> Cobb Tuning
Like Tree16Likes
 Old 02-09-2012, 05:41 PM   #81
reading up on speed density asap.
Boosted Beluga (02-09-2012), djuosnteisn (02-10-2012)
 Old 02-09-2012, 05:58 PM   #82
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
We have a map sensor on the manifold don't we?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 02-09-2012, 06:10 PM   #83
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Yup.
While i totally see the application and potential usefulness for the VE table..... i'm still not 100% convinced on reason for it's existence. The whole purpose of a MAF sensor is to account for airflow. If VE falls off for some reason or another (like higher rpms, or inefficient turbo, etc etc etc)... airflow drops, and the maf completely accounts for it.
Lex had a decent idea suggesting it may have been used to account for air lost during over lap..... but i think even that's a hell of a stretch, hahaha.
But i'm not going to complain. Hopefully it sets the stage for potentially better uses down the road... like speed density. I heard Cobb had a similar release on the gtr shortly before they started supporting SD on that platform. So who knows... maybe they're just starting to get their ducks in row.
lol already posed the question to David as to when we would get SD like the scoobie guys...for those who don't know IIRC it took cobb over a year after the announcement of its coming to make it to fruition over there. NASIOC has a thread covering it.
anywho...he gave me an answer... something along the lines of "there are a few things we need to get into place before we can get to SD".....hum...two weeks after my question we get a VE table....coincidence? You be the judge.
The Following 6 Users Say Thank You to Dano For This Useful Post:
Boosted Beluga (02-09-2012), djuosnteisn (02-10-2012), Fobio (02-09-2012), Nataphen (02-09-2012), Tokay444 (02-09-2012), wolly6973 (02-10-2012)
 Old 02-09-2012, 10:48 PM   #84
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Make sure your "use boost based" toggle is enabled (checked), and all your load tables are set up accordingly. Then set your "max boost throttle close" table to like 24 or something for good merit. Should fix your issue.
I've tried enabling and disabling the "Use Boost Based Tuning" toggle, and I had my boost limit throttle close table set to 23 or 24 at the time. I even went back and forth with Braden @ COBB via PM, and we never got to figure it out; that's when he suggested I play with boost targeting instead
2.24 sounds like an unachievable load at 5k on stock turbo. Every stock turbo car Ive played with are at 2ish for load. Was your wgdc maxed or close to maxed (above 80%)?
Tappin
Not sure if I screwed up along the way (I don't think I did), but at the time of my load tuning attempt, I saw calc loads of up to 2.36, and it would hold well above 2.00 up to 5500 IIRC. Nowadays I barely crest 2.05, I think. My WGDC was nowhere near maxxed either, it was still well within my WGDC ramp limiter range, but at some point, the logs indicated that the ECU stopped adding WGDC completely, and there was no throttle close either.
Agreed fully. But... The load target greatly depends on the maf cal. If his maf cal is just wildly off, and he's compensating by targeting overly lean afrs... may still be feasible.
But yeah, f-cast.... make sure your load targets are even feasible first, haha.
My MAF cal is still within +/- 3%, even as far back as my load tuning attempt. As for my load targets, my ECU was able to achieve high calc. loads, so I targeted slightly lower than what I was seeing, just to be conservative.
I'm kinda happy with where my tune is at ATM anyways, so I won't bother with the load tuning for now. I'll be watching the VE discussions though
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline   Reply With Quote
The Following User Says Thank You to f-castrillo For This Useful Post:
 Old 02-09-2012, 10:56 PM   #85
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Yes. And it also includes BAT sensor. Its all in 1.
 Old 02-10-2012, 12:07 AM   #86
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
So, VE tables didn't do anything we hoped for. I'm too many beers in at this point to post logs, but I'll start a thread tomorrow.
f-castrillo likes this.
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 8 Users Say Thank You to phate For This Useful Post:
Boosted Beluga (02-10-2012), djuosnteisn (02-10-2012), Fobio (02-10-2012), rfinkle2 (02-10-2012), superskaterxes (02-10-2012), Tokay444 (02-10-2012), wolly6973 (02-10-2012), Ziggo (02-10-2012)
 Old 02-10-2012, 04:03 AM   #87
Tokay444's Avatar
Groans: 793
So what would be the purpose of putting one on in the maf housing like Dj eluded to?
