> Cobb Tuning
Like Tree16Likes
 Old 02-03-2012, 08:30 PM   #41
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Not necessarily higher or lower... just "close". The only two tables i make sure are set higher are the throttle close and fuel cut. Then i just kinda set the targets to something close.... and turn my attention to load tables.
I have one guy currently who's WG is dropping on me... so i'm gonna take a close look at his tune tonight and see what i can come up with. I'm hoping there's something obvious (like boost based toggle empty, or throttle close table too low), but if not i'll let you know.
Prior to this update my boost tune had evolved to where my boost targets were actually being achieved from 3000-5500 and then I was targeting 1-2 PSI over what would actually be achieved above that trying to force things higher.
I had to limit the High limits on WGDC to ~7% and drop the WGDC from 3000-4500 from actual required to prevent overshoot and then I was lifting up the WGDC targets from 5500 + well above actual to try actually get close to what I wanted.
It just seemed like something was missing as it really shouldn't be this hard to have a PID loop actually achieve setpoints...
djuosnteisn (02-05-2012)
 Old 02-03-2012, 08:36 PM   #42
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
jesus MBC has made me stupid lol
why does everyone like to run EBCS?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 02-03-2012, 08:52 PM   #43
Ziggo's Avatar
Posts: 3,843   (View Stats)
For programmed boost creep fun!
Ask Me About My:
atvfreek (02-03-2012), Dano (02-04-2012), djuosnteisn (02-05-2012)
 Old 02-03-2012, 08:53 PM   #44
Eth/Meth Junkie
cld12pk2go's Avatar
MBC = it ain't broke
Me = Engineer
Since it ain't broke I have to fix it until it is...thus EBCS!
But seriously, my Mustang AEM EMS with ECBS and PI control on the boost works fucking awesome by gear (straight to target and holds to like 0.1 PSI solid). I would sooo like to be there on the Mazda...
I really don't see why this isn't easy for us too...
The Following 7 Users Say Thank You to cld12pk2go For This Useful Post:
atvfreek (02-03-2012), Dano (02-04-2012), djuosnteisn (02-05-2012), ms3blackmica (07-08-2013), rfinkle2 (02-04-2012), superskaterxes (02-04-2012), wolly6973 (02-06-2012)
 Old 02-04-2012, 05:57 AM   #45
actual release notes here:
MAZDASPEED AccessTUNER Updates
BlueStreak (02-05-2012), djuosnteisn (02-05-2012), f-castrillo (02-09-2012), wolly6973 (02-06-2012)
 Old 02-04-2012, 06:30 AM   #46
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
I have been load tuning with the "boost toggle" checked since v200 and it has been great. From what I'm reading, nothing about this update changes that. With regards to the TRL tables, I run ~ +0.05 uprate from actual. I might have said this before but I guess since I'm not as active anymore, it not noticed...lol...
David, please elaborate on some logic/methodology on how we can use calculated values to adjust the VE table. Thanks.
-- Mario Andretti --
The Following 3 Users Say Thank You to Fobio For This Useful Post:
BlueStreak (02-05-2012), djuosnteisn (02-05-2012), rfinkle2 (02-04-2012)
 Old 02-04-2012, 06:37 AM   #47
chintastic's Avatar
Posts: 299   (View Stats)
chintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the world
is the idle on the gen 2 able to raise with this update?
2013 CWP Mazdaspeed 3 : COBB TIH, COBB Intake, COBB AP, GFB BPV, SURE Shortcut, counterweight, and shifter bushings, Rally Armour mud flaps,
chintastic is offline   Reply With Quote
 Old 02-04-2012, 06:44 AM   #48
Yes.
 Old 02-04-2012, 06:55 AM   #49
chintastic's Avatar
thank u sir finkle
The Following User Says Thank You to chintastic For This Useful Post:
 Old 02-04-2012, 08:19 AM   #50
08cosmic3's Avatar
Posts: 2,920   (View Stats)
What is being done to resolve the lose of ecu contact when logging, happens to me way too often. Hit the log button, get into WOT and the AP quits. This only started with the last update for me.
 Old 02-04-2012, 09:31 AM   #51
Eth/Meth Junkie
cld12pk2go's Avatar
Maybe I just got lucky, but this didn't happen to me either on the way to or from work yesterday after the ATR update. It had been happening daily.
 Old 02-04-2012, 09:54 AM   #52
YokiMazoku's Avatar
Posts: 320   (View Stats)
YokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the world
08cosmic3 this happened to me as well. So i made sure my AP and everyrthing was updated then loaded my map in ATR and saved it back to the AP then reflashed it seems to have fixed my problem. Went on a 30min driver logging on and off without a problem.
Boobs.....because you can't motorboat a personality.
