM   #8
Fstrnyou's Avatar
I've also noticed similar claims. IF I do WMI, it'll be pre-TB or racecar port WMI.
Other rides:
History:
 Old 10-23-2017, 08:36 PM   #9
meekerMS3's Avatar
If I’m remebering correctly, I did read your thread about it which ultimately made me cancel the order before they shipped it. I think you started having kr with the location change to the Damond TB plate. I’ve also seen other says that for cooling purposes pre TB is best. I will check out all of your other threads too. Thank you so much!
At this point since my tune is already scheduled and I need to get a good 93oct tune asa well, I’m planning to jump on the ethanol train since it’s readily available here. Also gives me more time to thoughtfully plan out the wmi kit and install.
From everything I’ve read here, pre TB is best for cooling, post TB is best for extra fueling.
08 MS3 - RMM, AP, Autotech internals, CS TIP/SRI, CS Boost tubes/recirc tube, CS TMIC, CS BPV, DP, DMS OCC
Last edited by meekerMS3; 10-23-2017 at 08:36 PM. Reason: MSF Database - Automerged Doublepost
Need advice/help wes3id MazdaSpeed 3/6 - Dyno Sheets/Discussions 10 01-31-2016 02:17 PM
Need some advice RUMBLEFISH Mazdaspeed3/6 General Discussion 10 03-27-2014 10:58 AM
Need some advice Misfit_S3 Drag Racing 3 02-23-2014 09:01 PM
Page generated in 0.31075 seconds with 23 queries