With speed density, would we not be able to eliminate the intake all together and just run a filter or a screen on the turbo for a better pressure ratio?
Demodded.
The Seals
 Old 02-10-2012, 04:54 AM   #88
atvfreek's Avatar
Posts: 7,787   (View Stats)
Having a map/baro sensor before and after the throttle plate is better for load/boost calculation. It measures the difference on each side of the throttle plate. This is how the Ford sho ecoboost does it without a maf sensor.
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
Nataphen (02-10-2012), rfinkle2 (02-10-2012), silvapain (02-10-2012), Tokay444 (02-10-2012), wolly6973 (02-10-2012)
 Old 02-10-2012, 05:04 AM   #89
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Traditional speed density only has a MAP sensor in the intake manifold. It HAS to be after the throttle body or else fueling will be totally screwed.
This is how my Mustang is setup...
I have no knowledge of how the Ecoboost is using the second one.
The Following 2 Users Say Thank You to cld12pk2go For This Useful Post:
djuosnteisn (02-10-2012), rfinkle2 (02-10-2012)
 Old 02-10-2012, 05:07 AM   #90
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
still not sure why you would want to go SD over MAF.
if the ECU is so heavily based on the MAF why would u want to try and work around that? no one has reached a state were there is no more resolution for the MAF (unlike the subi guys who have some 300g/s limit).
its like the whole boost tuning logic. the ECU is load based and half the tables are scaled using a load axis so why would u want to brutalize your tune just to hit a certain PSI level?
hopefully someone can show me the way of SD!
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
The Following 3 Users Say Thank You to superskaterxes For This Useful Post:
Fobio (02-10-2012), rfinkle2 (02-10-2012), Ziggo (02-10-2012)
 Old 02-10-2012, 05:09 AM   #91
I read some about speed density last night, and was hoping to get some opinions on it from you guys, even if we may not use it in the future.
 Old 02-10-2012, 05:11 AM   #92
Ziggo's Avatar
Posts: 3,843   (View Stats)
Tag me please, I am interested in the results.
Zigatapatalka
Ask Me About My:
Boosted Beluga (02-10-2012), phate (02-10-2012), rfinkle2 (02-10-2012)
 Old 02-10-2012, 05:35 AM   #93
Ziggo's Avatar
The lazy\ricer reasons:
Boost\vacuum leaks don't affect fueling
BOVs
Better reasons:
MAF sensor is an intake restriction
MAF sensor requires a straight section of piping(better flexibility with intake piping)
Better part throttle response, particularly when compared to BIG maf cars. Allows massive intakes with little to no sacrifice in drivability, think 4" all the way (remember when the flow in the intake goes sub-turbulent, the MAF sensor readings become erratic)
The bad:
Think MAF cals are a pain in the ass? Try calibrating a 2d VE table, which will have to be touched for ANY hardware change after the throttle.
Our valve gunk will make VE table change over time.
VE table is not particularly stable over temperature, as turbo becomes more efficient at lower temperatures, lower exhaust mani pressure makes VE improve.
The Megasquirt has a function where you can run MAF below a certain threshold, and speed density above it, or vice versa. If you go this route, you could say, run a standard size MAF so drivability doesn't suffer, and before the MAF maxes out, switch to speed density. You gain headroom in that fashion, but IMO if you are maxing the stock MAF, you probably would be better off with a bigger intake anyway.
If you go the opposite direction it's racecar status and you use speed density for low load situations, but use MAF once there is enough flow to make the sensor accurate, so you get accurate, stable fueling at high throttle/WOT operation. You can really skimp on the VE table this way because the speed density area of operation is all vacuum, so pressure changes won't change VE very much, and who cares if it idles /off idles like shit, it's a racecar.
*All above information is solely the opinions of the author and does not reflect the ideas or opinions of his employer or the producers of this website*
Zigatapatalka
Ask Me About My:
The Following 11 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (02-10-2012), Boosted Beluga (02-10-2012), Dano (02-10-2012), djuosnteisn (02-10-2012), Enki (02-10-2012), f-castrillo (02-10-2012), Fobio (02-10-2012), Nataphen (02-10-2012), silvapain (02-10-2012), Tokay444 (02-10-2012), wolly6973 (02-10-2012)
 Old 02-10-2012, 06:11 AM   #94
Thanks Ziggo.