YokiMazoku is offline   Reply With Quote
 Old 02-04-2012, 09:55 AM   #53
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
if you have FWD you def want EBC or else all hopes of traction is but a pipe dream on street rubber.
I too employ a "reverse boost taper" in my maps.
cld12pk2go (02-04-2012), djuosnteisn (02-05-2012), rfinkle2 (02-06-2012)
 Old 02-04-2012, 10:02 AM   #54
08cosmic3's Avatar
I just updated to the new ATR, loaded and saved my map. I'll flash it to the car before going back out and see if this helps. Thanks.
 Old 02-04-2012, 11:13 AM   #55
A lot of people have the disconnection issue with the newer AP style and dongle connector. Mine is the old and low resolution model and I haven't had issues with disconnection - ever.
Fobio (02-04-2012), Nliiitend1 (02-04-2012), rfinkle2 (02-06-2012)
 Old 02-04-2012, 11:15 AM   #56
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Same here.
I'm sure I haven't done nearly as much logging as most guys, but I've never had a disconnection issue with my USB-dongle AP...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 02-04-2012, 11:19 AM   #57
Trail of Fail
Dano's Avatar
I don't think any of the V2a APs have the disco issue...only the V2b's....I have a V2a, log a TON, probably on flash v 12387463 to the ECU and never a disco issue.
BTW I am 99% certain there is no flash limit in our ECU
now watch me go out to flash later today and brick my ECU hahahahahahah
*knocks on wood*
The Following 4 Users Say Thank You to Dano For This Useful Post:
djuosnteisn (02-05-2012), Fobio (02-04-2012), Nliiitend1 (02-04-2012), rfinkle2 (02-04-2012)
 Old 02-04-2012, 04:17 PM   #58
Eth/Meth Junkie
cld12pk2go's Avatar
I am on map 269, so it is good up to that many at least.
The Following 2 Users Say Thank You to cld12pk2go For This Useful Post:
Dano (02-04-2012), rfinkle2 (02-04-2012)
 Old 02-04-2012, 08:19 PM   #59
Ziggo's Avatar
I am still having a ton of trouble figuring out what the VE table is used for in fueling calculations for a MAF based car. I know you say it is normalizing the numbers but I don't get it. I understand it fully for speed-density but not in this application the SAE load calculation doesn't include a VE number.
Absolute Load Value (PID 43)
The absolute load value has some different characteristics than the LOAD_PCT defined in PID 04 This definition, although restrictive,
will standardise the calculation. LOAD_ABS is the normalised value of air mass per intake stroke displayed as a percent.
LOAD_ABS = [air mass (g / intake stroke)] / [1.184 (g / intake stroke) * cylinder displacement in litres]
Derivation:
— air mass (g / intake stroke) = [total engine air mass (g/sec)] / [rpm (revs/min)* (1 min / 60 sec) * (1/2 # of
cylinders (strokes / rev)],
— LOAD_ABS = [air mass (g)/intake stroke] / [maximum air mass (g)/intake stroke at WOT@stp at 100% volumetric efficiency]
* 100%.
Where:
— STP = Standard Temperature and Pressure = 25 °C, 29.92 in Hg (101.3 kPa) BARO, WOT = wide open throttle.
The quantity (maximum air mass (g)/intake stroke at WOT@stp at 100% volumetric efficiency) is a constant for a given cylinder swept
volume. The constant is 1.184 (g/litre 3) * cylinder displacement (litre 3/intake stroke) based on air density
at STP.
Characteristics of LOAD_ABS are:
— Ranges from 0 to approximately 0.95 for naturally aspirated engines, 0 - 4 for boosted engines,
— Linearly correlated with engine indicated and brake torque,
— Often used to schedule spark and EGR rates,
— Peak value of LOAD_ABS correlates with volumetric efficiency at WOT.,
— Indicates the pumping efficiency of the engine for diagnostic purposes.
Spark ignition engine are required to support PID $43. Compression ignition (diesel) engines are not required to support this PID.
And after the load calculation is made, its not like you want to reduce the injected fuel by up to as much as 13% in some cases. The air the MAF measured coming in didn't just disappear, and the MAF accuracy isn't affected by the RPM or load the engine is operating at. Unless there is some switch that forces the ECU into a speed-density mode (scary) it almost seems like this would be some vestigial table from an earlier version of the ECU software, or some unused mode.
Ask Me About My:
The Following 4 Users Say Thank You to Ziggo For This Useful Post:
cld12pk2go (02-05-2012), djuosnteisn (02-05-2012), Fobio (02-04-2012), rfinkle2 (02-06-2012)
 Old 02-05-2012, 03:32 PM   #60
Driver
Fobio's Avatar
Groans: 44
Form the other thread, it reads that we're to basically adjust VE according to STFT's. So if we normalize by adjusting the VE table, will it ultimately affect LTFT's?
