> Cobb Tuning
 Old 09-10-2011, 12:24 AM   #1
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Default Problems with AP after new update
Did the last big update for my AP and now when I use the Live Data option the screen flashes black and white constantly and I don't understand why...any help?
2009 CWP Speed3
 Old 09-10-2011, 04:23 AM   #2
kmac's Avatar
Posts: 1,792   (View Stats)
U need to update your maps as well or install the new version of your current map . If u r using an ots tune.
The Following User Says Thank You to kmac For This Useful Post:
rfinkle2 (09-16-2011)
 Old 09-15-2011, 07:49 PM   #3
speedtown's Avatar
Posts: 533   (View Stats)
speedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the world
did this work for you? I opened my old map and re-saved it but my ap is still freaking out. When I try and change my map it says it won't connect. I'm to try and re-save and see if that helps. I could always just start over, been needing to do some tweeking anyway.
06 VRM MS6 - AP Stage 2 (Self Tuned to 18psi) - Forge BPV - PG SRI - PG TIP - Turboxs TP - ETS TMIC - TMW Stage1+JB SSP - CP-e RMM - PTP smokey turbo fix - Bnoon bolt - Prosport Boost Gauge in block8head vent pod
speedtown is offline   Reply With Quote
 Old 09-16-2011, 09:39 AM   #4
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
mine did the same till i re- saved my map and re-flashed my car.. now its all good..
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
 Old 09-16-2011, 09:58 AM   #5
speedtown's Avatar
i just did that and my ap still is flashing like crazy. I know sometimes you have to flash a couple times to get a map to stick but I've never had that problem before.
I'll just update it again and re save my map and see where that takes me.
 Old 09-16-2011, 10:42 AM   #6
Yep worked for me. Update your AP and ATR. Then save the map in ATR and reflash it and then your golden
Sent from my PG86100 using Tapatalk
2009 CWP Speed3
Problems with AC trdsw MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 07-03-2011 10:49 AM
A/C Problems superskaterxes MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 05-27-2011 08:48 AM
Few problems need help MS6 KoleDeRacer MazdaSpeed 6 - Engine, Transmission & Driveline 8 01-03-2010 10:26 PM
Will i have problems? Grim MazdaSpeed 3/6 - Turbo Induction 5 04-04-2009 01:03 PM
Page generated in 0.26180 seconds with 23 queries
