| Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,747
(Thread Starter) | Not Ranked : 0 score Just started happening tonight, and i was wanting to see if it's happened to other members, and if so what caused it. I went to load an ots map, and it does all the normal stuff, "communicating with ecu" then "loading and verifying map files" then just gets stuck on the cobb logo and nothing else comes up. I tried unplugging, reloading maps..ect. Any info is appreciated, i'm hoping it doesn't require me to have to send it in for repair.... I will be calling Cobb monday, i just wanted to get some insight from fellow members. ***UPDATE For anybody with this issue in the future, i found the fix on about the 10th page in the Mazda section on the Cobb forums. There seems to be a bug in the system that doesn't show often, but is related to "custom" tunes loaded in to the accessport that causes the screen to freeze and the maps not to load. First, delete ALL "custom" tunes from your accessport, then just reload them and it should work fine. It is a easy fix, but after a few days of google searches i found nothing, so hopefully this will come up if searched.
__________________ 2013 CWP - HPFP - 80d RMM - 3.5" INTAKE - CAT LESS EXTENDED DOWN PIPE - 3PORT - METH/WATER INJ D03 [SIGPIC][/SIGPIC] First 11 sec stock turbo MS3: 1.688, 7.676 @ 91.71 11.977 @ 113.85 Last edited by MZRSPEED; 12-02-2012 at 08:05 AM. Reason: found fix |
| The Following User Says Thank You to MZRSPEED For This Useful Post: | Lex (12-02-2012) |
(Thread Starter) | Not Ranked : 0 score @Raider; could you move this to the cobb tuning vendor forum, please?
__________________ 2013 CWP - HPFP - 80d RMM - 3.5" INTAKE - CAT LESS EXTENDED DOWN PIPE - 3PORT - METH/WATER INJ D03 [SIGPIC][/SIGPIC] First 11 sec stock turbo MS3: 1.688, 7.676 @ 91.71 11.977 @ 113.85 |
![]() Join Date: May 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Just had exact same problem too
__________________ Cobb AP / CS Tip & Sri /Sure Flow M3 /Solid Shifter Bushes / SSP / REM Inserts / Forge BPV |
| The Following User Says Thank You to Danwelford For This Useful Post: | MZRSPEED (12-02-2012) |
| Cobb OTS maps ? | Cyan | 2010 MS3 - ECU Computer Tuning | 17 | 09-10-2012 01:20 PM |
| Cobb AP maps and TPS | Mattius604 | 2010 MS3 - ECU Computer Tuning | 3 | 05-29-2012 04:40 PM |
| can BNR stage 1 use cobb OTS maps? | numbnuts22715 | MazdaSpeed 3/6 - ECU Computer Tuning | 7 | 01-02-2012 01:17 PM |
| really confuse on the cobb AP maps.. help :/ | Sniper2606 | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 10-26-2009 07:15 PM |
