> Cobb Tuning
 Old 05-03-2019, 07:53 PM   #1
Amnesia's Avatar
Posts: 13   (View Stats)
Amnesia will become famous soon enough
Default 2013 mazdaspeed Car having issues
HI everyone! Ive been reading and reading on the forums but i cant seem to find an answer to the problems im having with my car. I bought this car about a month ago and i wanted to do a cobb stage tune 2 eventually. I bought stage 1+ including the internal/ intake/ turbo inlet.
I installed these parts myself. After the install the car was running fine until i blew the turbo seal. I took it to the dealership(stealership) and they put in new turbo/ coil packs and spark plugs. When i picked it up they told me that it needs a tune because of the HPFP. I put the COBB stage map tune on it. That didnt fix it. The car will idle fine for about 10 minutes and it then eventually dies and i get a fuel system too rich in bank 1. Mazda tells me it needs a tune, Cobb tells me its mechanical issue. I need help please!Attached are the logs of it idling.
Should i just go back to stock internal?
Amnesia is offline   Reply With Quote
 Old 05-03-2019, 10:33 PM   #2
Speed3kid93's Avatar
Posts: 59   (View Stats)
Speed3kid93 has a spectacular aura aboutSpeed3kid93 has a spectacular aura about
Groaned at 18 Times in 7 Posts
seems to be running fine in this datalog. please post one where the problem occurs.
In this datalog is runs for 30+ seconds without an issue.
HPFP, Corksport Dp to CBE, cobb SRI and TIP, Cobb big front mount intercooler, corksport RMM, eibach lowering springs, accessport v3 with e50 tune by Will @ pd tuning 22 psi 11.8 AFR
Speed3kid93 is offline   Reply With Quote
 Old 05-03-2019, 10:44 PM   #3
Amnesia's Avatar
The End of the log is when the car died. It also started having white smoke now. As it was before the turbo replacement. When i got the car back from the dealership, i Drove it for probably 50 miles and got to a stop sign and the car died.
Going 60 on the high way and put it in neutral and the car died. i wish i had it logged..
 Old 08-07-2019, 10:23 AM   #4
tripppleP's Avatar
Posts: 97   (View Stats)
tripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to behold
Did this problem ever get resolved?
tripppleP is offline   Reply With Quote
 Old 08-07-2019, 10:39 AM   #5
Police - Grammarhead
Vansquish's Avatar
Your assessment is incorrect. You clearly either didn't read the log, or you don't know what you're talking about. There is definitely evidence in the log showing that the car is not running properly.
Your car is running insanely rich for most of that datalog. Your idle AFR should be around 14.7:1. Your car is sitting at at 8.6:1 to under 12.0:1 for most of your log. That's between about 23% and 71% more fuel than the car is supposed to be getting at idle. Additionally, your fuel pressure is elevated. I would expect to see between 400 and 500psi at idle, not 800-1200psi.
To me, this looks like you're either running entirely the wrong tune for the modifications on your car, or you've got a something blocking airflow in the intake tract.
For the moment, there is no reason to remove the fuel pump internals that you have installed. Aftermarket HPFP internals can be run on the OEM tune without problems. Likewise, they can be run on aftermarket tunes without issues.
What *exact* tune map are you running, and what *exact* modifications are on the car?
Have you checked the intake system to see if there is anything blocking airflow?
dagrimey1 (08-26-2019)
« Cobb ATR | - »
Mazdaspeed 6 issues... drive_sideways Mazdaspeed3/6 General Discussion 45 10-01-2017 05:55 AM
2013 speed starting issues kennyg1966 Gen2 MS3 General Discussion 20 09-27-2017 09:00 PM
2007 Mazdaspeed 3 Misfiring issues HELP Eustache MazdaSpeed 3 - Engine, Transmission & Driveline 9 01-08-2016 09:19 AM
VVT actuator issues on my 2013 Jinba Ittai 2010 MS3 - Engine, Transmission & Driveline 13 04-07-2014 01:36 AM
Page generated in 0.26578 seconds with 24 queries
