> Cobb Tuning
 Old 03-18-2016, 01:53 AM   #1
leo766's Avatar
Posts: 300   (View Stats)
Default How come a stage zero tune frin COBB requires a SF intake?
why is it that cobb offers stage 0 maps only for SF intake on their site? If I wanted to try a stage 0 tune wouldnt it be a stock car? seems a bit monopolistic to make it seem that to even try an AP you basically have to buy an aftermarket intake, otherwise your only option on the cobb site is a stage 1 map if you select a stock intake on their map finder thingy....
I live at altitude of 10k ft now and need to figure out if the knock i am getting is from a bad tune or what. But atm my AP v2 is sitting unistalled since I am not interested in increasing power on an engine that isn't even close to tuned for these conditions.
is there a stage zero map for a stcok intake anywhere? I just wanted to turn off my bloody EGR CEL(egr delted) not to mention get this car dialed in right for the altitude I now live at, so I wanted to do some good datalogging and maybe even install a 3 port ebcs and upgrade the MAP, while still keeping everything mostly stock in terms of power. I have had a protune in the past but at this point as i said before am interested in just running the car on a stock like tune without needing any aftermarket stuff to make it so, I alredy have a cp-e CAI, buying a cobb SF just to run stage 0 is redicules.... any advice would be greatly appreciated, thanks.
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to leo766 For This Un-useful Post:
Easter Bunny (03-21-2016), Vansquish (03-21-2016)
 Old 03-18-2016, 04:46 AM   #2
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Well a stage 1 tune isn't going to increase power so just install the shit and stop over thinking it. Lol.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post:
 Old 03-18-2016, 05:17 AM   #3
leo766's Avatar
i guess....
 Old 03-18-2016, 05:47 AM   #4
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Any OTS map, stage 0, 1, 2, 3, 90 whatever, is going to need tinkering to properly fit your car and environment.
I'd encourage the 1 over the 0, and both are conservative. Load your choice & do a basic MAF Cal, just the closed loop portion to start while you do your troubleshooting for the KR symptom.
Is your sig mod list current? Changed plugs recently? Plug age/type/heat range/gap? Changed your oil recently? When do you get the KR symptom? Consistent load & RPM range, or does it vary? Do you change elevation substantially during your commute?
340hp / 371tq
Easter Bunny (03-21-2016), leo766 (03-20-2016), Vansquish (03-21-2016)
 Old 03-20-2016, 05:19 PM   #5
leo766's Avatar
thx for the replies guys, the mod list needs updating which I will do now...
i guess ill try stage 1, as far as when I see knock its at like 10% throttle around 2k rpm and i wonder if it has to do maybe with the fact I did an EGR delete, since the egr valve works at part throttle to idle conditions right? and here it is hella cold right now(below 0 every night)
also I am sure my intake manifold needs cleaning, thats on my summer tiem to do list with a ton of other things like doing my timing chain vvt actuator and injector seals.
But really I think I need to go do a compression test before anything else, I was asking about stage 0 because I wanted to delete the EGR CEL mainly and figured I could do that if I am going to datalog with my AP v2, but to do that i need to install a new map if I am not mistaken with EGR CEL turned off. Just didn;t want to damage or push anything with stage 1 but seems you guys don't think it will do much I will try stage 1 since in actuality i have a the cp-e CAI still and they say any map made for stock intake will work with it, so that is usually what I look for. But with COBB taking down so many maps for anything but their intake I am starting to wish I just bought theirs to begin with. Since it seems to have so much more support than the cp-e one (since even trying to find stuff for a stock intake is a crapshoot lol)
Thanks again for your guys input, it is much appreciated.
p.s. I know I should just get an e-tune, but I am trying to do some maintanence before shelling out money for a tune, since I figure tuning a car with worn out parts is only going to need a re-tune once you replace them. and thx for the spark plug notice, I have had a set ready to swap for almost a year now lol
The Following User Says NO Thank You to leo766 For This Un-useful Post:
 Old 03-20-2016, 08:13 PM   #6
someguyondrugs's Avatar
Posts: 81   (View Stats)
someguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud of
Stages are for strippers.
2012 CWP
AP V2, AT internals, COBB sf intake, NoName Ebay TIP, M2 long catless DP, JBR RMM, JBR SSP, Hankook v12s, E 48 selftune @ 326whp 380wtq
someguyondrugs is offline   Reply With Quote
 Old 03-20-2016, 08:36 PM   #7
Omega's Avatar
Posts: 441   (View Stats)
Easy way to rule out knock, 1-2 gallons of e-85 in the tank if it's available (or meth)... You can knock on higher power levels but if it disappears you can infer it's not false knock... The tunes for certain intakes are just MAF calibrations, you should be doing this on each car for best results, there's a pretty good walk through around here somewhere on it. That would be the ideal solution regardless of what you bought. Any pro-tune will do this for you too since you mentioned it's down the road.
2006 Super Clean BCM MS6
 Old 03-21-2016, 07:52 AM   #8
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Or contact a protuner as you are obviously in over your head.
The Following 4 Users Say Thank You to SofaKingAwesome For This Useful Post:
Easter Bunny (03-21-2016), MS3Shadow (03-24-2016), sh4d0w (03-21-2016), Vansquish (03-21-2016)
 Old 03-21-2016, 08:38 AM   #9
These cars knock a lot at part throttle. Wot knock is the only thing to be concerned with.
The Cobb sf is the only one with a stage 0 because they are the only onses that couldn't make an intake that would work with the stock tune without throwing a cel.
 Old 03-21-2016, 06:34 PM   #10
hollar1211's Avatar
Posts: 495   (View Stats)
hollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond repute
You can try an ots+ from some of the reputable e-tuners on here. I believe stratified is $50, and Freek is $75. I started with a Freek ots+ and had the egr delete code removed.
2008.5 Speed3 GT
Freek Tuned e33: Cobb AP, Autotech Internals, UR Test Pipe, CPE TMIC, JBR Power Path Stage 2 SRI-TIP/ Short Shifter/ Solid Shifter Bushings/ Heavy Shift Knob/ 88 Duro RMM/ EGR Delete & Block Off Plate/ Throttle Body TIG, NGK IX 6510, 18x8 +35 Drag DR-49
hollar1211 is offline   Reply With Quote
Cobb tune for stage 1 JBR intake tc0308 Cobb Tuning 7 02-27-2013 09:52 PM
cobb ap: is safe tune quicker than stage 0 tune? Fusion_MS3 2010 MS3 - ECU Computer Tuning 14 12-16-2012 02:27 AM
cobb AP stage 1 tune question CornBread 2010 MS3 - ECU Computer Tuning 5 03-23-2012 04:36 PM
What are the requirements for Cobb ap stage 1 tune? caesura 2010 MS3 - ECU Computer Tuning 3 01-23-2012 08:32 PM
Page generated in 0.30777 seconds with 27 queries
