> Cobb Tuning
 Old 05-24-2011, 07:50 PM   #1
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
Default Will there come a time for Gen 1 to 2 ECU swap?
Assuming the mechanical bits are the same or made to be the same, will there come a time when it'll make sense to swap to a Gen 2 ECU?
personally, it might be worth it to cut down on downtime as development is focused on the Gen2 and so forth. I hate waiting for the trickle down effect considering we helped make the current market...
now I know what it feels like to be a MS6...
-- Mario Andretti --
 Old 05-25-2011, 12:49 AM   #2
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
get a custom tune
DONOTBUGME is offline   Reply With Quote
 Old 05-25-2011, 02:38 PM   #3
Driver
Fobio's Avatar
Groans: 44
Originally Posted by donotbugme View Post
get a custom tune
I tune my own car and even if I got someone else to do it, I'd still benefit from the newer logic being pushed out to the Gen2's first.
 Old 05-25-2011, 02:42 PM   #4
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
amoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the world
Groans: 53
Groaned at 31 Times in 22 Posts
You don't know what it feels like to be an MS6.... it feels awesome.
You know.... Moose stuff
amoosenamedhank is offline   Reply With Quote
The Following User Says Thank You to amoosenamedhank For This Useful Post:
manelscout4life (05-25-2011)
 Old 05-25-2011, 03:00 PM   #5
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
I dunno if it could happen due to the poo's having taller gears. There is nothing in ATR that lets you change the gearing!
The Following User Says Thank You to Fatguy729 For This Useful Post:
Fobio (05-25-2011)
 Old 05-25-2011, 03:03 PM   #6
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
I don't see any reason for a gen1 to switch to the gen2 ECM.. There is nothing in the ECM hardware that makes it better, it has no extra functionality, and IMO the firmware seems to be even more taxing on the HPFP than the gen1...
My ATR sure does have gearing tables so you can let the ECM know your not running the gen2 tranny...
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
rfinkle2 (05-25-2011), silvapain (05-25-2011)
 Old 05-25-2011, 03:10 PM   #7
Driver
Fobio's Avatar
Groans: 44
I don't think it's a matter on functionality. Or anything better per se. It's the difference in logic (I think), and since all the focus in development is now on the Gen2's I just want to by-pass the waiting on Cobb to port over the changes from Gen2 back to Gen1.
 Old 05-25-2011, 03:21 PM   #8
Groans: 60
There are so many different CAN subsystems integrated in these car I don't even think it is possible to just swap them...
You may end up with a running motor, but have several non-functioning CAN components.. It wouldn't be much fun driving without a cluster and ABS, or without working airbags...
The Following User Says Thank You to SSinstaller For This Useful Post:
Fobio (05-25-2011)
 Old 05-25-2011, 03:40 PM   #9
DONOTBUGME's Avatar
Groans: 266
gen1=gendone
The Following User Says Thank You to DONOTBUGME For This Useful Post:
vatordoc (05-25-2011)
 Old 05-25-2011, 03:49 PM   #10
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
It'd suit me just fine to run without working airbags.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 05-25-2011, 03:57 PM   #11
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
not sure why u think gen2 is so fancy. plenty of people making high power in gen1 and theres nothing different about the gen2 ecu then gen1 that u cant change/mimic in ATR.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 05-25-2011, 04:00 PM   #12
Driver
Fobio's Avatar
Groans: 44
in no way am I thinking the Gen2's are fancy...not at all...lol...
just that Cobb's development is focused on Gen2 logic..and now I have to wait for that shit to be ported over. that's all.
 Old 05-25-2011, 04:40 PM   #13
Must Have Teh 10's!
yea but if you do your own tuning why do u need to wait for cobb for anything?
 Old 05-25-2011, 04:50 PM   #14
Driver
Fobio's Avatar
Groans: 44
the boost tuning logic doesn't work as advertised. I can go back to load based, but when they fix the boost tune logic, they'll and have applied it to the Gen2's first. now we have to wait for the changes to be ported over.
I can see this being a pattern.
 Old 05-25-2011, 04:58 PM   #15
When some of the gen2 tables were discovered inactive, Cobb mentioned that after the 2011
beta testing was over, they were going to concentrate more effort and manpower to ATR and
transferring gen2 logic to gen1.
 Old 05-25-2011, 07:24 PM   #16
DONOTBUGME's Avatar
Groans: 266
gen 2 has no ffs, and lc yet
 Old 05-26-2011, 07:22 AM   #17
Also no fan or idle control. LOL
 Old 05-26-2011, 08:15 AM   #18
Driver
Fobio's Avatar
Groans: 44
yes, I'm also aware of these.
when talking with Christian, part of the reason for boost based tuning is to help BT setup's get up and running quickly, esp with the boost control aspect of tuning. after seeing recently what one of the locaql tuners have to do to get a 3071 running, it doesn't seem like any of the boost based tuning in its current incarnation made it any easier at all.
I may get a turn at tuning this car this wknd and we'll see what's up. I just think that when it comes to my own BT build, I'll likely just got back to load based tuning.
The Following User Says Thank You to Fobio For This Useful Post:
rfinkle2 (05-26-2011)
 Old 05-26-2011, 08:18 AM   #19
That seems to be the consensus forming from gen1 guys who have done both load and pressure based tuning.
 Old 05-26-2011, 08:51 AM   #20
DONOTBUGME's Avatar
Groans: 266
dj is using load tuning over boost tuning for my car
 Old 05-26-2011, 08:57 AM   #21
First of all, I'd personally stick to load instead of boost based tuning. Boost based is more primitive and further the ECU logic is not setup for it. Why fight it?
Secondly, it wouldn't work as the ECU is different and I am sure the wiring is as well amongst other things such as messaging across the CAN network etc.
Fobio (05-26-2011)
 Old 05-26-2011, 09:09 AM   #22
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Is this a documented problem? Do you have a link to that source? I've noticed in the few photos of totaled genpus that the airbags don't seem deployed, so I was curious if this was documented at all.
 Old 05-26-2011, 09:33 AM   #23
Tokay444's Avatar
Groans: 793
It was just used as a "for instance" to describe a situation why you may not want an ecu from genpu in a genwon. They control different things differently. The poster said you wouldn't want to drive around with no dash lights and airbags that didn't work, which was when I said I wouldn't mind if mine didn't work.
Demodded.
The Seals
Speed3eak (05-26-2011)
 Old 05-26-2011, 09:35 AM   #24
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
i cant get the fan control to work on my speed6...
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
Nap Time to Lap Time: 74-year-old James Hylton to race at Daytona Haltech Automotive News 0 11-27-2008 04:40 PM
Page generated in 0.42502 seconds with 30 queries
