> Cobb Tuning
 Old 09-02-2012, 03:32 PM   #1
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Default Has anyone written tool to diff compare 2 map files in AP?
Is there a tool that basically lists the diff (differences) between two map (.ptm) files? It is a little time consuming in ATR to go line for line and table by table to compare maps.
It would be an awesome tool if some program read in 2 map files and spit out the differences on a per table basis. Does such a thing exist?
 Old 09-02-2012, 03:36 PM   #2
You'd have to decode the .ptm file. I think COBB is not going to be pleased with something like this.
 Old 09-02-2012, 03:43 PM   #3
Would be a nice feature, but at the moment you would have to decrypt and/or decompress the map files.
 Old 09-02-2012, 03:55 PM   #4
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Would def be an awesome tool, but like ^ they said, not really doable by someone besides Cobb... I'll post it on the Cobb forum to see what they think though!
Sent from my iPhone using lame ass Tapatalk
 Old 09-02-2012, 03:59 PM   #5
Actually, there is a tool... its just depends on your aptitude level of actually being able to read code:
Beyond Compare - The file compare, folder compare and remote directory compare utility from Scooter Software
Ive been using it for years
 Old 09-02-2012, 04:04 PM   #6
hnda etr's Avatar
Groans: 90
Done!
https://forums.cobbtuning.com/forums...282#post667282
dale_gribble (09-02-2012)
 Old 09-02-2012, 04:08 PM   #7
^^ That will not work, try opening up a map, change just one value, save under a different name, the two files are completely different now when you do a hex dump.
 Old 09-02-2012, 04:28 PM   #8
I concur. I would only expect maybe a checksum and maybe a few bytes to change by changing 1 value. I diff'd two files the same way and the dump is completely different.
 Old 09-02-2012, 04:23 PM   #9
If Cobb provides the diff functionality as a high level feature in ATR then they don't have to worry about someone pursuing the solution deep into their map files.
For as long as the AP has been out in the tuner market and among a bunch of techies I am actually pretty shocked that this hasn't been done yet.
Done!
Thanks for posting that up. I will look forward to seeing their feedback.
Last edited by dale_gribble; 09-02-2012 at 04:23 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-17-2012, 09:58 PM   #10
weakdog85's Avatar
Posts: 493   (View Stats)
weakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the world
So let say you add a TIP and switch maps to accommodate the pipe. You have to go to each table and change them all again? There is no easy way to save the changes you've already made on a new map without changing what's important?
07 MS6 Sport.............
JBR Shifter Bushings * JBR RMM * JBR PMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP * Autotech Internals *
weakdog85 is offline   Reply With Quote
 Old 10-17-2012, 10:18 PM   #11
No, the encoding/encrypting of a map changes every time you tweak the littlest thing. This has nothing to do with how you see a map when you open it in the AccessTuner software.
weakdog85 (10-18-2012)
Rear diff locks while turning after SURE diff mount and brace install wettoast MazdaSpeed 6 - Engine, Transmission & Driveline 47 11-04-2018 04:50 PM
rear diff "stiff diff" brace vs. rear diff front mount giordanos4 MazdaSpeed 6 - Engine, Transmission & Driveline 18 03-03-2011 08:38 AM
Page generated in 0.31681 seconds with 25 queries
