> Cobb Tuning
 Old 03-10-2013, 04:46 PM   #1
BLAKK's Avatar
Posts: 130   (View Stats)
BLAKK is the leader of the worldBLAKK is the leader of the worldBLAKK is the leader of the worldBLAKK is the leader of the worldBLAKK is the leader of the worldBLAKK is the leader of the worldBLAKK is the leader of the worldBLAKK is the leader of the worldBLAKK is the leader of the worldBLAKK is the leader of the worldBLAKK is the leader of the world
Groaned at 11 Times in 3 Posts
Default Stock 2012 exhaust +stage2?
I own a 2012 Speed3. i bought it with 8k miles on it.
I purchased a Corksport Intake, and a cobb ap, also fuel pump internals.
Am i safe to run cobbs Stage2+CS 91 with the stock exhaust? or is a full turbo-back needed?
One last question.. I have yet to lift the car up but is the stock ms3 exhaust dead silence or does it have a decent pur to it when you start the car up?
BLAKK is offline   Reply With Quote
 Old 03-10-2013, 05:01 PM   #2
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
You need one of the cats removed for stage 2 ots. Get a test pipe its cheap
2012 MS3
Stratified 91
The Following 2 Users Say Thank You to Keko For This Useful Post:
BLAKK (03-10-2013), MazdaBoy2.3 (03-10-2013)
 Old 03-10-2013, 05:03 PM   #3
Hush's Avatar
Posts: 520   (View Stats)
Hush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the world
Groans: 156
Stage 2 is for a high flow cat, or delete one cat, so no, you should still be using stage 1.
Last question I don't understand, keep in mind.... one mans pur may be another mans growl.
-2012 CWP MS3 -
- COBB AP V2b - Autotech HPFP Internals - JBR 3.0 WP - CP-E TMIC - UR TP - NGK ILTR6A-8G # 3787 plugs - EGR delete - Bosch 3-bar TMap - DO WMI 50/50
- JBR RMM 88a - JBR PMM 70a + JBR TMM 70a - JBR OCC S2 - JBR SSP - JBR SSB - JBR RSB -
- Block8head single defrost pod - VDO Vision Boost Gauge - Maisonvi Custom Stainless Steel Ball Shift Knob -
- Self Tuning 91 octane of fail with 50/50 WMI of win -
Hush is offline   Reply With Quote
 Old 03-10-2013, 05:09 PM   #4
BLAKK's Avatar
perfect,
so a test pipe will allow me to run the stage 2 tune? its my wifes car.. we both want performance but need no more exhaust noise if that makes sense.
 Old 03-10-2013, 05:13 PM   #5
Hush's Avatar
Groans: 156
Originally Posted by BLAKK View Post
perfect,
Yessir...test pipe gets you to stage 2.
Exhaust note seems deeper and has more rumble, not really louder IMO.
-2012 CWP MS3 -
The Following User Says Thank You to Hush For This Useful Post:
BLAKK (03-10-2013)
 Old 03-10-2013, 05:14 PM   #6
BLAKK's Avatar
perfect thanks guys!
 Old 03-10-2013, 05:17 PM   #7
GODspeed7's Avatar
Posts: 3,456   (View Stats)
You can also get a resonated test pipe to open it up and keep the exhaust note somewhat tame. Check out Ultimate Racing.
2012 Mazdaspeed3 Black Mica
BLAKK (03-10-2013)
Yes, the stock exhaust. Dralphy Gen2 MS3 General Discussion 39 09-26-2012 11:57 AM
Stage2: Stock tune vs. 103d Ferdball MazdaSpeed 3/6 - ECU Computer Tuning 7 12-12-2008 11:40 PM
Page generated in 0.26677 seconds with 23 queries
