> Cobb Tuning
 Old 08-31-2013, 07:19 PM   #1
iammike's Avatar
Posts: 1,415   (View Stats)
Default Ign BAT vs ECT Comp
Just browsing through maps looking at things and I noticed a very large difference between the v210 and v231 maps.
The Ign BAT vs ECT Comp (lowers final timing value based on BAT's or ECT's) in v210 is WAY more aggressive than the one in v231 despite the target timing values being the same between the two maps. The Comp % Used is also the same between the two maps.
I've always heard of people having more problems with KR on v231...thinking this could be a contributing factor.
Thoughts of the tuner heads? To be honest, the v210 makes a lot more sense to me.
Mike
 Old 08-31-2013, 10:06 PM   #2
In V2.10 the values are OEM. COBB decided to change these around in V2.31.
 Old 08-31-2013, 10:10 PM   #3
My freektune is similar to the v210, I was getting knock road racing on the map similar to the v231.
 Old 08-31-2013, 10:15 PM   #4
iammike's Avatar
Yeah, to be honest, the v231 seems ridiculous to me. I really wouldn't think you would want to run the same timing across that huge temp range. More when cooler, less when hotter, makes a hell of a lot more sense to me.
I don't believe I've ever seen my BAT's hit 173.
Mike
 Old 08-31-2013, 10:18 PM   #5
My BATs hit 200.75 at the track.
 Old 08-31-2013, 10:30 PM   #6
iammike's Avatar
Show off. lol I've not tracked so that would explain that.
Mike
The Following User Says Thank You to iammike For This Useful Post:
Code Monkey (08-31-2013)
 Old 09-15-2013, 02:41 PM   #7
Caldazar's Avatar
Posts: 293   (View Stats)
Caldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond repute
anyone from Cobb care to explain why they did it this way? I am sure there is a reason for it. Especially if its as simple as it seems on the surface
thanx!
06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver
91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's
Caldazar is offline   Reply With Quote
 Old 09-15-2013, 02:48 PM   #8
snailD's Avatar
Posts: 3,039   (View Stats)
these tables seem slow to respond in real world conditions so they need to be more agressive in order to work correctly. cobb changing them to such low values is likely causing KR with excessive heat because they pretty much wont change ignition values at all.
 Old 09-15-2013, 03:31 PM   #9
iammike's Avatar
Ran a little test. Took my current tune and made two versions, one with the BAT vs ECT Comp table zero'd out and another set to retard timing by 5 degrees in all cells.
Behaved as expected when also taking into consideration the "Ign BAT vs ECT Comp. - % Used" table.
At ~6200 RPM on the first map, spark advance was 11*. On the second map it was 8.5*.
While all that is probably obvious to a lot of us, for anyone just messing with tuning, just thought I'd lay that out there.
Requested Timing - (Ign BAT vs ECT Comp A/B * Ign BAT vs ECT Comp % Used) - Knock Retard = Actual Spart Advance
That's what I've come up with anyway.
Mike
Comp turbo kriss90 MazdaSpeed 3/6 - Big Turbo Builds 23 12-05-2011 01:49 PM
Building a new comp hyun Computers & Technology News 13 08-02-2010 07:28 PM
Boost Comp & RPM badams118
Cobb ATR Support
3 05-07-2009 12:36 PM
Page generated in 0.29618 seconds with 25 queries
