> Cobb Tuning
 Old 01-06-2011, 12:39 PM   #1
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
Default why do you only have a 93 octane stage 2 + tmic map?
hi i have been throwing around intercooler ideas and noticed you have a ots map for stage 2 + sf + tmic 93 octane. why not a 91 octane map? i am stuck in cali all we have is shitty 91 and 100 octane race fuel for 7.59 a gallon help.... thanks anyhow
 Old 01-06-2011, 12:41 PM   #2
Post pwned's Avatar
Posts: 799   (View Stats)
Post pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the world
That hurts!
2010 Mica Black
RMM/RSB/SRI+TIP
Post pwned is offline   Reply With Quote
The Following User Says Thank You to Post pwned For This Useful Post:
skeeter149 (01-06-2011)
 Old 01-16-2011, 01:24 PM   #3
evidence's Avatar
Posts: 1,033   (View Stats)
Open the stage 2 + tmic 93 oct map in ATR and copy over the timing values from a similar 91 oct map. That should fare you pretty well. Do some logs and make sure your good to go, might have to tune boost down a tad but I'll bet your fine. Probably best to dial in your MAF and create your own map sometime soon since your already working in ATR, but the above isn't a bad first step.
Cobb pretty much created the tunes with logs from our cars, so if no beta tester had stage 2 + tmic in a 91 oct state, a map wasn't made.
Some things.
The Following 2 Users Say Thank You to evidence For This Useful Post:
08_ms3_gt (02-10-2011), aaronc7 (01-16-2011)
 Old 02-10-2011, 09:05 PM   #4
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
i took a crack at this, and it seems to have worked out well so far.
i took the ignition/timing tables from stage2+SF 91 and swapped them into my stage2+SF+TMIC 93 map. the "high throttle" tables were different between the two while the "low throttle" were not. i swapped the low throttle ones over but didn't notice a difference.
coming up on 100miles on the tweaked map, i'll mostly be looking to see if i get much KR at WOT. running 93 on the un-tweaked 93 map gave me minimal knock at WOT.
i had tried the 91octane stage2+SF map and found that it did not hit commanded AFR's at WOT, obviously because of the TMIC. i did run WOT this morning and saw that my AFR's were hitting target.
thanks, evidence! great first step.
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
[sold - 90 Miata - summer/project car, turbo w/ goodies, DIYPNP, springs/struts, etc.]
[sold - 08 MS3 GT - intake/downpipe/tuning/fuel pump/TMIC/springs/struts/etc.]
08_ms3_gt is offline   Reply With Quote
Stage 1 with TMIC Rulazig
Cobb ATR Support
8 04-13-2010 01:29 PM
2009 MS3 Stage 1+SF 93 +TMIC pwrful4
Cobb ATR Support
5 10-02-2009 02:37 PM
map request... v102 stage 1 + sf 91 octane cali skeeter149 MazdaSpeed 3/6 - ECU Computer Tuning 1 04-15-2009 09:44 PM
stage 1+ ms cai v103a 93 octane. dread
Cobb Access Port/Maps
12 12-22-2008 02:53 PM
Cobb Stage 2+TMIC+93 Dyno - MS6 LBV MazdaSpeed 3/6 - ECU Computer Tuning 13 10-03-2008 11:19 AM
Page generated in 0.26447 seconds with 23 queries
