> Cobb Tuning
View Poll Results: What intake are you using on your 1st Gen? (excluding COBB SRI and MAZDASPEED)
CP-E Xcel or Xcel Nano 32 53.33%
Injen CAI 5 8.33%
Corksport SRI 7 11.67%
Takeda CAI 1 1.67%
AEM CAI 9 15.00%
HPS CAI or SRI 1 1.67%
Fujita CAI 2 3.33%
K&N Typhoon 2 3.33%
Turbo XS CAI 0 0%
HKS Racing Suction 1 1.67%
Voters: 60. You may not vote on this poll
 Old 07-26-2010, 04:55 PM   #1
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Default 1st Gen MS3 Intake Poll
Everyone,
We are gathering information on aftermarket intakes to help us prioritize which AccessPORT Off-The-Shelf maps we should create for the 1st Gen MS3. Please select which intake you use on your car. We had to group the CP-E Xcel and Xcel Nano as well as the HPS CAI and SRI. We'll get into more detail on the individual products from these manufacturers later.
There were also several requests for maps with Turbo Inlet Pipes. Since we have seen that boost pressure can increase by removing the restriction of the stock TIP, we will create additional maps that include an aftermarket TIP. We still have yet to determine if all of the TIP manufacturer's products can be covered with a single TIP map adjustment, or if there is enough performance difference to require unique maps for each TIP.
Thanks very much for your input!
Gary
MAZDASPEED EXPERT GROUP
- ADAM HILL | MIKE MCGINNIS | RYAN LAMBERTH | CHRIS MOUNTAIN | MARSHALL GLASGOW
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE | EMAIL CUSTOMER SERVICE
The Following 3 Users Say Thank You to Cobb Tuning For This Useful Post:
08_ms3_gt (07-27-2010), DaleNixon (08-03-2010), mr_mazda329 (07-27-2010)
 Old 07-26-2010, 05:01 PM   #2
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
I think there should be two TIP maps. One for metal TIP's and another for silicone. That way they're both covered.
NATOR PA
09Speed3Z (07-31-2010)
 Old 07-26-2010, 05:18 PM   #3
That's a good point. It may work out that way. We'll see what we learn in testing.
Gary
 Old 07-27-2010, 12:24 AM   #4
fyrecrotch's Avatar
Posts: 123   (View Stats)
fyrecrotch has much to be proud offyrecrotch has much to be proud offyrecrotch has much to be proud offyrecrotch has much to be proud offyrecrotch has much to be proud offyrecrotch has much to be proud offyrecrotch has much to be proud offyrecrotch has much to be proud offyrecrotch has much to be proud of
<vote value=excluded text=COBB> Good luck!
I've done some unholy things to the car...nasty disgusting, locked doors in a dank basement perversion...she loves it.
fyrecrotch is offline   Reply With Quote
 Old 07-27-2010, 05:09 AM   #5
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
i'm glad to hear that you are working on more OTS maps
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
[sold - 90 Miata - summer/project car, turbo w/ goodies, DIYPNP, springs/struts, etc.]
[sold - 08 MS3 GT - intake/downpipe/tuning/fuel pump/TMIC/springs/struts/etc.]
08_ms3_gt is offline   Reply With Quote
 Old 07-27-2010, 05:47 AM   #6
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
lawlz. here's what hypertech has already mapped. thank god for competition.
Cold Air Intake Tuning AEM Brute Force, BEGi Cool Air System, Cobb Tuning SF Intake, CorkSport Short Ram, Custom Performance Engineering Xcel Nano Air, Custom Performance Engineering Xcel Cold Air, HKS Racing Suction Intake System, Injen Cold Air, K&N Typhoon, MAZDASPEED Cold Air, Takeda Attack
 Old 08-01-2010, 11:49 AM   #7
aspiring turbo guru
08_ms3_gt's Avatar
but do they have maps for stage 2 cars?
and is there custom tuning available to the end user such as with ATR?
and is it possible to monitor/log parameters such as the AP can?
from looking around their website, the answer is no to all of the above.
Originally Posted by egmazdaspeed3 View Post
If i'm not mistaken, AEM makes the Mazdaspeed CAI so the Mazdaspeed CAI map should work for the AEM CAI.
Does cobb have a map out there for a catless downpipe and test pipe?
they don't have a map for the catless downpipe nor test pipe, but it would appear as though stage 2 maps can be run for both. not optimal, but possible.
with a stage 2 map and test pipe, my experience was that the car didn't boost like it could have.
i think others have said that a catless DP may cause overboost (and maybe boost creep?) with stage 2 maps.
with either situation, you can tweak a map w/ ATR.