Your logic makes sense to me tho, on the surface and as I understand it. I just want a straight answer that doesn't come from pulling teeth, one question at a time.
 Old 02-05-2012, 06:42 PM   #61
Damn you your extensive vocabulary Ziggo. Googling vestigial now. LOL
 Old 02-05-2012, 07:57 PM   #62
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
I'd like to use the VE table to potentially fix those few cars that go lean post spool for a bit.
Seems like yet another method for afr tweaks, but it's nice, cause it's far more specific, considering it's a load vs rpm point.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
JacksonMS30 (02-06-2012), phate (02-09-2012), rfinkle2 (02-06-2012)
 Old 02-06-2012, 07:12 AM   #63
Dustin, have you had the chance to compare any of your beta e85 scaled maps to any ots gasoline maps in terms of the VE table?
djuosnteisn (02-06-2012)
 Old 02-06-2012, 09:46 AM   #64
David mentioned that this release does not include the E85 scaling ... so he is probably not using the VE tables to achieve this.
djuosnteisn (02-06-2012), rfinkle2 (02-06-2012), wolly6973 (02-06-2012)
 Old 02-06-2012, 09:49 AM   #65
He mentioned the different injector related functions he was using in the past, I was just interested to see if there was any other tweaks involved that we may be able to glean some info from.
 Old 02-06-2012, 10:38 AM   #66
Captain
I can take a look next time i'm on my tune computer. Couldn't hurt.
www.permtuning.com
 Old 02-07-2012, 03:22 PM   #67
Eth/Meth Junkie
cld12pk2go's Avatar
I am playing with the new tables in ATR and I have also cut back to 5 gal E85/tank (~E30 ish), which required pulling about 2% from my MAF curves.
I did this to try to get around the WGDC pull and throttle close up top. While it looks like it is still wanting to shut the fun down up there, I did squeeze some more out while trying to develop a nice reverse taper boost curve...
And the power is getting sick:
My next tune will call for another 0.5 PSI / 0.05 load at 6500 RPMs...
Dano (02-07-2012), rfinkle2 (02-09-2012)
 Old 02-09-2012, 03:03 PM   #68
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I'm days late on posting, but that was the first thought that popped into my head when I heard VE tables I see it more so on the E85 cars than gas cars, and especially on the E85 cars with extensive bolt ons....where it might be enough to drastically change the VE of the engine.
I think @GLORIFIEDBOZO's car will be a good candidate for this, as he's checked his hardware for the 1,000th time since I told him it was too much and too weird of a maf correction to get the fueling right lol. If it works, we can start a thread about it or something.
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 5 Users Say Thank You to phate For This Useful Post:
Boosted Beluga (02-09-2012), djuosnteisn (02-09-2012), GLORIFIEDBOZO (02-09-2012), rfinkle2 (02-09-2012), wolly6973 (02-09-2012)
 Old 02-09-2012, 03:22 PM   #69
Captain
Yup.
While i totally see the application and potential usefulness for the VE table..... i'm still not 100% convinced on reason for it's existence. The whole purpose of a MAF sensor is to account for airflow. If VE falls off for some reason or another (like higher rpms, or inefficient turbo, etc etc etc)... airflow drops, and the maf completely accounts for it.
Lex had a decent idea suggesting it may have been used to account for air lost during over lap..... but i think even that's a hell of a stretch, hahaha.
But i'm not going to complain. Hopefully it sets the stage for potentially better uses down the road... like speed density. I heard Cobb had a similar release on the gtr shortly before they started supporting SD on that platform. So who knows... maybe they're just starting to get their ducks in row.
www.permtuning.com
atvfreek (02-09-2012), Boosted Beluga (02-09-2012), Nataphen (02-09-2012), phate (02-09-2012), wolly6973 (02-09-2012)
 Old 02-09-2012, 03:30 PM   #70
Eth Fiend
phate's Avatar
Totally agree there. Airflow should define fueling, which is metered by the MAF sensor. But if it works, I'm not going to complain too much. I'll do some testing with it in the next few days before I implement it on anyone else's car, just in case it does unexpected things.
-06 MS6
Boosted Beluga (02-09-2012), djuosnteisn (02-09-2012), Nataphen (02-09-2012), wolly6973 (02-09-2012)
 Old 02-09-2012, 03:40 PM   #71
Ziggo's Avatar
I like the idea of it accounting for overlap, but it's completely ass backwards if that is the case, and completely dependent on the stock VVT table. It could be a divisor instead of multiplier I suppose.
