COBB Tuning announces the immediate availability of the first generation
MAZDASPEED3 Front Mount Intercooler v2.0 Retrofit Kit. This retrofit kit includes all
FMIC v2.0 components except for the intercooler core, allowing owners of the original COBB
FMIC kit to upgrade to the latest versions of boost tubes, silicone couplers, clamps and brackets. This revised layout provides more clearance for the frame rails, bumper beam and oil lines allowing for easier installation and less chance of contact between the chassis and kit components.
The COBB Tuning
FMIC v2.0 Retrofit Kit features 2.5-inch powder-coated charge tubes with blue 5-ply silicone couplers with T-bolt clamps plus everything you need for a simple and painless installation. Just like the full COBB Tuning intercooler kit, this retrofit kit comes with the COBB Tuning lightened shifter weight for improved fitment and more precise shifting feel.
The COBB Tuning
FMIC v2.0 Retrofit Kit for the MAZDASPEED3 is available now for purchase from COBB Tuning.com with free ground shipping.
- 2.5" aluminum tubing powder coated dark gray.
- Piping has been revised so that it does not interfere with the frame rail, bumper beam and oil lines.
- 5-ply blue silicone couplers.
- Stainless steel t-bolt clamps.
- Powder coated black mounting and power steering cooler relocation brackets.
- Stainless steel fasteners.
- Will work with stock BPV or aftermarket BPV that is stock style fitment.
- Retains the stock bumper beam and does not require cutting the bumper beam.
- Under tray can be reinstalled with no modifications.
- Does not require disconnecting of the power steering lines.
- New shift weight that is 0.66 lbs less than stock which improves the shift feel and allows for more pipe clearance.