It seems like there is pretty heated debate and it was difficult to find factual info. on the pros and cons of one vs. another, but your explanation explained it exactly as I had hoped.
/secretly hoping not to have to delve into speed density @ this point
 Old 02-10-2012, 06:16 AM   #95
Ziggo's Avatar
Thanks Ziggo.
Personally I wouldn't touch it with a 10ft pole while wearing level 4 mopps
Zigatapatalka
rfinkle2 and atvfreek like this.
Ask Me About My:
The Following 4 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (02-10-2012), Fobio (02-10-2012), Nataphen (02-10-2012), rfinkle2 (02-10-2012)
 Old 02-10-2012, 06:26 AM   #96
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
@phate
Please tag me when you start that thread as well. I'm barely on here anymore except for subbed threads, so I probably won't remember to look.
@Ziggo
Don't ever change, LOL.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline   Reply With Quote
The Following 5 Users Say Thank You to Nataphen For This Useful Post:
atvfreek (02-10-2012), Boosted Beluga (02-10-2012), phate (02-10-2012), rfinkle2 (02-10-2012), Ziggo (02-10-2012)
 Old 02-10-2012, 09:06 AM   #97
Trail of Fail
Dano's Avatar
afaik the 300g/s cap is gone in the scoobie world...so IDK why they are so enamored with the thought of running SD....maybe its only the ricecars that want it so they can VTA and not worry about it.
from my discussions with Lex and what Ziggo has said here it sounds like shit to me.
 Old 02-10-2012, 11:13 AM   #98
SD = Shit Density? Had to do it.
Dano (02-10-2012)
 Old 02-10-2012, 11:26 AM   #99
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
It was a joke.
The VE table is load dependent, and the load source is the maf sensor.
For SD to work, you need 3 main ingredients, RPM (obv), MAP and manifold temp.
If our newly exposed VE table was MAP dependent, then no worries, it's ready for SD prime time right away (or at least playing around with it)...... BUT because it's load dependent (read MAF dependent).... it's not so easy.
So i was kidding around about using a MAP sensor, and wiring it into the MAF wire harness.... so that the MAF input is now MAP. And then the VE table would be MAP referenced.
But it was 99.9% a joke. Unless someone really wants to calculate out which loads each MAF voltage / rpm point corresponds to.... and then use that to create a VE table... and re-configure all their load dependent tables......
so yeah..... 99.9% a joke, lol.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Dano (02-10-2012), Tokay444 (02-10-2012), Ziggo (02-10-2012)
 Old 02-10-2012, 11:28 AM   #100
Tokay444's Avatar
Groans: 793
I hais teh stupids!
Demodded.
The Seals
 Old 02-10-2012, 11:29 AM   #101
It was a joke.
I think I'll join in and laugh after I read that about 10x's.
djuosnteisn (02-10-2012), wolly6973 (02-10-2012)
 Old 02-10-2012, 11:45 AM   #102
Trail of Fail
Dano's Avatar
hard enough to get the ECU to target boost consistently....SD would have to be next to impossible
does anyone here know why the scoobie guys are so excited about it?
 Old 02-10-2012, 12:02 PM   #103
Eth Fiend
phate's Avatar
Volumetric Efficiency table discussion:
Volumetric Efficiency Table and You
-06 MS6
The Following 5 Users Say Thank You to phate For This Useful Post:
Dano (02-10-2012), djuosnteisn (02-10-2012), f-castrillo (02-11-2012), Nataphen (02-10-2012), rfinkle2 (02-10-2012)
 Old 02-10-2012, 12:19 PM   #104
Ziggo's Avatar
Since the VE table is load referenced: you can't use MAP to calculate load to lookup VE to calculate load. Circular references mean nobody gets anywhere.