Last edited by 08_ms3_gt; 08-01-2010 at 11:49 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-03-2010, 11:19 AM   #8
mazdaspeeding's Avatar
Posts: 260   (View Stats)
mazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the world
Groaned at 8 Times in 4 Posts
How long before these new maps are available....fall, winter? I am currently trying to make a Cobb or MSCAI stage 1 map work for my CPE CAI...everything's good except STFT and LTFT's...maybe I should just wait.
mazdaspeeding is offline   Reply With Quote
 Old 08-03-2010, 07:24 PM   #9
I'd like to get a few of the big hitter intakes mapped fairly quickly. However, the poll results are way lower than I would have hoped. Maybe it's because this poll is in the COBB subforum and isn't getting enough eyes on it.
I think I'm going to move this to an offsite survey so I can list more options and post this in the ECU Tuning section. I'd like to get a lot of people replying so that we make sure we have a good sampling from the community.
Gary
 Old 08-04-2010, 04:26 AM   #10
aspiring turbo guru
08_ms3_gt's Avatar
Gary
i did not vote b/c i have the cobb sri, which isn't available on the poll. that may be the case for a lot of AP users.
 Old 08-01-2010, 11:27 AM   #11
egmazdaspeed3's Avatar
Posts: 11   (View Stats)
egmazdaspeed3 is an unknown quantity at this point
AEM CAI, TURBO XS DP & RP, COBB Turbo Inlet, TURBO XS HV, HANKOOK Ventus R-S2 225/40Z/18, hidden hitch
egmazdaspeed3 is offline   Reply With Quote
 Old 08-03-2010, 07:48 PM   #12
R.MS3's Avatar
Posts: 987   (View Stats)
R.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the world
I think you got about 60% of people covered with the Cobb SRI and Mazdaspeed CAI, probably why there's so few posting. I believe the AEM CAI is the same as the Mazdaspeed version.
The rest of the majority are using the Cpe intakes, Corksport, and Injen/Fujita on that order just about.
Then there are the very few running big MAF intakes with a BT setup that most likely are not bothering posting here.
Hope that helps.
R.MS3 is offline   Reply With Quote
 Old 08-03-2010, 08:15 PM   #13
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
I think youll get MUCH more attention if you bring the information from the Cobb forums to here, This is pretty much the hang out for us ms3/6 guys.
Keep up the good work, I really never thought it would make much difference between a silicone vs metal tip, how it could change your values, just goes to show any little tiny thing cannot be overlooked with regards to proper tuning on a car.
As for Hyper-tech having all those intake maps, Ill admit thats pretty cool. And its prabaly a pretty good little programer for the average modder, gives you some more power, and its fairly priced.
But its not a Cobb ap or Cp-e SB
From that ive seen there is no custom maps for turboback exhausts and fmic mods, like the AP.
plus the pro-tunes or Custom ATR tuning and data logging, its just not in the same ball park as for as I am concerned.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO*
zx2man is offline   Reply With Quote
 Old 08-04-2010, 05:16 PM   #14
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
I have replied to the poll. CP-E Xcel
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 08-04-2010, 05:45 PM   #15
Jsn_Rob's Avatar
Posts: 116   (View Stats)
Jsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond repute
Wow, not that many folks have the K&N intake. If any one is wondering, I'm very happy with it.
Silver 08 MS3-
Purple Drank Racing Tune l CXRACING FMI l DO Methanol Injection l JBR 3.5 intake l Turbo XS DP, TP l ProSport Boost Gauge l HKS TT l Cobb AP l Cobb RMM l H&R Springs l Turbo Smart BPV l WOT Box l JBR side mounts l KMD internals l BNR Stage 1 turbo l Protegegarage SS l VTCS Delete | TB Spacer | CPE Injector Seals l BSD l 3 port EBC l Bosch 3bar MAP.
Jsn_Rob is offline   Reply With Quote
Gathering Intake Brands for Poll Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 34 07-28-2010 08:05 PM
Cold air intake vs short ram intake knarfies MazdaSpeed 3/6 - Turbo Induction 3 04-27-2010 04:15 PM
BPV AND BOV POLL 2010 MS3 2010 MS3 - Turbo Induction 32 02-18-2010 10:37 PM
CAI Poll zamdam MazdaSpeed 3/6 - Turbo Induction 60 08-19-2009 06:32 PM
Page generated in 0.36536 seconds with 31 queries
