> Cobb Tuning
 Old 08-26-2011, 03:29 PM   #1
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
Default WTF is going on with my AP
So I have had my used AP V2b or whatever, the newest version, for about 8 months now. For the most part it works great and does what it should. However, recently, I have being having a problem when trying to take logs.
I am usually monitoring live data prior to logging, mostly just sitting on KR or something, then I will hit the middle button to start a log. Recently, I have been having an issue where I press the button to log and it kinda freezes for a second. It switches to say "logging" vs. monitoriing, but the data goes to "--" and after a second or two it says communicatino with ECU lost. Same screen as if you leave it on monitor then turn the car off. I have to back all the way out to the main menus and go back into Live Data to reset it. When I get home it has created a datalog file, but the size is "N/A" and there is no data in the log.
Is does this intermittenly and doesn't appear to be related to connection issues or anything. I check the cables and they are all plugged in and secure. I can have this issue, then without touching anything, after backing out and back into the live data and collect a normal log and everything works as it should.
I started seeing this about a month or more ago and it would happen very rarely. Now it is to a point where almost every other log I do this happens. It is very annoying seeing that I dont' have a lot of opportunity to take logs and seems like whenever I really want to see my data is the time I look down and its all error'ed out.
Anyway, sorry for the mini rant. Just curious if anyone has ideas of what is going on or what I need to do to fix the issue. Thanks,
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
The Following User Says Thank You to BigjohnB20 For This Useful Post:
JS + MS3 (08-28-2011)
 Old 08-27-2011, 09:59 AM   #2
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
It is probably due to the beta software/maps. I have the same issue.
 Old 08-27-2011, 12:39 PM   #3
josurr's Avatar
Posts: 954   (View Stats)
josurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the world
Groans: 156
I had that same issue the first time I tried to take a log after updating ATR, AP Manager, the AP and flashing a beta map.
However, after that one time, I haven't had a problem taking a datalog at all (only problems I have had are accidentally pressing the center button twice when starting so it will log for like a second, or pressing the button mid run...)
josurr is offline   Reply With Quote
 Old 08-27-2011, 12:51 PM   #4
WorstEpEver's Avatar
Posts: 418   (View Stats)
WorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the world
I have the same issue after switching to beta maps. Does it maybe 1 out of 10 times.
09 MGM Sport
AP (MIA ) / Internals / TMIC / CAI / TIH / Downpipe / CBE / Short shifter / RMM / RSB
WorstEpEver is offline   Reply With Quote
 Old 08-28-2011, 02:25 PM   #5
BigjohnB20's Avatar
Thanks for the replies guys. Good to know it doesn't sound like it is a problem specific to my AP. Guess just wait it out until they update again.
2006 BCM MS6 GT
CS SRI/TIP
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
 Old 08-28-2011, 04:07 PM   #6
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
I got the same problem a month ago.
It was after I switched to beta version. It seems to be fine nowadays. I didn't try anything different.
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
Page generated in 0.26295 seconds with 23 queries