Supposing I were hacking the ECU and wanted to implement speed density, my function would halt the MAF lookup from the analog IO and instead inject a MAF value into the register that lookup was writing to. The injected MAF value would be calculated from the MAP, RPM and BATs. That way any function that was reading that register would continue to operate normally with a synthetic, speed density based MAF value.
The question is, which do you think is more accurate and faster::
MAF sensor voltage reading analog IO read
1D maf table lookup based on voltage to obtain MAF table values at high and low side of reading
1D linear interpolation between high and low values from table
Write interpolated value to register for "currernt" MAF
OR:
Read MAP value
Read RPM value
2D VE table lookup for high/low side values on either side of MAP and RPM
1D interpolation for VE based on MAP at low RPM
1D interpolation for VE based on MAP at high RPM
1D interpolation of two previous values for VE based on RPM
Calculate MAF for 2.3L @ RPM based on 100%VE @ MAP and BAT
Correct airflow based on inerpolated VE
Write airflow to MAF
Ask Me About My:
Dano (02-10-2012), djuosnteisn (02-10-2012), Nataphen (02-10-2012), rfinkle2 (02-10-2012)
 Old 02-10-2012, 02:08 PM   #105
OR:
Read MAP value
Read RPM value
I'm a good student of Ziggology, and would choose the 1st of the 2 methods (.5 because of the tone in which the question was written fml, and half out of wanting the ecu to do as little interpolation as possible, although I'm certainly no engineer).
Thanks for explaining the majority of the differences in SD vs. Maf based calibration.
I was reading many opinions last night, and came to the conclusion that I wonder why an oem like Ford would use SD as a factory calibration.
I don't want you to spend your time dumming things down for me Ziggo (even though I need it lol), although I appreciated the time you've already spent.
Thanks for bothering to type out what would have taken me hours of reading through opinions on which is better and trying to pull out what are the facts.
 Old 02-10-2012, 02:31 PM   #106
Tokay444's Avatar
Groans: 793
The current quickest ms6 on the planet is SD tuned.
Demodded.
The Seals
 Old 02-10-2012, 02:57 PM   #107
Trail of Fail
Dano's Avatar
doesn't make it the easiest to tune or drive...
jussayin
 Old 02-10-2012, 02:59 PM   #108
Paveltol's? Did you and Dano see his injector seal thread yet?
 Old 02-10-2012, 03:01 PM   #109
Tokay444's Avatar
Groans: 793
Mazdagaragepat.
Yes, I saw that.
I can't get a picture of the part though.
Every page I find that part number on has a different picture.
Demodded.
The Seals
 Old 02-10-2012, 03:02 PM   #110
Mazdagaragepat.
Yes, I saw that.
I chose the wrong country. LOL
 Old 02-10-2012, 03:15 PM   #111
Trail of Fail
Dano's Avatar
no PM me the link pls
rfinkle2 (02-13-2012)
 Old 02-12-2012, 03:54 PM   #112
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
How about this as a reason for existence.......... as a back up.
In case the MAF sensor fails?
Or maybe to detect a failing MAF sensor and throw a trouble code?
Suspension:
The Following User Says Thank You to FreeFlyFreak For This Useful Post:
djuosnteisn (02-13-2012)
 Old 02-12-2012, 05:16 PM   #113
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
or maybe there is a point that the SD/VE over rules our standard ECU logic? or at least a factor at some point for some reason? like AFR corrections for different fuel mixtures? Just throwing shit out there...
 Old 02-12-2012, 09:22 PM   #114
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
It's probably because its cheaper to manufacture. Cost of a MAF vs MAP sensor over xx vehicles is a pretty good savings.
Fueled by the haters.
2012 SCCA STX Auto-X build justint5387 MazdaSpeed 3/6 - Build Diaries 240 04-28-2014 07:19 PM
Help Hyundai build the 2012 Azera by... building a 2012 Azera Haltech Automotive News 0 08-30-2011 11:50 AM
Report: Akerson says GM will build Cadillac models outside North America by end of 2012 Haltech Automotive News 0 06-07-2011 12:50 PM
Rumormill: Honda to build road-going HSV-010 next year, pigs to take flight in 2012 Haltech Automotive News 0 03-29-2010 06:00 PM
Page generated in 0.56703 seconds with 35 queries
