> Cobb Tuning
 Old 02-10-2011, 09:05 PM   #1
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
i took a crack at this, and it seems to have worked out well so far.
i took the ignition/timing tables from stage2+SF 91 and swapped them into my stage2+SF+TMIC 93 map. the "high throttle" tables were different between the two while the "low throttle" were not. i swapped the low throttle ones over but didn't notice a difference.
coming up on 100miles on the tweaked map, i'll mostly be looking to see if i get much KR at WOT. running 93 on the un-tweaked 93 map gave me minimal knock at WOT.
i had tried the 91octane stage2+SF map and found that it did not hit commanded AFR's at WOT, obviously because of the TMIC. i did run WOT this morning and saw that my AFR's were hitting target.
thanks, evidence! great first step.
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
[sold - 90 Miata - summer/project car, turbo w/ goodies, DIYPNP, springs/struts, etc.]
[sold - 08 MS3 GT - intake/downpipe/tuning/fuel pump/TMIC/springs/struts/etc.]
08_ms3_gt is offline   Reply With Quote
Stage 1 with TMIC Rulazig
Cobb ATR Support
8 04-13-2010 01:29 PM
2009 MS3 Stage 1+SF 93 +TMIC pwrful4
Cobb ATR Support
5 10-02-2009 02:37 PM
map request... v102 stage 1 + sf 91 octane cali skeeter149 MazdaSpeed 3/6 - ECU Computer Tuning 1 04-15-2009 09:44 PM
stage 1+ ms cai v103a 93 octane. dread
Cobb Access Port/Maps
12 12-22-2008 02:53 PM
Cobb Stage 2+TMIC+93 Dyno - MS6 LBV MazdaSpeed 3/6 - ECU Computer Tuning 13 10-03-2008 11:19 AM
Page generated in 0.22756 seconds with 21 queries