Zigatapatalka
Ask Me About My:
djuosnteisn (02-09-2012), rfinkle2 (02-09-2012)
 Old 02-09-2012, 03:47 PM   #72
Eth Fiend
phate's Avatar
We shall see. It's an exciting table, nonetheless
-06 MS6
 Old 02-09-2012, 03:49 PM   #73
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Originally Posted by David@COBB View Post
That table is what has been plaguing some of you on the Load tuning side. When the WG Duty Throttle Close Baro Threshold is reached, it branches from using WG Duty Load Dynamics to using this WG Duty Baro Error Comp. Notice as well that all the values are negative, as the ECU suspects that it needs to pull WGDC.
There are two ways to combat this. First of all you could do it the easy way and make it all 0's. At that point, it wouldn't pull WGDC at all when going over there.
The more CORRECT way of doing it is to use the WG Duty Throttle Close Baro Threshold values to raise the threshold of when it changes logic branches on you. You could raise threshold of Load/RPM area to see if helps.
-David@COBB
I had an issue while load targeting a while back where my datalogs showed that my ECU failed to get anywhere near targeted load values - it would meet targets for the first few seconds of a pull, but then at some point, it starts to deviate by over .06, with the gap widening as the pull continues.
i.e. at 5K RPM, my load target for 4th gear was 2.24, but the car was only hitting 2.06. Logs showed no throttle closure, and the throttle close, fuel cut, etc. limiter tables were all set high enough to prevent this from happening, yet it still happened.
I'm curious if this new table is the key.
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline   Reply With Quote
The Following User Says Thank You to f-castrillo For This Useful Post:
 Old 02-09-2012, 04:01 PM   #74
Captain
Make sure your "use boost based" toggle is enabled (checked), and all your load tables are set up accordingly. Then set your "max boost throttle close" table to like 24 or something for good merit. Should fix your issue.
www.permtuning.com
atvfreek (02-09-2012), Nataphen (02-09-2012), Nliiitend1 (02-09-2012)
 Old 02-09-2012, 04:05 PM   #75
atvfreek's Avatar
Posts: 7,787   (View Stats)
2.24 sounds like an unachievable load at 5k on stock turbo. Every stock turbo car Ive played with are at 2ish for load. Was your wgdc maxed or close to maxed (above 80%)?
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
djuosnteisn (02-09-2012), Nataphen (02-09-2012), rfinkle2 (02-09-2012)
 Old 02-09-2012, 04:09 PM   #76
Captain
Tappin
Agreed fully. But... The load target greatly depends on the maf cal. If his maf cal is just wildly off, and he's compensating by targeting overly lean afrs... may still be feasible.
But yeah, f-cast.... make sure your load targets are even feasible first, haha.
www.permtuning.com
 Old 02-09-2012, 04:19 PM   #77
Eth Fiend
phate's Avatar
OK, so I just set up two different variations of the VE table that I'll be testing on the way home. My car has been neglected lately, so I'm excited to see how this affects things.
-06 MS6
Boosted Beluga (02-09-2012), djuosnteisn (02-09-2012), wolly6973 (02-09-2012)
 Old 02-09-2012, 04:25 PM   #78
Captain
What did you vary? And what effect are you hoping for?
If the table was MAP referenced, instead of load (maf), we could honestly start playing around with the possibility of SD, haha.
/in before someone wires in a MAP and temperature sensor into the MAF connector.
www.permtuning.com
Last edited by djuosnteisn; 02-09-2012 at 04:25 PM. Reason: MSF Database - Automerged Doublepost
atvfreek (02-09-2012), rfinkle2 (02-09-2012)
 Old 02-09-2012, 04:29 PM   #79
Eth Fiend
phate's Avatar
I increased the VE table values in hopes that I will see more fueling...negative stft's and hopefully richer at wot. Its a small increase, so hopefully the car doesn't freak out. I'm burning 93 and its been dead consistent for the past few weeks. I'll get logs and post everything later.
-06 MS6
djuosnteisn (02-09-2012), Fobio (02-09-2012), Nataphen (02-09-2012), rfinkle2 (02-09-2012), wolly6973 (02-09-2012)
 Old 02-09-2012, 04:36 PM   #80
Captain
So you want to see negative STFTs? Or are they fairly positive, and you wanna bring them back down?
It'll be a great test to see how the table behaves Make a new thread maybe.
www.permtuning.com
Boosted Beluga (02-09-2012), rfinkle2 (02-09-2012)
2012 SCCA STX Auto-X build justint5387 MazdaSpeed 3/6 - Build Diaries 240 04-28-2014 07:19 PM
Help Hyundai build the 2012 Azera by... building a 2012 Azera Haltech Automotive News 0 08-30-2011 11:50 AM
Report: Akerson says GM will build Cadillac models outside North America by end of 2012 Haltech Automotive News 0 06-07-2011 12:50 PM
Rumormill: Honda to build road-going HSV-010 next year, pigs to take flight in 2012 Haltech Automotive News 0 03-29-2010 06:00 PM
Page generated in 0.59655 seconds with 35 queries
